Since my HP EliteBook 2170p Notebook was not powering up, I extracted its 25Q128FVSG winbound bios chip and managed to read its contents with ch341a software. Thanks to the those in this forum who directed to various guides.
I inserted photos what the software shows me. Is my bios chip completely dead? Pls advise, thanks)
Im not saying that you can trust the Detect button…im saying you can manually select it.
As the IC was desoldered from the mainboard and presumably well soldered to the WSON/DIP adapter, if everything is working… yes we also can assume its a dead IC…
Good luck
Recommend to read the chip properly before drawing conclusion. What’s the meaning of reading a X24something with 128 byte size if the chip obviously has 16Mbyte?
I did select my bios name in ASprogrammer, managed to read it and saved the bin two times with identical file size of 16 mb.
As far as I see, there are only ffs in this file, no valuable info to extract.
Reading the guides again, I see that next steps should be erase the chip, verify the blank and then write again a bios file similar to my laptop version. If I am lucky to find one)
Thank you all for the excellent tips. I fiddled a bit with AS software and managed to read bios from the chip correctly. I see that there is some info on the chip.
How should I check whether the info is corrupted or not?
This bios firmware should contain a password, so Id like to investigate and find it as well before erasing the bios.
Any suggestions how to proceed further? Thank you.
