[Problem] Dell R720xd iDRAC BIOS Recovery
Hi,
I checked the pinout for the said chip, and have a lookout for the seven unpopulated pads near the text U_NAND.
Seems like they are connected to pins 4-6 (these are NC according to datasheet), 10 (NC), 12 (VCC!), 14 (NC) and 15 (NC).
There might, or might not be, power supplied to the chip? there’s a VIA on the chip side, so it might have power. Worth checking though.
So the working one will crash within lifecycle controller for some reason, but other than that it works. I will try to reset/clear NVRAM etc.
Not looking at the time debugging, but taking it apart, in-place-dump emmc, fetch the enterprise-license, desolder emmc, solder emmc, but it all back together and verify if it works or not - this will take 2-3 hours.
Debugging is another thing, and the purchase of parts and supplies that I didn’t have from before. Was it worth it, as replacements are available for ~200e on eBay? depends on how you value your time.
Taking debugging, file digging (for the license) into account - not to mention if a reball is required on the new emmc - a LOT of hours were spent.
Also, as bootleg license CAN be bought for as much as ~33e on eBay, how much is your time worth digging THAT info?
No dice on using the TSOP :(. I put a TSOP memory package on and I get the same error.
<br />iDRAC7=&gt; mmcinfo<br />sh_mmcif: Cmd(d'1) err<br />Card did not respond to voltage select!<br />
Anyone know if there is a switch to make the switch to using the TSOP? I tried to short a couple of the jumpers I saw around the NAND/MMC chip but no dice :(. Same result as above. Without have a diagram of the board I don’t think there is anything else I can do.
Right. I changed the eMMC on a failed R630, but it does NOT attempt recovery from SD-card. Here’s the console output:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
U-Boot 2009.08 (Apr 25 2019 - 04:38:23) Avocent (0.0.3) EVB
CPU: SH-4A
BOARD: R0P7758LC00xxRL (A0 step) board
BOOT: Secure, HRK generated
DRAM: 240MB
(240MB of 256MB total DRAM is available on U-Boot)
ENV: Using primary env area.
Undefined env fwu_act
Undefined env Failsafe_PowerON_Lockout
Undefined env wdt2cnt
Undefined env cpld_recover_cnt
Undefined env ddr_recover_cnt
Restore env FWN=0x2f08a6_0x1ed85be6,0x68e1000_0xd0b3f90f,0x6db9c_0x6c7446cf,0x139000_0xf354cdb9
Restore env FWN1=0x2f0578_0xad6f2291,0x6513000_0xcbf6bece,0x6db9c_0x7bb8b363,0x132000_0x950fec8d
Restore env etherc0=B8:2A:72:FC:53:48
Restore env getherc0=B8:2A:72:FC:53:49
Restore env first_ac=yes
Restore env ethaddr=B8:2A:72:FC:53:48
Restore env eth2addr=B8:2A:72:FC:53:49
Restore env macs_in_res1=yes
Restore env ethact=sh_g_eth.0
Restore env dmn=disabled
Restore env wdt0cnt=3
In: serial
Out: serial
Err: serial
PCIe: Bridge loaded with 0x18000 bytes
WDT2: Booted Lower Vector, 'uboot1'
sh_mmcif: 0, sh-sdhi: 1
Net: sh_eth.0, sh_g_eth.0
INFO: 00:002 Start-up -to- util_idrac_main()
INFO: 00:004 U-Boot 2009.08 (Apr 25 2019 - 04:38:23) Avocent (0.0.3) EVB
INFO: 00:007 U-Boot checkin date(10-04-2018) Version(1.1.34)
INFO: 00:006 iDRAC PPID <NULL>
INFO: 00:003 SPI NOR init 4096 KiB MX25L3206E bus=0 cs=0, speed=1000000, mode=3
INFO: 00:007 SH-4A Product: Major Ver=0x31 Minor Ver=0x20 D0 Little endian
Family=0x10 Major Ver=0x30 Minor Ver=0x0b
INFO: 00:139 BCM54610 OUI=0x00d897 Model=0x26 Revision=0x0a PhyAddr=1
INFO: 00:007 Dedicated monolithic mgmt NIC disabled
INFO: 00:214 SD CARD: Device: sh-sdhi Manufacturer ID: 74 OEM: 4a45
Name: SDC Tran Speed: 25000000 Rd Blk Len: 512
SD ver 2.0 HC: Yes cap(<2gb): 4025483264 cap(>2gb): 0
ext_rev: 0 rst_n: 0 ext[96]: 0
INFO: 00:139 EMMC: Device: sh_mmcif Manufacturer ID: 90 OEM: 14a
Name: H4G1d Tran Speed: 25000000 Rd Blk Len: 512
MMC ver 4.0 HC: Yes cap(<2gb): 0 cap(>2gb): 7634944
ext_rev: 6 rst_n: 1 ext[96]: 0
INFO: 00:024 CPLD: Major Ver=0x1 Minor Ver=0x0 Maint Ver=0x1
Planar: Type=0x58 Rev=0x9 Rework=0x0 Scratch/PathRetry=0x00
PASS: 00:014 Coin cell detected good, AD=0x3a6 low water=0x2c1
PASS: 00:008 PCIe SH7758_A0 Ver=0.03 MCTP en, CRC=0x70ae6992 @0x8efd54f4 cnt=0x18000
INFO: 00:008 Init PCIe mailbox(PCIe 0xFFEE0150=0x40010000)
INFO: 00:005 mode=normal
INFO: 00:003 reset_cause=ac
PASS: 00:004 Booted Lower Vector, 'uboot1' wdt2cnt=0
INFO: 00:006 wdt0cnt=3 cpld_recover_cnt=0 ddr_recover_cnt=0
PASS: 00:006 Clear CH1/CH2, clear 4K shared memory@0xffcaa000 on AC power up
PASS: 00:007 SMR0 no sermux env, default 0xd4
INFO: 00:005 GRACR=0x3c HISEL=0x00 SIRQCR5_D=0x03 SIRQCR6_D=0x01 LADMSK0=0xff2
MRSTCR0=0xfedffe7f MRSTCR1=0xfff3ff0f MRSTCR2=0x6f80feff
BARMAP=0x1 BCR=0x85000000 NCER=0x01fc NCMCR=0x0006 NCCSR=0x0303
PASS: 00:021 etherc0=B8:2A:72:FC:53:48
INFO: 00:009 Fan logic for monolithic planar type 88
fan1 - def 0000 1fff 3d fan2 - def 0000 1fff 3d
fan3 - def 0000 1fff 3d fan4 - def 0000 1fff 3d
fan5 - def 0000 1fff 3d fan6 - def 0000 1fff 3d
fan7 - def 0000 1fff 3d fan8 - def 0000 1fff 3d
INFO: 00:077 Env and backup CRC'ed ok
Erasing SPI flash at 0x100000...Writing to SPI flash...done
Erasing SPI flash at 0x110000...Writing to SPI flash...done
INFO: 02:062 Sync eMMC/SPI NOR/Alternate u-boot images
FAIL: 00:261 U-boot 'ubootN' on path N failed CRC
U-boot2 in sync with u-boot1 1.1.34
FAIL: 00:122 Verify OS Images N: Kernel crc exp=0x1ed85be6 rec=0xc1ca96cb
blk_start=0x1 blk_size=0x0 ENV bcnt=0x2f08a6
PASS: 00:334 Boot device=emmc Boot partition5/N-1
Boot Path Retry:P1/N=3 P5/N-1=0 swapping to P5/N-1
INFO: 00:013 Sync eMMC/SPI NOR/Alternate u-boot images
FAIL: 00:261 U-boot 'ubootN1' on path N-1 failed CRC
FAIL: 00:122 Verify OS Images N-1: Kernel crc exp=0xad6f2291 rec=0x26d1d5ba
blk_start=0x40002 blk_size=0x0 ENV bcnt=0x2f0578
FAIL: 00:013 Boot device=emmc Boot partition5/N-1
Boot Path Retry:P1/N=3 P5/N-1=3 P5/N-1 now expired
INFO: 00:000 03:924
OS_WDT0_EN:180 seconds, Re-load ILRAM:
SPI_WP: Successful.
EMMC_WP: Successful.
Boot Path Retry:P1/N=3 P5/N-1=3 Recover
*** fail to boot image ***
Unable to boot, disable wdogs -- HALTING
What format is your SD-card (fat/fat32/ntfs/ext4)?
What did you write to the SD-card?
You are working with a Dell R730, this thread is mostly about R720 or Rx20 family machines, so I do not know if the R730 has the sd recovery stuff in it, or if any requirements about getting it to do image recovery have changed.
Hello All! I replaced eMMC on my DELL r720 twice, but u-boot and mmcinfo say "Card did not respond to voltage select!". What can be wrong? I tested eMMC with external programmer, they are good. When I replace it, i do not prepare new eMMC, just soldered it on the motherboard. May be I should copy partition from original emmc? eMMC is same model (H26M31001FPR).
Card did not respond to voltage select! -> it’s not completely soldered on board.
Be sure to preheat the board as well
I soldered with preheat, same result.
Console log:
pastebin.com/szi3Jh21
I copied old bad eMMC to new eMMC, No luck. But u-boot trying to read partition.
May be I need fwu update command?
Looking at your console log its defanitly having issues talking to your emmc chip, this line: sh_mmcif: Cmd(d’1) err is certainly fatal when it is trying to initialize the emmc. Do you know what this all looked like before you tried to replace the chip?
rgrimes, before replace I have this log:
pastebin.com/kxSm2dDi
alucard666 the before replacement shows that it probed the EMMC and found it fine, but later had read errors. The after replacement can not even find the device any longer, so something went rather wrong with your chip replacement is about all I can conclude.
Hi,
I’ve been reading through this thread a couple of times and found it again everytime I was looking up the error message I’ve got. So far you have already helped me a lot with the console. Maybe you can help me out or put the final nail in the coffin of my R720xd I just got for free.
Thanks to you I am able to access the console. This is what I get.
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
U-Boot 2009.08-00063-g1de9cb8 (Mar 11 2014 - 04:53:42) Avocent (0.0.3) EVB, Build: jenkins-idrac-yocto-release-467
CPU: SH-4A
BOARD: R0P7757LC00xxRL (C0 step) board
DRAM: 240MB
In: serial
Out: serial
Err: serial
INFO: 00:004 U-Boot 2009.08-00063-g1de9cb8 (Mar 11 2014 - 04:53:42) Avocent (0.0.3) EVB
INFO: 00:009 U-Boot checkin date(05-10-2013) Version(1.0.183)
INFO: 00:005 iDRAC PPID <NULL>
INFO: 00:008 SH-4A Product: Major Ver=0x31 Minor Ver=0x14 C4 Little endian
PASS: 00:015 Dedicated monolithic mgmt NIC disabled
INFO: 00:129 BCM54610 OUI=0x3fffff Model=0x3f Revision=0x0f PhyAddr=1
INFO: 00:156 SD CARD: Device: sh-sdhi Manufacturer ID: 41 OEM: 3432
Name: DELL1 Tran Speed: 25000000 Rd Block Len: 512
SD version 2.0 High Capacity: Yes Capacity: -423624704
mmc read failed
** Can't read Driver Desriptor Block **
CPU: SH-4A
DRAM: 240MB
ENV: Skip env_relocate() on Alternate boot
In: serial
Out: serial
Err: serial
WDT2: Booted Upper Vector, copy 'uboot2' to alternate vector 'uboot1'
CPU: SH-4A
DRAM: 240MB
In: serial
Out: serial
Err: serial
INFO: 00:008 U-Boot checkin date(05-10-2013) Version(1.0.183)
INFO: 00:007 SH-4A Product: Major Ver=0x31 Minor Ver=0x14 C4 Little endian
PASS: 00:016 Dedicated monolithic mgmt NIC disabled
INFO: 00:128 BCM54610 OUI=0x3fffff Model=0x3f Revision=0x0f PhyAddr=1
sh-sdhi: Cmd(d'115) err
sh-sdhi: cmdidx = 51
INFO: 00:153 SD CARD: Device: sh-sdhi Manufacturer ID: 6 OEM: 0
Name: 16&#65533;&#65533;&#65533; Tran Speed: 25000000 Rd Block Len: 512
SD version 2.0 High Capacity: No Capacity: 8192
mmc read failed
CPU: SH-4A
DRAM: 240MB
In: serial
Out: serial
Err: serial
CPU: SH-4A
DRAM: 240MB
In: serial
Out: serial
Err: serial
mmc read failed
I've seen messages in this thread that look like this error, but I don't get a timeout for instance, it just loops.
I am able to reboot using the SW_IDRAC_DBG pads A1-B1, but I can't abort the boot using A2-B2.
Is there a chance iDRAC can be fixed?
@vqu you should poweroff and unplug the system from power, short a2/b2 and leave them shorted, then power on the system. See if that gets you to uboot prompt. I can tell from your messages you appear to have a rather serious mmc problem. Has some rework attempt been done to this board?
I just powered the server with A2 B2 shorted, no change. The output is exactly the same.
I was the first one to do anything to the board when I soldered the UART pins. It was running for 1994 days when I shut it off due to a failed iDRAC.
@vqu is there an SD card in one of the slots? If so try to remove that. To me these message look like maybe an sd card is failing to init.
There is a vflash SD card in the back of the server and two cards in the idsdm module. The message stayed the same no matter what card I removed or swapped. Even removing the idsdm module didn’t change anything.
@vqu Try removing ALL sd cards, format a fat32 sd card 16g or smaller, don’t put any files on it, and put it in the FRONT sd card slot. I want to see if the idrac can infact find and read the directory from the front sd card. This should certainly change the boot messages if things are getting that far.
Unfortunately I can’t format fat32 on my mac. I reformatted two 8GB Dell vFlash cards and two 1GB SD cards, that were used in the IDSDM before, using exFAT. Then I tried every card in the SD slot in the back (there is no slot in the front). The message is the same with every card.
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
CPU: SH-4A
DRAM: 240MB
In: serial
Out: serial
Err: serial
INFO: 00:002 SPI NOR init 4096 KiB MX25L3206E bus=0 cs=0, speed=1000000, mode=3
INFO: 00:179 SD CARD: Device: sh-sdhi Manufacturer ID: 41 OEM: 3432
mmc read failed
CPU: SH-4A
DRAM: 240MB
In: serial
Out: serial
Err: serial
CPU: SH-4A
DRAM: 240MB
In: serial
Out: serial
Err: serial
INFO: 00:003 Start-up -to- util_idrac_main()
mmc read failed
Of course I get "SD CARD: is not found" when there is no card.
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
CPU: SH-4A
DRAM: 240MB
In: serial
Out: serial
Err: serial
INFO: 00:006 SD CARD: is not found
mmc read failed
CPU: SH-4A
DRAM: 240MB
In: serial
Out: serial
Err: serial
CPU: SH-4A
DRAM: 240MB
In: serial
Out: serial
Err: serial
INFO: 00:007 SD CARD: is not found
mmc read failed
Mmc read failed -> Either replace system board or emmc.
I do not believe the idrac can read exFat, please use FAT32 or extfs3.
Will give it a last chance with ext3.
If ext3 won’t work I will sacrifice an R320 and let it donate it’s emmc to the R720xd.
