Hi everyone,
I’m trying to recover a Lenovo LOQ 15IRX10 (MTM: 83JE002KUS) that is stuck in an
infinite ROM recovery loop and never boots to Windows — external HDMI output works
and shows the recovery message, but the internal display stays off and it never
progresses past this state.
Since the machine can’t boot Windows at all, the official Lenovo BIOS update tool
(r3cn44ww.exe, version R3CN44WW / V44) can’t run — it fails with “This platform
does not support IHISI interface” when run from another PC, and obviously can’t
run on the affected machine since it never reaches Windows.
I extracted the update package with 7-Zip (without executing it) and found:
- signed_R3.ROM (21,264,072 bytes) — appears to be a Windows-signed UEFI Capsule
(file reports it as PE32+ EFI application), not a flat/raw image - $BVDT signature at offset 5,331,888
- _FVH signature at offset 736
- $BIOS signature at offset 16,545,696
- Internal config strings reference “BIOS.fd”, “ME.fd”, “32bios.bin”, “64bios.bin”,
and “platform.ini” — this comes from a leftover H2OFFT MULTI_FD config block - BIOS chip is Winbond (SPI)
- pcie_pei_enable=crisisrecovery string is present in the package
What I need help with:
- How to properly extract the raw flat BIOS image (the actual “64bios.bin”
equivalent) from this Windows-signed capsule using UEFITool or similar, without
corrupting the layout - Whether this extracted image would actually be usable for Insyde H2O’s offline
USB Crisis Recovery mode (I understand the boot-block-level crisis recovery
parser may expect a different structure than what Windows Capsule Update uses) - The correct crisis recovery key combination for this Insyde H2O implementation
on Lenovo LOQ 15IRX10 (I’ve seen Fn+Esc and Fn+B mentioned for other Insyde
platforms, unsure which applies here)
I have the full signed_R3.ROM file if anyone wants me to upload it for analysis.
Thanks in advance — trying to avoid bricking this further by guessing at the file
format.
Edit y Fernando: Thread title shortened
