Hello, guys! What an amazing work you’ve done here! Wish I read these before deciding to upgrade my r720’s iDRAC from 1.35.35 to 2.10.10.
Anyway I got this UART output. Seems like partition table is corrupted.
So it sees SD card (on which I copied firmimg.d7).
What could I do? Maybe I should try to write a bootable image on SD card? Or try to interrupt booting with A2-B2 shortage?
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
U-Boot 2009.08-00088-g121cddc (Nov 17 2014 - 05:50:46) Avocent (0.0.3) EVB, Build: jenkins-idrac-yocto-release-505
CPU: SH-4A
BOARD: R0P7757LC00xxRL (C0 step) board
BOOT: Secure,
sh_mmcINFO: 00:002 Start-up -to- util_idrac_main()
INFO: 00:005 U-Boot 2009.08-00088-g121cddc (Nov 17 2014 - 05:50:46) Avocent (0.0.3) EVB
INFO: 00:008 U-Boot checkin date(05-10-2013) Version(1.0.FO: detect2CIe C0 Ver=0.15 MCTP en, x8e9b6875 @0x8efbf954 cnt=0x18000
INFO: 00:007 Init PCIe mailbox(PCIe 0xFFEE0150=0x40010000)
INFO: 00:006 m 04:829 Write trace buf mem@0x83000000 to SPI NOR@0x140000 for 0x80000
PASS: 00:008 Booted Lower Vector, 'uboot1' wdt2cnt=0
INFO: 00:005 wdt0cnt=0
PASS: 00:002 SMR0 no sermux env, default 0xd4
INFO: 00:004 GRACR=0x3c HISEL=0x00 SIRQCR5_D=0x03 SIRQCR6_D=0x01 LADMSK0=0xff2
:8E
INFO: 00:007 Fan logic is not modified on Non-AC power up
00:052 Env and backup CRC'ed ok
*** no text signature found ***
INFO:FO: 00:000 10:607
WDT2: Disabled
Initialization complete, proceed with boot
OS_WDT0_EN:180 seconds, Re-load ILRAM:
OK
## B 88000age Name: ssh_eth_init
Monolithic/DRB
init started: BusyBox v1.18.4 (2014-11-17 05:25:30 CST)
starting pid 409, tty '': '/etc/init.d/rcS'
waitfor:409 ...
Fri Dec 31 xecute command __source /etc/sysapps_script/I_1170_mknode.sh__
Fri Dec 31 18:00:06 CST 1999 To execu7.79 0.02
/etc/sysapps_script/syslog.sh: /sbin/aim not running
Dec 31 18:00:09 (none) kernel: klogd 1.4.2, log source = /proc/kmsg started.
Dec 31 18:00:09 (none) kernel: Cannot find map file.
Dec 31 18:00:09 (none) kernel: No module symbols loaded - kernel modules not enabled.
Dec 31 18:00:09 (none) kernel: cannot find any symbols, turning off symbol looku ...kernel: ... ORIG_ROOT_DEV - 00000000
Dec 31 18:00:09 (none) kernel: ... LOADER_TYPE - 00000000
Dec 31 18:00:0ernel: ... INITRD_START - 00000000
Dec 31 18:00:09 (none) kernel: 09e) kernel: 0: 0x00040000 -> 0x0004ea00
Dec 31 18:00:09 (none) kernel: On node 0 totalpages: 59904
Dec 31 18:00:09 (none) kernel: free_area_init_node: node 0, pgdat 8049539c, node_mem_map 804fa000
Dec 31 18:00:09 (none) kernel: Normal zone: 468 pages used for memmap
Dec 31 18:00:09 (none) kernel: Normal zone: 0 pages reserved
Dec 31 18:00:09 (none) kernel: Normal zone: 59436 pageO batch:15
Dec 31 18:00:09 (none) kernel: Built 1 zonelists in Zone order, mobility grouping dev/mmcblk0p2 rootwait rw rootfstype=squashfs mem=239616k console=ttyS2,115200 <NULL> mac1=78:45:C4:F3:00:8D mac2=78:45:C4:F3:0R_IRQS:384
Dec 31 18:00:09 (none) kernel: PID hash table entries: 1024 (order: 10, 4096 bytes)
Dec 31 18:hetries: 16384 (order: 4, 65536 bytes)
Dec 31 18:00:09 (none) kernel: PVR=10300b00 CVR=410 PRR=00003113
Dec 31 18:00:09 (none) kernel: I-cache : n_iases=2
Dec 31 18:00:09 (none) kernel: D-cache : n_ways=4 n_sets=256 way_incr=8192
Dec 31 18:00:09 (none) kernel: D-cache : entry_mask=0x00001fe0 alias_mask=0x00001000 n_aliases=2
Dec 31 18:00:09 (none) krnel: Memory: 232192k/239616k available (3484k kernel code, 1209k data, 156k init)
Dec 31 18:00:09 (none) kerCalibrating delay loop... 230.19 BogoMIPS 150976)
Dec 31 18:00:09 (none) kernel: Security Framk initialized
Dec 31 18:00:09 (none) kernel: Mount-cache hash table entries: 512
D: net_namespace: 980 bytes
Dec 31 18:00:09 (none) kernel: PCI: Using configuration type 1
Dec 31 18:00:09 (none) kernel: NET: Registered protocol family 16
Deckernsh pinmux: sh7757_pfc handling gpio 0 -> 504
Dec 31 18:00:09 (none) kernel: bio: crslab <bio-0> at 0
Dec 31 18e drevice driver usb
Dec 31 18:00:09 (none) kernel: DMA: Registering sh_dmac handler (24 channels).
Dec 31 18:00:09 (none) kernel: Autoconfig PCI channel 0x8048e8f4
Dec 31 18:00:09 (none) kernel: Scanning bus 00, I/O 0xfedhash table entries: 8192 (order: 4, 65536 bytes)
Dec 31 1tries: 8192 (order: 3, 32768 bytes)
Dec 31 18:00:09 (none) kernel: TCP: Hash tables configured (established 8192 bind 8192)
Dec 31 18:00:09 (none) kernel: TCP reno registered
Dec 31 18:00:09 (none) kernel: Switched to high resolution mode on CPU 0
Dec 31 18:00:09 (none) kernel: planar_id: id 2
Dec 31 18:00:09 (none) kernel: enable PCIe shared memory area
Dec 31 18:00:09 (none) kernel: audit: initializing netlink socket (died)
Dec 31 18:00:09 (none) kernel: type=2000 audit(946684800.310:1): initialized
Dec 31 18:00:09 (none) kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
31 18:00:09 (none) kernel: JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
Dec 31 18:00:09 (l: fuse init (API version 7.11)
Fri Dec 31 18:00:09 CST 1999 To execute command __source /etc/sysapps_script/I_trab_asdf.sh__
Dec 31 18:00:09 (none) kernel: msgmni has bee none) kernel: alg: o test for compress_null (compress_null-generic)
Dec 31 18:00:09 (none) kernel: alg: No test for stdrng (krng)
Dec 31 18:00:09 (none) kernel: io scheduler noop registered
Dec 31 18:00:09 (none) kernel: io sch registered
Decheduler deadline registered (default)
Dec 31 18:00:09 (nones
00000, 00:00:00:00:00:00, IRQ 315.
Dec 31 18:00:09kernel: sh_spi sh_spi.0: registered master spi0
Dec 31 18:00:09 (none) kernel: m25p80 spi0.1: mx25l3205d (4096 Kbytes)
Dec 31 18:00:09 (none) kernel: Creating 9 MTD partitions on "m25p80":
31 18:00:09 (none) kernel: 0x000000000000-0x000000080000 : "u-boot1"
Dec 31 18:00:09 (none) kernel: 0x000000080000-0x000000100000 : "u-boot2"
Dec 31 18:00:09 (none) kernel: 0x000000100000-0x000000110000 : "env1"
Dec 31 18:00:09 (none) kernel: 0x0110000-0x000000120000 : "env2"
Dec 31 18:00:09 (none) kernel: 0x000000120000-000 : "fru"
Dec 31 18:00:09 (none) kernel: 0x000000130000-0x000000140000 : "res1"
De0340000 : "lcl"
Dec 31 18:00:09 (none) kernel: 0x000000340000-0x000000400000 : "res2"
Dec 31 18:00:09 (none) kernel: sh_spi sh_spi.0: registered child spi0.1
10
Dec 31 18:00:09 (none) kernel: mknod /dev/aess_wdtdrv c 10 130
Dec 31 18:00:09 (nsermrmux: version 2010-05-26
Dec 31 18hid_init: Desc: Keyboard/Mouse Function
:00:09 (none) kehid_init: Name: g_kbdmouse
rnel: nf_conntrahid_init: Version: 20120917
ck version 0.5.0hid_bind: Using Major Number 232
(3744 buckets, hid_bind: using r8a66597_udc, Keyboard ep1 Mouse ep2
14976 max)
Dechid_bind: Mouse REL ep3
31 18:00:09 (none) kernel: IPv4 ove: NET: Registered protocol family 10
Dec 31 18:00:09 (none) kernel: lo: Disabled Privacy Exons
Dec 31 18:00:09 (none) kernel: tunl0: Disabled Privacy Extensions
Dec 31 18:00:09 (none) kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
De:09 (none) kernel: IPv6 over IPv4 tunndriver
Dec 31 18:00:09 (none) kernel: sit0: Disabled Privacy Extensions
Dec 31 18:00:09 (none) kernel: NET: Registered protocol family 17
Dec 31 18:00:09 (none) kernel: RPC: Regis(none) kernel: RPC: Registered tcp transport module.
Dec 31 18:00:09 (none) kernel: 802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
Dec 31 18:00:09 (none) kerns added by David S. Miller <[email protected]>
Dec 31 18:00:09 (none) kernel: registered taskstats version 1
Dec 31 18:00:09 (none) kernel: Waite) el: mmcblk0: mmc0:0001 HYNIX 3.60 GiB
Dec 31 18:00:09 (none) kernel: blk0: p1 p2 p3 p4 < p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 >
Dec 31 18:00:09 (none) kernel: mmc1: power on - 8e
Dec 31 18:00:09 (none) kernel: VFS: Mounted root (squashfs filesystem) readonly on device 179:2 156k freed
Decone) kernel: mmc1: non-Dell SD detected
Dec 31 18:00:09 (none) kernel: mmc1: new DHC card at address b368
Dec 31 18:00:09 (none) kernel: mmcblk1: mmc1:b368 SDC 30.2 GiB
Dec 31 18:00:09 (none) kernel: mmcblk1: p1
Dec 31 18:00:09 (none) kernel: kjournald starting. Commit ial journal
Dec 31 18:00:09 (none) kernel: EXT3-fs: recovery complete.
Dec 31 18:0(0 dead, 0 orphan) found.
Dec 31 18:00:10 (none) kernel: KN:init_aess_mem_module
Dec 31 18:00:10 (none) kemknod /dev/aess_gpiodrv c 250 0
Dec 31 18:00:ss_sgpiodrv c 249 0
Dec 31 18:00:10 (none) kernel: mknod /dev/aess_dynairqdrv c 248 0
D0:10 (none) kernel: IRQ 236/aess_dynairqdrv: IRQF_DISABLED is not guaranteed on shared IRQs
Dec 31 18:00:10 (none) kern8:00:10 (none) kernel: hwrng registration sucessed
Dec 31 18:00:10 (none) kernel: cbc(aes) ecb(aes) ecb(des3_ede) cbc(des3_ede) sha1 sha256 hmac(sha1) hmac(sha256) <6>
Dec 1 18:00:10 (none) kernel: mknod /dev/aess_fansnod /dev/vkcs c 240 0
Dec 31 18:00:10 (none) kernel: mknod /dev/aess_memdrv c 239 0
Dec 31 18:00:10 (none) kernel: mknod /dev/aess_spi1drv c 238 0
Dec 31 18:00:10 (none) kernel: mknod /dev/dell_cplddrv c 237 0
Dec 31 18:00:10 (none) kernel: mknoddrv c 236 0
Dec 31 18:00:10 (none) kernel: aess_rspi_init: isblade=0 val=0x2
Dec 31 18:00:10 (no 1800:10 (none) kernel: mknod /dev/sh_pbi c 233 0
Dec 31 18:00:10 (none) kernel: sh_pbi: 4kb Shared memoryRQ 320
Deec :10 (none) kernel: g_mass_storage: msd_i0 (none) kernel: g_mass_storage: msd_init() Name: g_mass_storage
Dec 31 18:00:10 (none) kernel: g_m0919
Dec 31 18:00:10 (none) kernel: Now registering e 18:00:10 (none) kernel: g_mass_storage2: msd_init() Desc: Mass Storage Function
Dec l: g_mass_storage4: msd_bind() Using Major Nu
waitfor: pid 409, wpid -1
SCSI subsystem initialized
Driver 'sd' needs updating - please use bus_type methods
Dec 31 18:00:12 (none) kernel: Driver 'sd' needs updating - please use bus_type methods
ss, the pid is 734!
13.55 0.04
(none) kernel: Initializing USB Mass Storage driver...
Dec 31 18:00:13 (none) kernel: usbcore: registered new intDec 31 18:00:13 (none) kernel: USB Mass Storage support registered.
usb drivers version: 1.1.0.3
Fri Dec 31 18:00:13 CST 199aess_video_init Avocent Video Driver installed
allocate_video_buffer ulEcc_enabled 0x00000000 ulEcd_clock_stop 0x00000000 ulMcr_ecc_enabled 0x00000001
allocate_video_buffer_dynamically- video_buffer_phys: 47000000 video_buffer_size: 0x00EAE000
Dec 31 18:00:13 (none) kernel: aess_video_init Avocent Video Driver installed
Dec 31 18:00:13 (none) kernel: allocate_video_buffer ulEcc_enabled 0x00000000 ulEcd_clock_stop 0x00000000 ulMcr_ecc_enabled 0x00000001
Dec 31 18:00:13 (ne comm __touch /flash/data0/o/maserinit__
18:EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended
Dec 31 18:00:14 (none) kernel: EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended
mv: cclogs: Read-only file system
Dec 31 18:00:15 (none) syslogd 1.4.2: restart.
Dec 31 18:00:15 (none) kernel: klogd 1.4.2, log source = /proc/kmsg started.
Dec 31 18:00:15 (none) kernel: Cannot find map file.
Dec 31 18:00:15 (none) kernel: No module symbols loaded - f symbSetting Debut ...
Debug Level set to: 1 (Critical)
Debug Source set to: 1024 (All Sources)
Debug Output set to: 2 (Rs))
Debug Extra Options set to: 0 (No Extra Options)
IPMI Trace Buffer Stopped
Generic Trace Buffer StIRQCR Write OK! -- SIRQCR_SELIRQ10 = 1
KCSSI 513 16384 83 Linux
Partition 1 does not end on 0 Empty
Partition 3 does not end on cylinder boundary
/dev/mmcblk0p4 4097 85184 2594815+ 5 Extended
Partition 4 does not end on cylinder boundary
/dev/mmcblk0p5 4097 4609 16384 83 Linux
/dev/mmcblk0p6 4609 8177 114176 0 Empty
/dev/mmcblk0p7 8177 8193 512 0 Empty
/dev/mmcblk0p8 8193 18433 327680 18689 18817 4096 83 Linux
/dev/mmcblk0p12 18817 63937 1443840 83 Linux
/dev/mmcblk0p13 lervalconds
Dec 31 18:00:16 (none) kernel: EXT3-fs warning: mounting fs with errors, running e2fsck is recommend : mounystem with writeback data mode.
done.
FreshAir Partition type = "ext2"
Checking FS Dec 31 18:00:16 (none) kernel: EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended
done.
done.
Fri Dec 31 18:00:16 CST 1999 To execute command __/etc/sysapps_script/S_1000_AIM.sh start__
h st
AMEA card is present or not
Read CPLD Offset 0x21 Bit 3
c 31 18:00:17 CST 1999 Toend_request: I/O error, dev mmcblk0, sector 1196698
end_request: I/O error, dev mmcblk0, sector 1196700
end_request: I/O error, dev mmcblk0, sector 1196702
end_request: Icblk0: retrying using single block read
sh_mmcif: Cmd(d'17) err
mmcblk0: error -84 sending read/write command, responmmcblrror -84 sending read/write command, response xd40
end_request: I/O error, dev mmcblk0, sector 524296
mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd40
end_request: I/O error, dev mmcblk0, sector 524297
end_requ4command, responsrequest: I/O error, dev mmcblk0, sector 524300
Buffer I/O error on device mmcblk0p8, logical block 0
sh_mmcif: Cmd(d9 (none) kernel: mmcblk0: error -84 sending read1 1end_request: mmcblk0: error -nding read/write command, response 0x0, card status 0xd40
I/O errormend_request: I/O error, dev mmcblk0, sector 524302
k0, sector 1sh_mmcif: Cmd(d'17) err
196670
Dec 31 18:00: kernel: end_request: I/O error, dev mmcblk0, sector 1196672
Dec 31 18:00:19 (none) kernel: end_request: I/O error, devmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd40
mmcblk0, sectorend_request: I/O error, dev mmcblk0, sector 524303
1196674
Dec 3sh_mmcif: Cmd(d'17) err
1 18:00:19 (none) kernel: end_request: I/O err966mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd40
78
Dec 31 18:0end_request: I/O error, dev mmcblk0, sector 524306
0:19 (none) kernsh_mmcif: Cmd(d'17) err
el: end_request:mmcblk0: error -84 se error -84 sending read/write command, response 0x0, card status 0xd00:19 (none)end_request: I/O error, dev mmcblk0, sector 524308
Buffer I, logical block 1
kernel: end_reqsh_mmcif: Cmd(d'17) err
uest: I/O error,mmcblk0: error -84 sendi read/write command, response 0x0, card status 0xd40
dev mmcblk0, seend_reerror, dev mmcblk0, sector 524309
ctor 1196682
Dsh_mmd(d'17) err
ec 31 18:00:19 (mmcblk0: error -84 sending rea 524310
d_request: , card status 0xd40
Dec 31 18:00:19end_request: I/O error, dev mmcblk0, sect312
(none) kernel: s:19 (none) kerend_request: I/O error, dev mmcblk0, sector 524314
nel: end_requestsh_mmcif: Cmd(d'17) err
: I/O error, devmmcblk0: error -84 sng read/write command, response 0x0, card status 0xd40
mmcblk0, sectorend_requogical block 2
quest: I/O errorsh_mmcif: Cmd(d'17) err
, dev mmcblk0, smmcblk0: response 0x0, card status 0xd40
ector 1196692
end_request: I/O error, dev 18:0end_request: I/O error, dev mmcblk0, sec cesponse 0x0, card status 0xd40
18:00:19 (none)end_request: I/O error, dev mmcblk0, sector 524321
uest: I/O error,mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd40
dev mmcblk0, seend_request: I/O error, dev mmcblk0, sector 524322
ctor 1196698
From run to run I see it different:
2
3
4
5
6
7
8
9
10
11
12
13
14
KCSSIRQCR Write OK! -- SIRQCR_IRQ10E2 = 1
rs
ition 1 does not end on cylinder b 4097 85184 2594815+ 5 Extended
/dev/mmcblk0p7 8 8193 512 0 Empty
/dev/mmcblk0p8 8193 18433 327680 0 Empty
/dev/mmcblk0p9 18433 18561 4096 0 Empty
/dev/m 1868 4096 0 Empty
/dev/mmcblk0p11 18689 18817 4096 83 Linux
/dev/mmcblk0p840 83 Linux
/dev/mmcblk0p13 63937 65463 48 Checking FS Mounting EXT3-fs warning: mounting fs with errors, running e2fsck is recommended
Dec 31 18:00:17 (none) fs warning: mounting unchecked fs, running e2fsck is recommended
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
Units = cylinders of 64 * 512 = 32768 bytes
Device Boot Start k0p5 Empty
/dev/mmcblk0p10 18561 18689 4096 0 Empty
lk0p13 63937 65463 48828 83 Linux
/dev/mmcblk0p14 65463 2048 83 Linux
/dev/mmcblk0p15 65655 84855 614400+ 83 Linux
Core Dump Partition Size = 48828, type =
Checking FS Mounting EXT3-fs ws with errors, running e2fsck is recommended
Dec 31 18:00:16 (none) kernel: kjournald start0lk0:00:16 (none) kernel: EXT3-fs: recovery complete.
Dec 31 18:00:16 (none) kernel: EXT3-fs: mounted filesystem with writeback data mode.
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
4 heads, 16 sectors/track, 118272 cylinders
Units = cylinders of768 bytes
Device Boot Start End Blocks Id System
/dev/mmcblk0p1 * 1 513 16384 83 Linux
Partition 1 does not end on cylinder boundary
/dev/mmcblk0pty
Partition 2 does not end on cylinder boundary
/dev/m 4081 4097 512 0 Empty
/dev/mmcblk0p5 v/mmcblk0p7 8177 8193 512 0 Empty
/dev/mmcblk0p9
Dec(none) kernel: EXT3-fs: recovery complete.
done.
FreshAir Partition t mounting unchecked fs, running e2fsck is recommended
done.
done.
Fri Dec 31 18:00:16 CST 1999 To ex:00:17 CST 1999 To execute command __/etc/sysapps_script/S_3000_st/S_3ular_setup.sh start__
mmcblk0: retrying using ing read/write command, response 0x0, card status 0xd40
mmcblk0: retryiend_request: I/O error, dev mmcblk0, d(d'1718:0mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd40
0:19 (none) kernend_request: I/O error, dev mmcblk0, sector el: sh_mmcif: Cmd(d'17) sh_mmcif: Cmd(d'17) err
err
And this loop output with changing sector:
2
3
Dec 31 18:01:24 (none) kernel: mmcblmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd40
k0: retrying usiend_request: I/O error, dev mmcblkec 31 18:01:24 mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd40
(nokernel: eend_request: I/O error, dev mmcblk0, sector 82035
