Hi everyone,
I’m currently deep into a project involving a CheckPoint 19200-Plus appliance (Intel Whitley platform, Dual Xeon Silver 4316 Ice Lake-SP). I’m trying to turn this network beast into a high-density AI workstation and Media Server.
The Current Setup & Problem:
Right now, I am using an ADT-Link R73B (OCP 3.0 to PCIe x16) to run an external RTX 5070 Ti. While it works, the R73B is a nightmare in this 2U chassis. It’s too wide, blocking adjacent slots and completely ruining the internal airflow tunnel required for the Xeons.
Furthermore, the board features 5x MCIO x8 ports, but they are currently “dead.” No matter what I plug in (NVMe controllers, USB cards via adapters), nothing is detected. I suspect these ports are either disabled in the proprietary firmware or tied to specific IIO stack policies that I haven’t fully cracked yet.
Technical Progress so far:
Resizable BAR: Successfully patched the BIOS to support ReBAR for the RTX 50-series.
Bifurcation: I’ve dumped the IFR and identified the SocketIioConfig store (GUID: DD84017E-7F52-48F9-B16E-50ED9E0DBE27). I’m currently using setup_var to force x4x4x4x4 on the IIO stacks, but the firmware likes to auto-revert on some ports.
Has anyone successfully enabled the MCIO ports on these CheckPoint Whitley boards? Is there a specific “Presence Detect” or “VMD” magic setting I’m missing?
Thanks,
Mike
Edit by Fernando: Thread title shortened and customized
