PCH replacement on MSI GP76 and Boot Guard question
Hi guys i accidentally damaged the HM470 chipset of my MSI GP76-10UG laptop so it needs to be replaced.Is there anything i need to do to make the new PCH work because of Boot Guard or not?
Here is the MEinfo of my laptop:
Intel (R) MEInfo Version: 14.0.48.1605
Copyright (C) 2005 - 2021, Intel Corporation. All rights reserved.
General FW Information
    Platform Type                                Mobile
    FW Type                                      Production
    Last ME Reset Reason                         Other
    BIOS boot State                              Post Boot
    Boot critical code redundancy                Disabled
    Current Boot Partition                       1
    Firmware Update OEM ID                       00000000-0000-0000-0000-000000000000
    TCSS FW partial update                       Disabled
    Crypto HW Support                            Enabled
    Integrated Sensor Hub Initial Power State    Disabled
    OEM Tag                                      0x20020500
    FWUpdLcl                                     Enabled
    Capability Licensing Service State           Enabled
    TLS State                                    Disabled
    CSME Measured Boot to TPM                    Disabled
Intel(R) ME code versions:
    BIOS Version                                 E17K2IMS.30C
    Vendor ID                                    8086
    MEI Driver Version                           2047.100.0.1039
    FW Version                                   14.0.31.1120 H Consumer
    LMS Version                                  Not Available
IUPs Information
    PMC FW Version                               140.2.1.1008
    OEM FW Version                               0.0.0.0000
    PCHC FW Version                              14.0.0.7001
PCH Information
    PCH Version                                  0
    PCH Device ID                                68D
    PCH Step Data                                A0
    PCH SKU Type                                 Production PRQ Revenue
    PCH Replacement State                        Disabled
    PCH Replacement Counter                      0
    PCH Unlocked State                           Disabled
Flash Information
    Storage Device Type                          SPI
    SPI Flash ID 1                               C22018
    SPI Flash ID 2                               Not Available
    RPMC Replay Protection                       Unsupported
    RPMC Replay Protection Bind Counter          0
    RPMC Replay Protection Bind Status           Pre-bind
    RPMC Replay Protection Rebind                Unsupported
    RPMC Replay Protection Max Rebind            1
    Host Read Access to ME                       Enabled
    Host Write Access to ME                      Enabled
    Host Read Access to EC                       Enabled
    Host Write Access to EC                      Disabled
FW Capabilities                                  0x31119140
    Protect Audio Video Path - PRESENT/ENABLED
    Intel(R) Dynamic Application Loader - PRESENT/ENABLED
    Intel(R) Platform Trust Technology - PRESENT/ENABLED
    Persistent RTC and Memory - PRESENT/ENABLED
End Of Manufacturing
    Post Manufacturing NVAR Config               Yes
    HW Binding                                   Enabled
    End of Manufacturing Enable                  Yes
Intel(R) Protected Audio Video Path
    Keybox                                       Not Provisioned
    EPID Group ID                                0x3587
    Re-key needed                                False
    PAVP State                                   Yes
Security Version Numbers
    Trusted Computing Base SVN                   1
    Minimum Allowed Anti Rollback SVN            1
    Image Anti Rollback SVN                      5
    Intel(R) PTT initial power-up state          Enabled
    Intel(R) PTT State                           Enabled
FW Supported FPFs
                                                 FPF         UEP         ME FW
                                                 *In Use
EK Revoke State                                  Not Revoked Not Revoked   Not Revoked
Error Enforcement Policy 0                       Enabled     Enabled       Enabled
Error Enforcement Policy 1                       Enabled     Enabled       Enabled
Flash Descriptor Verification                    Disabled    Disabled      Disabled
Intel(R) PTT                                     Enabled     Enabled       Enabled
OEM ID                                           0x00        0x00          0x00
OEM KM Present                                   Enabled     Enabled       Enabled
OEM Platform ID                                  0x00        0x00          0x00
OEM Secure Boot Policy                           0x79        0x79          0x79
CPU Debugging                                    Enabled     Enabled       Enabled
BSP Initialization                               Enabled     Enabled       Enabled
Protect BIOS Environment                         Enabled     Enabled       Enabled
Measured Boot                                    Enabled     Enabled       Enabled
Verified Boot                                    Enabled     Enabled       Enabled
Key Manifest ID                                  0x01        0x01          0x01
Force Boot Guard ACM                             Enabled     Enabled       Enabled
PTT Lockout Override Counter                     0x01        0x00          0x01
Persistent PRTC Backup Power                     Enabled     Enabled       Enabled
RPMC Rebinding                                   Disabled    Disabled      Disabled
RPMC Support                                     Disabled    Disabled      Disabled
SOC Config Lock State                            Enabled     Disabled      Enabled
SPI Boot Source                                  Enabled     Enabled       Enabled
Txt Supported                                    Disabled    Disabled      Disabled
ACM SVN                                          0x02        0x02          0x02
BSMM SVN                                         0x00        0x00          0x00
KM SVN                                           0x00        0x00          0x00
OEM Public Key Hash FPF                          3C407389592A222A836AF668A51C65DFEB1E832E5236F53EAA6A348E8811EA24
OEM Public Key Hash UEP                          3C407389592A222A836AF668A51C65DFEB1E832E5236F53EAA6A348E8811EA24
OEM Public Key Hash ME FW                        3C407389592A222A836AF668A51C65DFEB1E832E5236F53EAA6A348E8811EA24
