[Problem] Corrupted Asus Rog Ally BIOS
Hi everyone,
I recently bought Asus Rog Ally which I suspect has a corrupted BIOS.
When I turn it on, it gets stuck on the ASUS logo. The RGB rings around the analog sticks keep changing colors, but nothing else happens, even after waiting several minutes. I’m also unable to enter the BIOS.
I desoldered Winbond BIOS chip, connected it to a CH341A programmer using 1.8V adapter and read BIOS from my IC three times using NeoProgrammer. Each read produced the same CRC value.
Could someone please take a look at my BIOS dump and check whether it appears to be corrupted? If possible, I would also appreciate some help restoring or creating a valid BIOS image.
Here is a link to my BIOS dumps: Download ally_orig_1.bin | LimeWire
Best regards,
Kuba
Hi, The SPI image isn’t original. If this ain’t work, post the SN. RC71L-BIOS-V343
Thanks for the V343 image!
Unfortunately it didn’t solve the problem. What I did and what I see:
  • Flashed RC71L-BIOS-V343.bin with CH341A + 1.8V adapter (erase, write, verify, readback hash matches the file)
  • Resoldered the chip and assembled the board
  • Symptoms are the same as before: ROG logo, joystick LEDs cycling, no BIOS access
  • Current draw around 2.4 A at 20 V, the APU heatsink gets very hot, and after a few minutes it shuts down
As you asked, here is the SN: R8NVKD024842329.
If you could prepare an image with my SN, I’d really appreciate it.
Thanks a lot!
To do that, you need to scan the QR code on your motherboard and post what it says.
Oh, sorry. Here is what’s on the QR code:
C7G38M20870
R832NVKD000RD4MB
RC71L
60NV0GY0-MB1510
210
If your issue isn’t hardware-related. RC71L-BIOS-V330+DMI
Thank you Sparo for your help. I just reflashed my chip with BIOS v330 from you and unfortunately console doesn’t turn on at all. Based on meter, it just charges a battery but doesn’t react to power button. Do you think it could be because of older version of the BIOS?
Version shouldn’t matter. Latest is V343; here’s the oldest: RC71L-BIOS-V322
