i have buy a thinkpad t470, with a admin password on the bios, i have use a as programmer to read 2 time the bios chip, verify both reading are the same, and put lenovo_auto_patcher_0.2 to remove the admin password.
Now i want to put back one of the two reading on the bios chip, but i can’t acces the bios, i try a bunch of software, neoprogrammer, as programmer, the one on this forum, but nothing work, when just the plug the ch341a on my computer i see Current programmer: CH341a IC not responding
and when i plug the clip on the chip, and click on detect, i have two issue, one the software just freeze and need to reboot the pc in order to close it (task manager is not enought)
or two Connecting Error CH341(Not found) Connecting Error CH341(Not found) Connecting Error CH341(Not found) Connecting Error CH341(Not found) IC not responding
Edit by Fernando: Thread title specified and customized
EDIT: “i have use a as programmer to read 2 time the bios chip, verify both reading are the same”
My understanding is that you had successfully connected and used the CH341A for these readings, so you now have a damaged IC or Programmer… logic?
Does anyone have LenovoTranslateService.ffs extracted from an L14 Gen1 BIOS dump?
I’m trying to run the Auto-Patcher on a Lenovo ThinkPad L14 Gen1 (Intel, model PF2L36SP). The BootOption.ffs GUID (e0746c42-d3f9-4f8b-b211-1410957b9ff5) injects fine, but the LenovoTranslateService.ffs GUID (826bcf56-bac4-43f4-8ea1-8cdf0a121abd) from the patch folder doesn’t exist anywhere in my dump — confirmed via GUID search in UEFITool, zero hits. This looks like a firmware revision mismatch rather than a corrupted dump.
If anyone has a clean L14 Gen1 BIOS dump, could you extract and share LenovoTranslateService.ffs (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd) via UEFITool/UEFIExtract? That would let me try patching with a matching driver.
