Although please note I did take it to a technician and I think they also tried flashing my laptop. Regardless, this was the backup I read from the ch341A after I took it to the technician and said they couldn’t fix it (i’m taking matters into my own hands now).
You’re welcome! You can try downgrading to BIOS version 318 now that the laptop is working, just enable the downgrade option in the BIOS settings (If there is)
So the problem came back after I just put my laptop to sleep (charger disconnected), When I woke up, its back to the same bricked state (no post, kb backlight on, caps lock unresponsive). It seems to have problems with the sleep state as when I shut down/ restart, it works fine
This sounds very much like a hardware issue (GPU not being detected, working fine on integrated graphics, the “sleep state”, the bricked state etc.). You may need to check the GPU VRAM MOSFETs and Modules or have a professional repair technician do it for you.
