[Problem] Change Max Value in Bios Menu Ami Aptio V
Hello,
i need help for change max value in some setting in the bios menu Ami Aptio V:
Example:
Numeric Prompt: “”, Help: “”, QuestionFlags: 0x0, QuestionId: 0x23C, VarStoreId: 0x38, VarOffset: 0x17F2, Flags: 0x11, Size: 16, Min: 0x0, Max: 0x1F, Step: 0x1 { 07 …..
Using ifr-Extractor the is “tipical” string in the bios, with Max: 0x1F (31) , i want change this value to 40 (0x28) so that in the bios menu I can set 40.
It Possible?
Very Thanks a lot for any suggestions.
