@Pacman
I went ahead and indeed that works as designed as you just wrote to extract as is and go ahead from there
Then after I did the microcode update, I used the OROM replacer to update VGA and EFI VGA and EFI GopDriver on the BIOS I wanted to use…
LAN perhaps later with same OROM replacer method
That is good
Asus came out with a new BIOS version for my Maximus this morning, so i did it this way and it works fine, i also use Orom_replace for the rest of the updates.
Greetings to all.
Who has a utility to configure "OROM VBIOS"? Share please.
ADD:
Many thanks to Florin9doi, for the programme Intel BMP.
@SoniX
Hi
I found Ivy Bridge GOP Driver 3.0.1027 thought maybe you want.
Also Ivy/Sandy VBIOS 2170, but it is for mobile, and OEM, but maybe you want to have a look, i attached some files and original BIOS.
EDIT: Original BIOS has to be extracted Before MMTool, UEFItool.
2170Mobile.rar (3.33 MB)
@Pacman
@Fernando
@All
I propose to rename this topic. Add to the name of "Modification"
Full name of the theme will be like this:
"Intel Sandy/Ivy bridge and Haswell VBIOS differences and modification"
I suggest everyone to share their experiences and share OROM VBIOS and BSF files.
Intel® Binary Modification Program v2.67e PV
VBIOS and BSF
SandyBridge/IvyBridge - 2137, 2158
Haswell - 2170, 2173
Done! Thanks for your suggestion.
@ Pacman and SoniX:
While changing the thread and some post titles the Forum software did some HTML code mixtures. That is why I had do correct some quotes within the first 2 pages of this thread.
VBIOS and BSF
Update:
SandyBridge/IvyBridge - 2120, 2143, 2170
What is the original source for snd_2170 ??
VBIOS and BSF
SandyBridge/IvyBridge - 2120, 2137, 2143, 2158, 2170
Update:
SandyBridge/IvyBridge - 2089, 2102, 2104, 2108, 2111, 2119, 2132
PS I am looking for VBIOS and BSF versions 216x. Thank.
VBIOS and BSF
SandyBridge/IvyBridge - 2089, 2102, 2104, 2108, 2111, 2119, 2120, 2132, 2137, 2143, 2158, 2170
Add Haswell 2171, 2175, 2177
Fixed snm_2170.dat -> not displayed "LFP (Integrated LVDS) Features"
All a Happy New Year!
Good luck, happiness and prosperity in the New Year!
Edit:
Add Haswell 2178
@SoniX
I don’t know if you want this, "SNB/IVB-DESKTOP Build Number: 2153 PC 14.34 09/07/2012"
Not so new but i haven’t seen it Before, no BSF, from HP.
2153.zip (37.2 KB)
Hi.
I’m using P8Z77-V LE PLUS + 3570K
bios motherboard 0908
VBIOS 1243.0
How can I update VBIOS to 2170 from your archive? I do not know what program to use (
@ marsone:
Welcome at Win-RAID Forum!
The easiest way to update BIOS modules like the VBIOS is to use the "UEFI BIOS Updater" (UBU). You can find the download link and a guide within the start post of >this< thread.
Good luck!
Fernando
Thank you. You helped me very much!
VBIOS and BSF
Haswell - 2170, 2171, 2173, 2175, 2177, 2178
Add Haswell 2180
Many thanks to Pacman!
@SoniX thanks for the great work. I am unable to access the download (appears broken). Can you or someone upload the files again?
@ p4spooky:
Which download link are you searching for?
If it should be the VBIOS.rar file, I will attach it.
Regards
Fernando
VBIOS-BSF_HSW-SIB.rar (765 KB)
That’s it - thanks for your quick help Fernando
