Based on Bios Version: 3.4 SPS: 2.1.7.328
Added NvmExpressDxe_5.ffs driver.
X9DR3P9-B20-NVMe.zip (3.7 MB)
Welcome and thank you for sharing, presumably tested, the NVMe mod, enjoy.
Hi Meatwar…ive got a x9dr7-ln4f…do you think i can use this bios for my mobo,please?
As general rule, never.
Perform the mod according the NVMe guide in the forum.
EDIT: But this thread and the work made here, was about NVMe mod for the motherboard, not unlocking/unhide bios options or Bi-Furcation, im sorry but this i cannot do.
Some tasks/mods asked by users, takes too much time and responsibility, that’s why the forum and the users, shares the many guides around.
A post was merged into an existing topic: Supermicro X9DR7-LNF4 BIOS
thanks anyway…
Thanks, yes it’s been tested, works with my F80, the drives show up in the BIOS. I’ve had it running on my system since it was posted. No issues encountered so far.
Hi folks…Anyone knows if is posible to add to this bios offered…usb 3 support?this mobo doesnt have usb 3…and consequently…the usb 3 support not in the bios…But …my question…is,it is posibble to add usb 3 support and included thqt in the 3.4 bios offered here>thanks
Hi, reupload please bios file’s, if possible, thank you.
@Illia
Welcome to the Win-Raid Forum!
If you want, that the thread opener Stealth103 reuploads his modded BIOS, you should personally address your appeal to him/her (as “@Stealth103”). Otherwise he/she may not recognize your request.
Other idea: Try the BIOS modification yourself. >Here< is an easy to follow step-by-step Guide.
Good luck!
I still had the file laying around. It’s been reuploaded with a couple of new links. One directly on the forum, one on google drive.
Thank you ![]()
I would like to share my result. I’m not sure if this is the right effect, but it seems the firmware update was successful through AMI Flash. I got all the “done” stripes, but without a success message, and I was thrown back to the console after a couple of reboots and a BIOS reset. It seems everything booted up, but the lower banner in the BIOS settings showed version 2.1.15 instead of 2.1.17(maybe I’m stupid and this is Intel me version and Don’t need to be shown on down). After that, I went to the port settings and enabled 4x4x4x4 in the bi-furcation for the third slot. After booting into Windows not from the NVMe but from the SSD, I saw the NVMe working completely. I will try to install Windows on the NVMe and boot from it to give further feedback.
I double-checked everything, it worked, Intel ME is now 2.1.7.328, and there is now “PATA” or “PATA_SS” in the drives. I also want to say a big thank you for the work.
