@SoniX
Are you really sure this is a new VBIOS? Have you modified it in any way? Because these are the only differences I see:
They are exactly the same, 1035 and 1036.
@SoniX
Yes.
No, I have not changed anything. Only clean setting.
I too at first confused similarity versions. But do not think that Toshiba will itself change the version.
The original BIOS https://www.sendspace.com/file/9k1m6j
Here is also Intel Hsw/Bdw GOP Driver 5.5.1032 & VBIOS 5.5.1038
Pulled from this Intel BIOS:
http://downloadmirror.intel.com/24804/eng/RY0246.BIO
GOP1032_VBIOS1038.zip (68.6 KB)
Yes
Purified file OROM VBIOS HSW_1038.DAT + BSF (Haswell/Broadwell 5.5.1038)
ASUS Z87-PLUS Slow boot
Can see the settings of your OROM VBIOS 1038 for Asus Z87-Plus? Please upload your file.
Need a similar patches
1035 VBIOS has similar moves before
Only for owners of motherboard ASUS Z87-PLUS.
Fully customized modules OROM VBIOS 1035 and VBT for GOP v5.5.1024 and higher.
Extract the contents of the archive in the folder "\Modules" and update.
Added:
Why is that on many sites Asus support this version does not.
New BIOS for Asius Z97-PRO BIOS 2012
- Improve system stability.
SoniX has attached files to this post OROM_VBIOS_1035_and_VBT_for_GOP ASIS Z87-Plus.rar
Where can I find OROM VBIOS for Ivy Bridge???
Does anyone have a 1037 bsf?
No, but there is 1038 if you want. Attached.
https://www.sendspace.com/folder/vdgvgg
1038.rar (80.1 KB)
1029 - 1038 VBT version and size identical. Scripts BSF compatible within these versions.
12/06/2015:
IronLake 2050 Desktop
IronLake 2050 Mobile
Cantiga 1573
Crestline 1428
Auburn 233
20/06/2015:
BearLake B 1471
Partial_VBIOS_and_BSF_20-06-2015.rar (209 KB)
Hi,
I just saw this topic and when i open AIDA64 and check the GPU tab it shows me this:
Can i update it to a newer build, lets say to the last one posted here (2153) or here (2170) or some newer than the one i have?
Sorry but i’m completely noob on this.
Thanks SoniX but it feels too much complicated for my taste and i’m scared of doing it since i don’t understand these techniques.
I tried the UBU tool but the only thing it shows is:
which i assume it can’t update by itself and need your guide instead, which is more complicated.
Anyway thanks for the info.
Haswell-Broadwell 1039
Original the scripts BSF compatible for 1029-1038
OROM_and_BSF_VBIOS_HSW_BDW_1039.rar (82.2 KB)
