"No EEPROM/flash device found."
Hi. I’m having a little problem with my Thinkpad T440p. There is a Wifi whitelist that I would like to remove. Therefore I wanted to read the contents of the BIOS chip with the CH341A Pro.
To get better access to the chip, I disassembled my laptop. I did not have success in reading it out. I have been working on it for weeks. I reattached the programmer more than hundred times.
The chip:
https://i.imgur.com/fUKQZcf.jpg
https://i.imgur.com/gvQlXDs.jpg
The programmer:
https://i.imgur.com/WfGkJ4S.jpg
https://i.imgur.com/zvuJVgh.jpg
Programmer on the chip:
https://i.imgur.com/7ttvRxe.jpg
https://i.imgur.com/ty0L1Za.jpg
https://i.imgur.com/kYb2Fkx.jpg
Error message:
https://i.imgur.com/zdfFt1q.jpg
Do you have a tip how I could do this? What am I doing wrong?
@alan
Check the TEXT;
if are sure about the connection and it’s the same as this you need to find and try the following PCB.
If it doesn’t work: any high range industry standard hardware with in off-line ICP/ISP programming capability usually work out the box.
CH341A is kinda unlicensed product.
Probably someone mixed\flooded the inventory around the world with counter-counterfeiter copy of the copy (or spec datasheet) with unknown-number and no real specification to drive the profit on other/original product.
Never used the CH341A in-circuit with result before but maybe I just missed the merchant availability of the working PCB.
The Thinkpad T440p had a recent surge of popularity because the latest Coreboot supports it. There are a few guides that may help you since they have to attach a reprogrammer to it, so at least these instructions should apply to you. There are TWO Flash EEPROM chips, not one, keep that in mind.
https://blog.conor-burns.com/lenovo-t440p-coreboot/
https://doc.coreboot.org/mainboard/lenovo/t440p.html
