[Problem] Asus Zephyrus M16 GU603HM Keyboard not working
Hello
I am really new to this but it feels really great and I unlocked one of the most interesting thing of mind storming :grin:.
I have Asus Zephyrus M16 GU603HM with a broken Bios chip I have managed to find some bin files online searching and flashed the chip with it couple times now , many bins dump 310 , 313 , 315 , 315 . Some with different SN and some with mine .
The built-in keyboard never worked on any of the bin files , touchpad works on UEFI but not on windows setup , USB loads only the old kind of flash drives like 1gb or 2gb .
I browsed many topics here and found out about the EC frimware and it is related to keyboard and drivers , sorry still dumb in this , and some nvram needs to be reset and ME region etc .
What sould I do to get keyboard to function and I have noticed the Nvme works most of time but sometimes is not showing in UEFI.
There is no USB legacy option in UEFI
Thanks in advanced
Edit by Fernando: Thread title shortened
2021 ROG Zephyrus M16 GU603HM - Badcaps
I posted there also , the last 4 comments is me looking for a solution or EC frimware etc
Do you see anyone there talking about an EC file or IC on the mb or sharing any file of it?
You have main bios IC and next to it a liitle top is the NVidia FW.
Re-initializing the CSME FW:
[Guide] Clean Dumped Intel Engine (CS)ME/(CS)TXE Regions with Data Initialization - Special Topics / Intel Management Engine - Win-Raid Forum
That’s all from me, nothing more to add, good luck.
I really appreciate your time reading my post , this one is really new to me and I need to learn what is the EC and how to mod the bios dumps etc , I will give it a try hopeing to see some progress
@Jebreni
What has your problem to do with the Forum Category “BIOS Modding/Flashing Tools”?
If it should be related to the Intel Management Engine Region, I recommend to move it into >this< Category by editing the first post.
Thanks a lot fernando
I am still new at doing this , you guys a experts int this field.
IDK if its possible to ask for a detailed tutorial which tools should I use and which files can I go with , there is alot more than I expected in here and it looks too complicated form me to be honest, should I get the ME cleand from a working dump in order to get the keyboard working again , thanks in advance.
As I understand I need to do :
1- ME Analyzer
2- Find the correct CSME that fits my dump
3- decomple or hex edit with the new file
4-comple or save the output file
5-flash back the bios chip with this file
Is there something I missed to mention ?
