[Problem] Bricked Lenovo ThinkBook 16p G5 IRX BIOS
Lenovo ThinkBook 16p G5 IRX (NM-F891) – Firmware Brick After Changing Hidden BIOS DDR5 JEDEC Write Leveling
Hello everyone,
I’m looking for some expert advice regarding what appears to be a firmware-level brick on my Lenovo ThinkBook 16p G5 IRX after modifying a hidden BIOS setting.
System Information
Laptop: Lenovo ThinkBook 16p G5 IRX
Motherboard: NM-F891
BIOS: InsydeH2O
Platform: Intel
Memory: DDR5 SO-DIMM
Graphics: Intel iGPU + NVIDIA RTX dGPU
What Happened
The laptop was working perfectly.
While exploring the hidden BIOS menus, I changed the JEDEC Write Leveling setting under the advanced memory configuration.
I saved the settings and rebooted.
Immediately afterward, the laptop stopped booting.
Symptoms:
No successful POST
Cannot enter BIOS
Normal CMOS reset methods did not recover the system
I do not remember the exact value that I selected.
Recovery Attempts
So far I have:
Cleared CMOS
Removed the CMOS battery
Disconnected the main battery
Performed power drain
Dumped every SPI flash chip with an external programmer
Backed up all original firmware
Extracted Lenovo’s official BIOS update
Compared firmware layouts
Used UEFITool
Used ME Analyzer
Used Intel FIT
My Main Question
Could changing JEDEC Write Leveling in an unlocked Insyde BIOS cause the firmware to store invalid DDR5 training parameters that prevent POST?
Specifically:
Does this setting map directly into Intel FSP-M UPD / MRC configuration?
Could invalid values be written into the UEFI Variable Store or MRC cache?
Would memory initialization fail before POST with no automatic recovery?
Is there any known Lenovo or Insyde behavior where hidden memory options bypass sanity checking?
Recovery Strategy
If this motherboard were on your repair bench, would you recommend:
Clearing the Variable Store only?
Removing the MRC cache?
Rebuilding the BIOS with FIT?
Replacing only the BIOS region while preserving board-specific data?
Reflashing EC firmware as well?
Any Lenovo-specific recovery procedure?
Files Available
I have:
Original SPI dumps of every flash chip
Official Lenovo BIOS update
Firmware analysis reports
If anyone is willing to analyze the dumps, I can upload them.
I’d really appreciate advice from anyone familiar with modern Lenovo Insyde firmware, Intel FSP/MRC, or DDR5 memory initialization.
Thank you!
Edit by Fernando: Thread title customized and shortened
Then you have NVRAM data that still persists your JEDEC attempts.
Try Lenovo official recover methods or re-program the firmware IC’s, using original dumps you may try to swap NVram volumes from Lenovo files…if only here the changes happened, if not a deep analysis/compare with UEFItool_NE and Hex editor is needed.
Thah’s all, good luck.
Thanks for the suggestion. I still have complete original dumps of the SPI chips taken before the issue occurred, as well as the official Lenovo BIOS package. The problem started immediately after changing the hidden JEDEC Write Leveling setting, and CMOS/EC resets did not clear it. I’ll compare the original dump with the Lenovo image in UEFITool NE and inspect the NVRAM/variable stores first. If the setting isn’t stored there, I’ll continue comparing other firmware volumes such as any memory-training or MRC-related regions. Thanks for pointing me in that direction.
