Ok, home now, i will test on my Gigabyte shortly, but here is the mod and a short document.
VBIOSIntel2175_doc.zip (38.1 KB)
Looked. I also made the list. The list is not small.
It turns out that while the early talk about the universality of this method to work on all motherboards. Not really be corrected under each specific MB. Then may appear 2176 and above, and have to start all over again.
It’s like sticking a SLIC on MDL.
Yes, for it to work on all motherboards, i don’t Think would be impossible,
But i was hoping the Intel version would have all outputs, that of course would have made things easier.
EDIT: i do Think these Changes could be applied to new versions though, it does seem like different portmappings,
but i Think i can check that, as now i have also both Gigabyte 2171 and 2173, would just have to compare what is changed.
I compared Gigabyte Z87X-OC VBIOS 2170, 2171, 2173.
The values on the offsets i had written down, are in 2171 and 2173 identical, minor difference in 2170.
Even though i think my way of correcting the checksum is wrong, it does seem to work.
I attached the actual values from Z87X-OC 2170, 2171, 2173.
Z87X-OC Values.txt (6.63 KB)
Hey guys…anybody can extract new Intel MicroCode update ID: 0x326C309 Update Revision: 09 Date: 04/04/2013
from latest Z87 ASRock BIOS:
http://picx.xfastest.com/nickshih/asrock/Z87OCF151b.rar
Thanks SoniX.
What is the metod to extract?
I tried but my MMTool crash.
MMTool crash because he meets 2 empty modules.
1) Open MMTool and Load Image
2) Delete Vol 01 Ind 00 and Vol 02:01:02 Ind 02 modules (GUID 17088572-)
3) "CPU Patch"
@Pacman
Hello!
Test Result
Asus Z87-Deluxe/I7-4770K
DP/mDP/HDMI - All Working
Asus Z87-Plus/I7-4770K
D-Sub/DVI/HDMI - All Working
mDP - not testing
Asus MAXIMUS VI HERO/I7-4770K
HDMI - Working
Test Result
mDP - not testing
HDMI - Working
Good luck!
New IntelGopDriver 5.0.1033 for Haswell GUID 5BBA83E6-F027-4CA7-BFD0-16358CC9E123
IntelGopDriver_5.0.1033.rar (25 KB)
@SoniX
Here is Intel GOP Driver 5.0.1034 GUID 5BBA83E6-F027-4CA7-BFD0-16358CC9E123
IntelGopDriver_1034.zip (25.5 KB)
I have been a bit lazy, i have modded my Z87X-OC with it and flashed, and that works, but i only tried with the HDMI that is already connected, and i still have to get a DP adapter.
Have not tried on Asus board yet, but i will try on the Asus tonight and check the other HDMI on the Gigabyte.
It would be very interesting to know.
Both HDMI ports work with 2177 on my Gigabyte.
Have taken the Asus system apart, I’m going to sell the CPU.
What’s the latest VBIOS and GOP driver for Sandy Bridge (Z68)?
also for H67 pls…
For 6x/7x series
OROM VBIOS - v2158
EFI GOP Driver Sandy - v2.0.1024 GUID 8D59EBC8- + EFI GOP Driver Ivy - v3.0.1023 GUID 5BBA83E6-
PS EFI GOP Driver - On 6x series may be missing in the BIOS.
