My laptop have shutdown problem for servel months, I searched for different methods(reintall Win10 system, clean cooling system etc.) to try, all failed.
Finally found this forum last month, read almost all ME releated posts, I’m sure 30 minutes is caused by ME disabled.
And I know need to do a ME clean, Below is what I have done.
1.Run Meinfo -verbose, appears ME disabled, means Me is corruptted, I think.
Intel(R) MEInfo Version: 11.8.90.4052
Copyright(C) 2005 - 2020, Intel Corporation. All rights reserved.
Windows OS Version : 10.0
Table Type 103 ( 0x 67 ) found, size of 0 (0x 00 ) bytes
Table Type 22 ( 0x 16 ) found, size of 134 (0x 86 ) bytes
Table Type 218 ( 0x DA ) found, size of 247 (0x F7 ) bytes
Table Type 218 ( 0x DA ) found, size of 85 (0x 55 ) bytes
Table Type 0 ( 0x 00 ) found, size of 52 (0x 34 ) bytes
Table Type 1 ( 0x 01 ) found, size of 80 (0x 50 ) bytes
Table Type 2 ( 0x 02 ) found, size of 82 (0x 52 ) bytes
Table Type 3 ( 0x 03 ) found, size of 75 (0x 4B ) bytes
Table Type 8 ( 0x 08 ) found, size of 25 (0x 19 ) bytes
Table Type 9 ( 0x 09 ) found, size of 23 (0x 17 ) bytes
Table Type 10 ( 0x 0A ) found, size of 44 (0x 2C ) bytes
Table Type 11 ( 0x 0B ) found, size of 173 (0x AD ) bytes
Table Type 12 ( 0x 0C ) found, size of 15 (0x 0F ) bytes
Table Type 21 ( 0x 15 ) found, size of 9 (0x 09 ) bytes
Table Type 32 ( 0x 20 ) found, size of 22 (0x 16 ) bytes
Table Type 34 ( 0x 22 ) found, size of 19 (0x 13 ) bytes
Table Type 26 ( 0x 1A ) found, size of 29 (0x 1D ) bytes
Table Type 28 ( 0x 1C ) found, size of 29 (0x 1D ) bytes
Table Type 27 ( 0x 1B ) found, size of 30 (0x 1E ) bytes
Table Type 29 ( 0x 1D ) found, size of 27 (0x 1B ) bytes
Table Type 39 ( 0x 27 ) found, size of 184 (0x B8 ) bytes
Table Type 41 ( 0x 29 ) found, size of 26 (0x 1A ) bytes
Table Type 7 ( 0x 07 ) found, size of 29 (0x 1D ) bytes
Table Type 4 ( 0x 04 ) found, size of 186 (0x BA ) bytes
Table Type 16 ( 0x 10 ) found, size of 25 (0x 19 ) bytes
Table Type 17 ( 0x 11 ) found, size of 113 (0x 71 ) bytes
Table Type 19 ( 0x 13 ) found, size of 33 (0x 21 ) bytes
Table Type 221 ( 0x DD ) found, size of 35 (0x 23 ) bytes
Table Type 14 ( 0x 0E ) found, size of 14 (0x 0E ) bytes
FW Status Register1: 0x80032004
FW Status Register2: 0x30840106
FW Status Register3: 0x00000420
FW Status Register4: 0x00084200
FW Status Register5: 0x80000113
FW Status Register6: 0x00400B48
CurrentState: Disabled
ManufacturingMode: Disabled
FlashPartition: Valid
OperationalState: Transitioning
InitComplete: Initializing
BUPLoadState: Success
ErrorCode: Disabled
ModeOfOperation: Temporary Disable mode
SPI Flash Log: Not Present
FPF HW Source value: Not Applicable
ME FPF Fusing Patch Status: ME FPF Fusing patch NOT applicable
Phase: BringUp
ICC: Valid OEM data, ICC programmed
ME File System Corrupted: No
PhaseStatus: UNKNOWN
FPF and ME Config Status: Not committed
Error 86: Communication error between application and Intel(R) ME module (FWU client)
Error 81: Internal error (Could not determine FW features information)
C:\Users\Wangs\Desktop\ME_new\CSME System Tools v11 r43\MEInfo\WIN64>
2.Unlock FD by pinmod, run FPT -d dump spi image.
3.Run FIT, Followed the Clean Guide D4 step by step(skipped step7&13), make a cleaned spi image.
4.As there’s a bios protection, can’t write to it. Extract me region with UEFITool, then run fpt -me -f make a re-flash for ME region, Followed -greset.
Move all power for 1 minutes, then boot.
But nothing changed, ME still disabled, 30 minutes shuwdown not gone.
All attempt failed, I can’t find out what is wrong in it. So frustrated now.
Attached dumped SPI image and cleaned image, want ask a help to check.
I’ll be much appreciated, thank you!
BTW, I bought a programmer this week, can use it if necessary.
spi_dump.rar (4.51 MB)
spi_clean.rar (4.35 MB)
