Hi all,
I’m trying to update my wyse 5060. There’s no update functionality built into the bios and no clear way to update the bios without thin client management tools.
I was able to backup the existing bios (wyse5060_Orig_bios_1.0F) using the CH341A. But when i try to flash the new bios (D10Q_bios downloaded from dells website) the image is too big for the flash chip. How can I remove the un-needed padding/images from the new bios file?
Attached are both files in the zip.
Thanks.
Edit by Fernando: Thread title specified and customized
bios.zip (5.78 MB)
Hi there,
Can you please teach me how to backup existing bios using the CH341A on 5060?!
I updated the BIOS using "ThinLinux_5060_BIOS_10K.zip" with Dell USB Imaging Tool but onboard speaker/heahphone jack stopped working and now sounds only comes through DP/HDMI as if the other output is completely absent!!
There is a guide online to flash it: https://www.parkytowers.me.uk/thin/wyse/zd_bios/ch341a.shtml
Click the tabs at the top there is a guide for flashrom it has additional details. I attached my bios backup I made (version 1.0F).
Make sure you are able to backup your current bios with the programmer before you flash this one just in case.
wyse5060_Orig_bios_1.0F.zip (2.78 MB)
