[Problem] CPU temp. -55° C after awaking from Windows sleep mode
Hello everyone! I’ve recently started experiencing a strange anomaly. After going into sleep mode, I take a break (for example, to drink some water or something), but when I wake up my PC (Windows) from sleep mode, my processor temperature is -55°C and doesn’t change. The processor fan (PWM) starts spinning at 985 RPM and doesn’t change with the load. After this, I realized the problem wasn’t software (HWiNFO) but something deeper. My Gigabyte GA-H110-D3A motherboard has a modified BIOS (CoffeeTime 0.99), but the problem appeared recently and suddenly. Previously, the problem didn’t exist even with a modified BIOS, but now it’s appeared, and I don’t know why. Intel PTT technologies also don’t work properly. Perhaps my ME didn’t fully integrate with the modified BIOS. I remember the last time I had a modified BIOS, it was 0.9 CoffeeTime. Then I switched to version 0.99, but I’m not sure if they’re very different, so it probably doesn’t make sense. If anyone else has had this problem and you’ve resolved it, please help me too :heart:
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title customized
@fikalis
Welcome to the Win-Raid Forum!
A measured CPU temperature of -55°C while running the computer cannot be true.
You should ask the developer of the tool HWInfo64 for an explanation. Maybe the data means “up to 55°C”.
This is due to mod bios files not properly handled and/or old AMIBCP modifications and/or internal oPROMS/DXE version applied, it’s a known issue on users who “touch” too much where they shouldn’t.
Go back to official bios release and you can confirm yourself.
Sir, if I go back to stock, my Xeon E-1270 v6 won’t work.
PTT shouldn’t have worked in the first place since you need to disable ME in order to run the Xeons. Why don’t you try to mod the BIOS once again and flash to see if it makes any differences?
I think I found a solution! I simply disabled fast startup in the BIOS, and the problem hasn’t recurred for three days now. I tested it for a long time, then put it into sleep mode, and everything was fine in the end. If anyone else has encountered this problem, just disable fast boot in the BIOS, and it should go away :melting_face:
