[Offer] Bugfixed Netgear XR500 Router firmware
Removed V8 with the LLM IPv6 fixes(its alot more busted than I thought and needs more manual verifing)
I’ve included the ipv4 fixed version that removes the whitespace.
dont use ipv6 on this router its a busted mess.
XR500-V2.3.5.152-fixed.img
Fixes in this build:
  1. WAN internet drop for a couple of seconds on every DHCP lease renewal
Caveats (read before flashing)
  • Community build — not tested or supported or approved by Netgear or NetDuma in any way.
Flashing
Note: Lookup TFTP restore XR500 for any major issues, but this is why I get you to flash 152 stock first, because if 152 stock works my fixed version will too, and if you have issues flashing 152 you had a problem unrelated to my fixes.
  1. Download this firmware and the stock firmware
  2. GUI config backup first. Settings - Administration - Backup settings - Back up - Make sure your browser actually saved the file because chrome blocks .cfg files these days.
  3. Flash the stock XR500-V2.3.5.152.img from netgear and reset the router if you were on an older version or the half arsed rc14 beta version(hold the reset pin)
  4. Set it up how you like it
  5. GUI config backup settings again for a fresh 152 based settings cfg
  6. Extract the firmware from the ZIP then Settings - Firmware update page → select the XR500-V2.3.5.152-fixed.img → upload.
  7. Do not power off or press reset during write/reboot (a few minutes of no LAN).
  8. Settings carry over if you were already on 152 no reset is required; version still reads V2.3.5.152.
after more testing the watchdog is shaker than a fox terrier in the rain
I’ve removed v7/v8 and put my original ipv4 fixed version up that gets rid of the trailing space
I need more verifing on the watchdog/ipv6 stuff, this router has badly messed up ipv6 implimentation it’s..horrifing this was meant to be a premium gaming router at one point and its firmware got released in this state.
