[Problem] Bricked HP Envy x360 15-cn0 after BIOS Flash
[HELP] HP Envy x360 15-cn0xxx – Cypress CCG5 PD Controller dead after BIOS F.31 – USB-C completely gone
Device:
HP Envy x360 Convertible 15-cn0xxx
Platform ID: 8483
BIOS: Insyde F.31 (latest available – HP has EOL’d this platform, no newer BIOS exists)
CPU: Intel Core i7-8550U (Kaby Lake-R)
OS: Windows 11 + Ubuntu dual boot
Problem:
After BIOS update to F.31, the USB-C port is completely dead. No data, no power delivery, no video output. Before F.31, everything worked perfectly (charging, DisplayPort, HP G4 Dock).
What has already been confirmed/ruled out:
  • Hardware is intact: When performing a CMOS reset (Win+V), the HP G4 Dock LED briefly lights up when connected to the USB-C port – proving the port and dock are physically fine.
  • Windows 11: UCM-UCSI ACPI Device shows Status OK, ConfigManagerErrorCode 0. No error flag, no Code 43.
  • Registry: HKLM\SYSTEM\CurrentControlSet\Enum\ACPI\USBC000\0\Device Parameters\FirmwareIdentified = 0x1 – Windows knows firmware should be there but gets no response.
  • Device Manager: No Thunderbolt controller, no USB-C controller anywhere – not even as hidden device. Only standard Intel USB 3.0 xHCI (00:14.0) visible.
  • ACPI: Get-PnpDevice shows ACPI\USBC000\0 present, service = UcmUcsiAcpiClient.
  • HP CMSL: Platform 8483 returns 404 on ALL Windows versions (win10/21H2/22H2, etc.) – HP has completely removed this platform from their update database.
  • fwupdmgr (Linux): Cypress CCG5 / UCSI device does NOT appear at all.
  • dmesg (Linux):
    [1.054023] ACPI: bus type thunderbolt registered
    [11.101114] ucsi_acpi USBC000:00: failed to reset PPM!
    [11.101123] ucsi_acpi USBC000:00: error -ETIMEDOUT: PPM init failed
  • lspci: Only 0000:00:14.0 USB controller: Intel Sunrise Point-LP USB 3.0 xHCI visible. No Thunderbolt/USB-C controller on PCI bus.
  • ACPI path: \_SB.UBTC exists, _STA returns 0xF (device present and enabled per ACPI).
  • i2c scan: Bus i2c-1 (Intel Sunrise Point-LP I2C #1, PCI 0000:00:15.1) shows UU at address 0x10.
  • i2cdump -f -y 1 0x10: Returns all zeros (0x00) across all 256 registers – controller is on the bus electrically but its internal processor is frozen/empty.
  • All standard resets attempted: 30-sec power drain, 60-sec power drain, battery disconnect, CMOS reset (Win+V), Win+B BIOS recovery, Windows reinstall, Ubuntu install, BIOS reflash via Windows – none resolved the issue.
  • HP BCU / RU.efi: HP Sure Start blocks all third-party EFI execution. RU.efi cannot be launched even with Secure Boot disabled.
Root cause (as best as I can determine):
BIOS F.31 appears to have corrupted or failed to flash the Cypress CCG5 PD controller firmware. The controller is electrically present on I2C bus 1 at address 0x10, the ACPI table declares it (_STA = 0xF), but the internal MCU returns only zeros – classic “blank/corrupted firmware” symptom. The controller’s firmware version shows as 0.0 in Windows.
What I need:
One of the following:
  1. A working Cypress CCG5 firmware binary for platform 8483 (HP Envy x360 15-cn0xxx) that can be flashed via CH341A programmer directly to the flash chip on the board.
  2. A modified BIOS for platform 8483 (Insyde F.31) that correctly initializes the CCG5 and re-includes the PD firmware in the update payload.
  3. Guidance on how to extract the CCG5 firmware from the original F.31 BIOS binary and reflash it via external programmer.
What I have available:
  • CH341A programmer (or willing to acquire one)
  • Ubuntu terminal with full root access
  • Windows 11 with admin access
  • The original F.31 BIOS SoftPaq
  • HP SoftPaq sp102315 (extracted)
  • Multimeter / basic soldering capability
Any help is greatly appreciated. This is clearly a F.31 regression – the hardware is confirmed intact, all software paths are exhausted.
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title shortened
What you dont provide to any user willing to help you… a aboard schematic/boardview, the IC location and his info, Hp diagnostics report, Intel ME FW report status…that can be re-initialize/clean and may be one of the causes of the PYH failure…
Found info on HP SoftPaq sp102315…a GPU windows driver…
Found info on bios F31, points to SP147423 from May 22, 2023… on HP ENVY 15-cn0000 x360 Convertible PC…
Hi, since you have an external SPI programmer, make a backup of your BIOS chip and post it. This is your request for the BIOS file, but make a backup first (IMPORTANT)
Platform ID: 8483 BIOS Version F.31 Rev.A
08483.rar (5.5 MB)
I was also confused when I saw that sp102315 was the AMD High-Definition Graphics Driver.
