Great!
You are welcome, happy I was able to help!
Hello!
I am looking for a functional modded 2101 BIOS for the Asus Rampage V Edition 10. The links for Google Drive seem to be dead.
I am trying to unlock the hidden features for Virtualization and to allow DDA with Hyper-V on Server 2025. Based on all I can see on this bios, the features are available, just locked as āconsumerā and hidden.
I attempted using AMIBCP, but EZ Flash doesnāt like the .CAP I saved. Am I missing a step to flash this BIOS? Yes, I am very new to this.
Edit: I found this forum post - [Guide] How to flash a modded AMI UEFI BIOS
and also noticed it referenced in the topic earlier in the thread. I will check these options for my .CAP, but still would like if anyone could share the modded 2101 BIOS.
Edit 2: After enabling features I believe to be available with a successful flash, I was still not able to DDA the GPU.
@Powerfull
Hey, are there any tricks to getting this to work beyond turning CSM off and Above 4G Decoding on? Iām in Proxmox and seeing errors with an Intel B580 GPU.
[ 12.686176] pcieport 0000:01:00.0: bridge window [mem 0x00000000 64bit pref] to [bus 02-04] requires relaxed alignment rules
[ 12.686190] xe 0000:03:00.0: BAR 2 [mem size 0x400000000 64bit pref]: can't assign; no space
[ 12.686191] xe 0000:03:00.0: BAR 2 [mem size 0x400000000 64bit pref]: failed to assign
[ 12.686282] xe 0000:03:00.0: [drm] Failed to resize BAR2 to 16384M (-ENOSPC). Consider enabling 'Resizable BAR' support in your BIOS
[ 12.686286] xe 0000:03:00.0: BAR 2 [mem 0x383fe0000000-0x383fefffffff 64bit pref]: assigned
[ 12.686327] xe 0000:03:00.0: [drm] VISIBLE VRAM: 0x0000383fe0000000, 0x0000000010000000
[ 12.686512] xe 0000:03:00.0: [drm] Small BAR device
[ 12.686513] xe 0000:03:00.0: [drm] VRAM[0, 0]: Actual physical size 0x0000000300000000, usable size exclude stolen 0x00000002fb800000, CPU accessible size 0x0000000010000000
Hey, I do not know if this could work with Intel GPU, I only have knowledge and experience on NVIDIA 3000 series GPUs. I think in the BIOS Secure Boot Enable is also required.
May be asked this in ReBarUEFI or in Github.
Good luck, and let us known !
I fixed it, I forgot about ReBarState.
Heya,
Anyone has the latest modded bios without the ReBar?
The google drive links are down
Thank you!
