Someone up above has done it, but you have to flash the firmware to the SD card, then take that SD card to another host to unpack/repack and change device paths for the Linux squash filesystem.
If anyone happening by this thread happens to have a copy of iDRAC7 1.30.30 firmware that they wouldn’t mind passing on it would be appreciated. I have a server that can’t find a valid firmware image, and I’d like to try flashing it with the iDRAC version that it shipped with. It looks like the previous versions on Dell’s website only go back to 1.57.57,A00
I join the problem with the corrupted EMMC. I have been trying to boot from the SD with the steps you indicate. But I can’t get it:
Here is the current boot.
U-Boot 2009.08 (Jun 03 2013 - 03:47:19) Avocent (0.0.3) EVB, Build: jenkins-idrac-yocto-release-264
CPU: SH-4A
BOARD: R0P7757LC00xxRL (C0 step) board
BOOT: Secure, HRK generated
DRAM: 240MB
(240MB of 256MB total DRAM is available on U-Boot)
ENV: Using primary env area.
In: serial
Out: serial
Err: serial
PCIe: Bridge loaded with 0x18000 bytes
WDT2: Booted Lower Vector, 'uboot1'
sh_mmcif: 0, sh-sdhi: 1
Net: sh_eth.0, sh_g_eth.0
INFO: 00:003 Start-up -to- util_idrac_main()
INFO: 00:004 U-Boot 2009.08 (Jun 03 2013 - 03:47:19) Avocent (0.0.3) EVB
INFO: 00:006 U-Boot checkin date(07-30-2012) Version(1.0.179)
INFO: 00:006 iDRAC PPID <NULL>
INFO: 00:003 SPI NOR init 4096 KiB MX25L3206E bus=0 cs=0, speed=1000000, mode=3
INFO: 00:008 SH-4A Product: Major Ver=0x31 Minor Ver=0x14 C4 Little endian
Family=0x10 Major Ver=0x30 Minor Ver=0x0b
PASS: 00:015 Dedicated monolithic mgmt NIC disabled
INFO: 00:129 BCM54610 OUI=0x3fffff Model=0x3f Revision=0x0f PhyAddr=1
INFO: 00:260 SD CARD: Device: sh-sdhi Manufacturer ID: 1b OEM: 534d
Name: 00000 Tran Speed: 25000000 Rd Block Len: 512
SD version 2.0 High Capacity: Yes Capacity: -353370112
INFO: 00:473 EMMC: Device: sh_mmcif Manufacturer ID: 90 OEM: 14a
Name: HYNIX Tran Speed: 25000000 Rd Block Len: 512
MMC version 4.0 High Capacity: Yes Capacity: 0
INFO: 00:018 CPLD: Major Ver=0x1 Minor Ver=0x0 Maint Ver=0x3
Planar: Type=0x04 Rev=0x8 Rework=0x0 Scratch/PathRetry=0x00
PASS: 00:014 Coin cell detected good, AD=0x384 low water=0x2c1
PASS: 00:008 PCIe C0 Ver=0.13 MCTP en, CRC=0x19592849 @0x8efbf4fc cnt=0x18000
INFO: 00:007 Init PCIe mailbox(PCIe 0xFFEE0150=0x40010000)
INFO: 00:006 mode=normal
INFO: 00:002 reset_cause=ac
PASS: 00:005 Booted Lower Vector, 'uboot1' wdt2cnt=0
INFO: 00:005 wdt0cnt=0
PASS: 00:002 Clear CH1/CH2, clear 4K shared memory@0xffcaa000 on AC power up
PASS: 00:008 SMR0 no sermux env, default 0xd4
INFO: 00:004 GRACR=0x3c HISEL=0x00 SIRQCR5_D=0x03 SIRQCR6_D=0x01 LADMSK0=0xff2
MRSTCR0=0xfedffe7f MRSTCR1=0xfff3ff0f MRSTCR2=0x7f80feff
BARMAP=0x1 BCR=0x85000000 NCER=0x01fc NCMCR=0x0006 NCCSR=0x0303
PASS: 00:021 etherc0=90:B1:1C:59:61:3F
getherc0=90:B1:1C:59:61:40
INFO: 00:010 Fan logic for monolithic planar type 4
fan1 - def 0000 1fff 3d fan2 - def 0000 1fff 3d
fan3 - def 0000 1fff 3d fan4 - def 0000 1fff 3d
fan5 - def 0000 1fff 3d fan6 - def 0000 1fff 3d
fan7 - def 0000 1fff 3d fan8 - def 0000 1fff 3d
INFO: 00:076 Env and backup CRC'ed ok
Extended partiton size is 0x1bffff
Clear beginning MASER, start_blk=0x126009 blk_cnt=0x7000
*** create default partitions ***
No. Type Status Start Size System
1 P 80 1 8000 16 MB Linux
2 P 00 8001 37c00 111 MB Empty
3 P 00 3fc01 400 512 KB Empty
4 E 00 40001 1bffff 895 MB Extended
5 L 00 40002 8000 16 MB Linux
6 L 00 48003 37c00 111 MB Empty
7 L 00 7fc04 400 512 KB Empty
8 L 00 80005 a0000 320 MB Empty
9 L 00 120006 2000 4 MB Empty
10 L 00 122007 2000 4 MB Empty
11 L 00 124008 2000 4 MB Empty
12 L 00 126009 d9ff7 435 MB Linux
1 Name: sh-linux
Type: SuperH Linux Kernel Image (gzip compressed)
Data Size: 0x26c395 bytes (0x1362 blocks)
Load Address: 80001000
Entry Point: 80002000
2 Type: SquashFS
Data Size: 0x38d15f4 bytes (0x1c68b blocks)
3 Unknown Image
4 Unknown Image
5 Name: sh-linux
6 Type: SquashFS
7 Unknown Image
8 Unknown Image
9 Type: SquashFS
Data Size: 0x7212c bytes (0x391 blocks)
10 Type: SquashFS
11 Unknown Image
12 Unknown Image
*** partition size changed ***
1 Name: sh-linux
2 Type: SquashFS
3 Unknown Image
4 Unknown Image
5 Name: sh-linux
6 Type: SquashFS
7 Unknown Image
8 Unknown Image
9 Type: SquashFS
10 Type: SquashFS
11 Unknown Image
12 Unknown Image
INFO: 06:834 Sync eMMC/SPI NOR/Alternate u-boot images
PASS: 00:257 Current u-boot1 1.0.179 verified with 'ubootN1'
Trailer Struct - Missing start token, exp=0xc0de1111 rec=0x1
U-boot2 in sync with u-boot1 1.0.179
FAIL: 00:328 Verify OS Images N-1: Kernel crc exp=0x1139a4c6 rec=0x191f67a5
blk_start=0x40002 blk_size=0x1362 ENV bcnt=0x26c3d5
PASS: 00:169 Boot device=emmc Boot partition1/N
Boot Path Retry:P1/N=0 P5/N-1=3 swapping to P1/N
INFO: 00:011 Sync eMMC/SPI NOR/Alternate u-boot images
PASS: 00:258 Current u-boot1 1.0.179 verified with 'ubootN'
FAIL: 00:218 Verify OS Images N: Kernel crc exp=0x1139a4c6 rec=0xc26079b6
blk_start=0x1 blk_size=0x1362 ENV bcnt=0x26c3d5
FAIL: 00:012 Boot device=emmc Boot partition1/N
Boot Path Retry:P1/N=3 P5/N-1=3 P1/N now expired
INFO: 00:000 09:191
WDT2: Disabled
** No bootable iDRAC image is found **
** (System Health & ID LED is flashing amber at ~1/2 second rate).
To Recover iDRAC via an SD card.
1) Format SD using FAT on a Windows box or EXT3 using Linux.
2) Copy 'firmimg.d7' to root path.
3) Insert SD card.
4) System Health & ID button solid amber durning recover.
5) Both boot paths are flashed.
Polling for SD card state change |
And the variables in U-boat
iDRAC7=> printenv
bootdelay=3
baudrate=115200
bootfile="all.bin"
offset=8a000000
offset_kernel=8a100000
offset_rootfs=8a300000
ps_start=a8040000
envps_on_flash=a8030000
envps_size=10000
flash_0_start=a8000000
kernel_load=88000000
kernel_start=a8100000
sd_kernel_start=1
kernel_size=200000
rootfs_start=a8300000
rootfs_load=8a000000
rootfs_size=d00000
rootfs_size_in_long=340000
ps_size=C0000
erase_env=ps erase env
erase_ps=set fl_start $(ps_start);set fl_size $(ps_size);run erase
erase=protect off $(fl_start) +$(fl_size);erase $(fl_start) +$(fl_size);protect on $(fl_start) +$(fl_size)
netboot=bootp; bootm
uboot_start=a8000000
bu=set interface tftp;set bootfile $(rootpath)bootloader.bin;set fl_start $(uboot_start);run uploadfile
au=run fwu_au erase_ps erase_env
ku=run sd_ku
ru=run sd_ru
sd_ku=fwu dev 1;set interface tftp;set bootfile kernel.bin;set sdstart $(fwu_kernel_start);run uploadsd
sd_ru=fwu dev 1;set interface tftp;set bootfile rootfs.squashfs;set sdstart $(fwu_rootfs_start);run uploadsd
uploadsd=$(interface) $(offset) $(rootpath)$(bootfile);getsdblk;mmc write 0 $(offset) $(sdstart) $(sdblknum)
fwu_au=tftp $(offset) $(rootpath)$(fwuimage);fwu update $(offset)
spi_boot=bootm $(kernel_start) $(rootfs_start)
nfs_boot=run nfsargs;run nfs_load_kernel
sd_boot=fwu dev 1; fwu boot;
nfs_load_kernel=fwu dev 1; mmc read 0 $(kernel_load) $(fwu_kernel_start) 1000;run nfsargs;bootm $(kernel_load)
uploadfile=$(interface) $(offset);protect off $(fl_start) +$(filesize);erase $(fl_start) +$(filesize);cp.b $(offset) $(fl_start) $(filesize);protect on $(fl_start) +$(filesize)
fwuimage=firmimg.d7
netdev=eth0
nfsip=
nfsroot=/nfsroot
console=ttyS2
initrdargs=set bootargs console=$(console) root=$(rootpath);bootm $(kernel_start) $(rootfs_start)
nfsargs=set bootargs console=$(console),$(baudrate) $(optarg) ethaddr=$(ethaddr) mem=$(mem) nfsroot=$(nfsip):$(nfsroot) root=/dev/nfs rw ip=$(ipaddr):$(nfsip):$(gatewayip):$(netmask):$(hostname):$(netdev):off
sbu=run spi_sbu
sku=fwu dev 1;set interface loadb;set bootfile kernel.bin;set sdstart $(fwu_kernel_start);run uploadsd
sru=fwu dev 1;set interface loadb;set bootfile kernel.bin;set sdstart $(fwu_kernel_start);run uploadsd
mac_source=0
autoload=n
uboot_offset=0
uboot_size=30000
write_spi=sf probe 0;sf erase $(spi_offset) $(size_to_spi);sf write $(offset) $(spi_offset) $(size_to_spi)
spi_bu=set interface tftp;set bootfile $(rootpath)bootloader.bin;$(interface) $(offset);set spi_offset $(uboot_offset);set size_to_spi $(uboot_size);run write_spi
spi_sbu=set interface loadb;$(interface) $(offset);set spi_offset $(uboot_offset);set size_to_spi $(uboot_size);run write_spi
m0_inf=1
m0_act=1
dmn=disabled
hostname=idrac7
bootnfs=tftp 82000000 $(bootfile); run nfsargs; bootm
macs_in_res1=yes
fwu_kernel_load=0x82000000
fwu=mmc sd
FWN=0x26c3d5_0x1139a4c6,0x38d2000_0x80668c52,0x57ff4_0xf0dc6379,0x73000_0x3ad0249b
bootcmd=fwu dev 1
benv=ootargs=root=/dev/mmcblk1p6 rootwait rw rootfstype=squashfs mem=239616k console=ttyS2,115200 <NULL> mac1=90:B1:1C:59:61:3F mac2=90:B1:1C:59:61:40 mode=vhard reset_cause=ac nmi_buf=0x83000000 quiet
fwu_spi_uboot1_start=0x0
fwu_spi_uboot2_start=0x80000
platform_id=DDRB
filesize=3C096DD
fileaddr=81000000
gatewayip=192.168.0.1
netmask=255.255.255.0
ipaddr=192.168.0.120
serverip=192.168.0.100
fwu_kernel_offset=81000200
fwu_rootfs_offset=8126c600
fwu_uboot_offset=84b3e600
fwu_uboot_size=57ff4
fwu_platform_offset=84b96600
fwu_platform_size=398
FWN1=0x26c3d5_0x1139a4c6,0x38d2000_0x80668c52,0x57ff4_0xf0dc6379,0x73000_0x3ad0249b
verify=no
dell_version=U-Boot checkin date(07-30-2012) Version(1.0.179)
stdin=serial
stdout=serial
stderr=serial
ethaddr=90:B1:1C:59:61:3F
eth2addr=90:B1:1C:59:61:40
mem=239616k
ethrotate=no
nmi_buf=0x83000000
runtime_args=mode=vhard reset_cause=ac nmi_buf=0x83000000
fwudev=evb
bootargs=root=/dev/mmcblk1p6 rootwait rw rootfstype=squashfs mem=239616k console=ttyS2,115200 <NULL> mac1=90:B1:1C:59:61:3F mac2=90:B1:1C:59:61:40 mode=vhard reset_cause=ac nmi_buf=0x83000000 quiet
fwu_kernel_start=40002
fwu_rootfs_start=48003
fwu_platform_start=122007
fwu_uboot_start=7fc04
fwu_kernel_size=1362
fwu_rootfs_size=1c68b
fwummc=emmc
ethact=sh_eth.0
ver=U-Boot 2009.08 (Jun 03 2013 - 03:47:19) Avocent (0.0.3) EVB
Environment size: 4272/65532 bytes
Before doing this SD card test, I tried to recover the emmc but it gives me a write error.
I am currently debating whether to buy an emmc chip and make the switch or keep trying with the SD.
Thank god I had stumbled upon this forum. Thanks to your guys help, I was able to successfully update my iDRAC firmware on my R320. Although mine wasn’t ‘bricked’ it just refused to update no matter how hard I tried or what method of updating it I used. Here is my Dell Forum right from the very start and how I have included the steps that I took for fixing my issue as there aren’t many for R320/R420 users. I was starting to lose hope with my R320, although it wasn’t bricked like yours, iDRAC just refused to update no matter how hard I tried or what method I used. Luckily, the util command worked for me and updated the firmware image from the SD card. If it wasn’t for your video I would have definitely given up! Here is my conversation with on the Dell Forum with the steps I took to fix this problem for anyone that had experienced similar issues: https://www.dell.com/community/PowerEdge-Hardware-General/Unable-to-upgrade-iDRAC-7-from-2-21-21/td-p/8388296
Hi Team,
I have the same problem with my r720:
Warning ! iDRAC initialization error. Continuing to boot may yield unexpected power loss due to unknown Power inventory and various features lost such as Remote Access, Active Power Management, Thermal Management, Inventory, LCD, or System Error Reporting.
Strike F1 to continue, F2 to run system setup program
If I hit F2, in BIOS option, under iDRAC Setting, I have: “SWC0700: iDRAC is not ready. The configuration values cannot be accessed.”
If I hit F1, the boot sequence continue and complain again about iDRAC “SWC0700: iDRAC is not ready. The configuration values cannot be accessed.”
but if I press F1, the real boot continue.
I came across
The Bios is something like 2.52 or 2.56
I am not exactly sure which iDrac version I had running.
If I have to guess, I would say something like 2.30.30.30…
I have downloaded all iDrac versions and have extracted firmimg.d7 from all of them, which are:
1.20.20
1.23.23
1.31.30
1.35.35
1.37.35
1.40.40
1.45.45
1.46.45
1.57.57
1.66.65
2.10.10.10
2.15.10.10
2.20.20.20
2.21.21.21
2.30.30.30
2.31.31.30
2.32.31.30
2.40.40.40
2.41.40.40
2.50.50.50
2.52.52.52
2.60.60.60
2.61.60.60
2.63.60.62
Which version should I use on the SD disc?
Thank you
Marco
Hi,
an update:
What caused this, might have been that one power supply was defect, when I tried to do a rebranding
I tried it the image from 2.63.60.62 after replacing the defect powersupply.
there was no LED flashing, that might be the reason why it did not try to boot from the SD card.
I left the server now powered down - and basically be thrown out … …
If anyone has an idea, please let me know.
Thanks
Marco
Hiya…
Can u share a picture with the Diagram for the RS232TTL ? i´ve got a R420 unit with the same issue, it has just arrived this week, got it off someone that was going to scrap this unit, so i am willing to give it a try.
Hi guys… so i have managed to connect the BCM_UART port and interrupt i can get idrac7 console now… so i have formated a SD card and copied the firmimage.d7 to the sd card in FAT mode .
after playing around with the cmds it gives me the following errors trying to load image from SD card.
iDRAC7=> mmc list
sh_mmcif: 0
sh-sdhi: 1
iDRAC7=> mmc rescan 1
iDRAC7=> util recover -emmc -from sd -f firmimg.d7
UTIL RECOVER:Transport:sd TargetMMC:EMMC File:firmimg.d7
UTIL RECOVER:ERROR:Could not locate ‘firmimg.d7’ in FAT or EXT2 file system.
UTIL FAIL
iDRAC7=> mmc list
sh_mmcif: 0
sh-sdhi: 1
UTIL FAIL
iDRAC7=> mmc list
sh_mmcif: 0
sh-sdhi: 1
iDRAC7=> mmc list
sh_mmcif: 0
sh-sdhi: 1
reading firmimg.d7
63064294 bytes read
UTIL RECOVER:SD load passed from FAT fs.
UTIL RECOVER:Transport time [sec:mil]: 10:897
Clear OS images in partition/s.
Clear kernelN, rootfsN, ubootN
‘EMMC’ blk size=[0x200][512] Erase to 0xffffffff
Mem buf size=[0x06000000][100663296] Total bytes=[0x08000000][134217728]
blocks[0x1:0x40001][1:262145]
mmc write failed000] Buf[0x88000000]…fill buffer…erase/write
util flash:
Failure writing blocks [1:196609] RC=0xffffffac
UTIL PASS
iDRAC7=> mmc list
sh_mmcif: 0
sh-sdhi: 1
iDRAC7=> mmc list
sh_mmcif: 0
sh-sdhi: 1
reading firmimg.d7
63064294 bytes read
UTIL RECOVER:Transport time [sec:mil]: 10:886
util flash:
UTIL PASS
iDRAC7=> mmc list
sh_mmcif: 0
sh-sdhi: 1
iDRAC7=> mmc list
sh_mmcif: 0
sh-sdhi: 1
reading firmimg.d7
112384230 bytes read
UTIL RECOVER:Transport time [sec:mil]: 19:383
util flash:
UTIL PASS
iDRAC7=>
Any ideas? when i tried to copy the firmimage.d7 to the SD card is crashed the card and usb came back up again but showing the image inside but it allways gives me erros when uploading the firmware img i will try to get a new SD card for testing.
Ok few more testing with different command and i got the following result
iDRAC7=> util recover -emmc -from sd -f firmimg.d7 -noreset -clean
reading firmimg.d7
UTIL RECOVER:Transport time [sec:mil]: 19:382
Clear SPI LCL.
‘SPI NOR’ blk size=[0x10000][65536] Erase to 0xffffffff
Mem buf size=[0x06000000][100663296] Total bytes=[0x00180000][1572864]
blocks[0x1c:0x33][28:51]
Blocks [0x1c:0x33] Buf[0x88000000]…fill buffer…erase/write
Completed loop 1, Elapsed time in hr:min:sec:mil 17:161
Clear eMMC…~3 minutes.
Mem buf size=[0x06000000][100663296] Total bytes=[0x80000000][-2147483648]
blocks[0x0:0x400000][0:4194304]
mmc write failedfff] Buf[0x88000000]…fill buffer…erase/write
util flash:
Failure writing blocks [0:196608] RC=0xffffffac
UTIL PASS
iDRAC7=>
but still getting errors.
DUMP SPI iDRAC 8 DELL PowerEdge R530
Hi All,
I am here to join the party of unbricking my iDRAC. I have T330 Server that I tried to install frimware via the WebUI and it never came back. I am planning on just loading FreeNAS and just use it for NAS Storage. However now it wont boot without physically directing it to start OS and the FAN controls are now borked. So I decided to endeavor the adventure of reviving a dell iDRAC8.
So firstly if someone needs to do this to iDRAC8 (T330) and dont want to solder I have a solution. I made a 3D print that will hold the pins in the exact location you need. You can find and print from thingiverse here: T330 IDRAC8 UART Solderless Jumper Cable Clip by rtarson - Thingiverse
Any whose, so I am currently having a situation which from reading something is wrong with my eMMC storage on the board.
When i do mmcinfo 0 (which is presumably the on board chip that stores the frimware?) I have this message:
Card did not respond to voltage select!
Device: sh_mmcif
Manufacturer ID: 0
OEM: 0
Name: Tran Speed: 0
Rd Block Len: 0
MMC version 0.0
High Capacity: No
Capacity: 0
Bus Width: 1-bit
When I try to write the mmc from the SD I get this message here:
Card did not respond to voltage select!ill buffer…erase/write
sh_mmcif: Cmd(d’16) err
set write bl len failed, err =-84
util flash:
Failure writing blocks [1:196609] RC=0xffffffff
UTIL PASS
Now I did see in this form post that someone said you can get it so iDrac just runs off of the SD versus the eMMC and in order to do that you have a tftp server with the frimimg.d7 but have the util recover from the tftp to the sd card so from my knowledge you are building out the SD card with the formating and partion on the SD versus the emmc from my understanding?
My situation is when i do try to use tftp it looks like ethernet timing out? I have the ethernet plugged in on port 1 on the motherboard(not the dedicated idrac) which is showing link lights on port 1. But I get this message when doing dhcp command:
iDRAC8=> dhcp
reset PHY of sh_g_eth.0
sh_eth: phy reset timeout
sh_eth: phy config timeout
No for my printenv it does show an ipaddr I know this is just the default IP but maybe I have to change the ip address and set enviroment virable to ip subnet that its on? I would do it now but I am not with the server at the moment.
iDRAC8=> printenv
bootdelay=3
baudrate=115200
bootfile=“all.bin”
offset=8a000000
Any help here would be great as I am only trying to save a couple bucks and turn this into a storage server for a business but I want it to boot back when it gets power lost and not scream all day long lol.
Dear Everyone,
I join the topic because I bought a T620 and the IDRAC was not working.
IDRAC Info LED not blinking.
I have updated the BIOS to the latest version 2.9.0.
So it was not possible to interrupt UBOOT.
To solve the issue I did the following:
- I connected an USB to UART adapter to the IDRAC UART.
- Replaced the IDRAC eMMC.
- Flash the latest firmware using the SD-Card firmimg.d7. I had to remove the SD-Card multiple time before the server was able to detect the SD-Card.
- After the update I had to “flea drain” the server power.
- Wait 4 minutes to allow the IDRAC to boot (1-2 minutes per eMMC GB)
- The server still had some issue to communicate with the power supply
- Update the drivers and firmware using Dell update ISO
- I install a Linux operating systems
- Install BIOS 2.9.0 again
- Install IDRAC version 2.65.65.65
Now everything is OK, the IDRAC is working and the server FAN are quiet.
Thank you for creating this thread. I will not have been able to repair this T620 without the information listed here.
Hey all,
I have a Dell R720 that I recently wanted to update the iDRAC firmware for, because I wasn’t able to access the web UI because the TLS encryption did not work and I couldn’t do anything to my web browser to bypass this error and continue to the UI.
The SSH console worked, the LCD worked, etc.
So I went to the dell website to search for firmware, found the latest one, didn’t think much of it, because I previously updated the bios on the machine to the latest one without issues. I was on some version from 2012, maybe 1.20.20_A00, and I went straight for 2.65.65.65_A00.
So I booted into Win 10, opened the EXE, and everything was working just fine.
After like 10-15 minutes, I got an error from the firmware application, and now the LCD on front did not work. I was a bit scared, tried to re-running the EXE, but it only said that my system was not compatible.
I decided to restart the server to try installing the firmware from CentOS/RHEL, but that is when the issues started, the iDRAC did not boot anymore, and I got the errors on boot-up.
I tried so many different things, different OSs, tired removing the verification part from the shell script to update the iDRAC firmware, but to no avail.
Now I resorted to trying to see what the UART says, and this is what I can see:
U-Boot 2009.08 (Jun 02 2012 - 18:30:52) Avocent (0.0.3) EVB, Build: jenkins-12G_W3_FW_Releases-60
CPU: SH-4A
DRAM: 240MB
In: serial
Out: serial
Err: serial
INFO: 00:004 U-Boot 2009.08 (Jun 02 2012 - 18:30:52) Avocent (0.0.3) EVB
INFO: 00:007 U-Boot checkin date(03-02-2012) Version(1.0.175)
INFO: 00:002 SPI NOR init 4096 KiB MX25L3206E bus=0 cs=0, speed=1000000, mode=3
INFO: 00:008 SH-4A Product: Major Ver=0x31 Minor Ver=0x13 C3 Little endian
INFO: 00:246 SD CARD: Device: sh-sdhi Manufacturer ID: 41 OEM: 3432
Name: DELL1 Tran Speed: 25000000 Rd Block Len: 512
SD version 2.0 High Capacity: Yes Capacity: -398458880
INFO: 00:059 EMMC: Device: sh_mmcif Manufacturer ID: 90 OEM: 14a
Planar: Type=0x02 Rev=0x8 Rework=0x0 Scratch/PathRetry=0x00
PASS: 00:014 Coin cell detected good, AD=0x37b low water=0x2c1
PASS: 00:008 PCIe C0 Ver=0.13 MCTP en, CRC=0x19592849 @0x8efbf3a8 cnt=0x18000
INFO: 00:005 mode=normal
INFO: 00:003 reset_cause=NMI_id_button
PASS: 05:087 Write trace buf mem@0x83000000 to SPI NOR@0x140000 for 0x80000
PASS: 00:008 Booted Lower Vector, 'uboot1' wdt2cnt=0
PASS: 00:002 SMR0 no sermux env, default 0xd4
PASS: 00:022 etherc0=90:B1:1C:01:BE:A5
getherc0=90:B1:1C:01:BE:A6
INFO: 00:007 Fan logic is not modified on Non-AC power up
INFO: 00:052 Env and backup CRC'ed ok
*** no text signature found ***
INFO: 00:529 Sync eMMC/SPI NOR/Alternate u-boot images
PASS: 00:074 Current u-boot1 1.0.175 verified with 'ubootN'
Trailer Struct - Missing start token, exp=0xc0de1111 rec=0x0
PASS: 03:458 Verify OS Images N: CRC32 OK: Kernel=0x2d2709dd Rootfs=0xc0000fcd
PASS: 00:008 Boot device=emmc Boot partition1/N
Boot Path Retry:P1/N=0 P5/N-1=0
INFO: 00:000 09:798
WDT2: Disabled
Initialization complete, proceed with boot
OS_WDT0_EN:180 seconds, Re-load ILRAM:
Copying kernel image ... OK
## Booting kernel from Legacy Image at 88000000 ...
Image Name: sh-linux
Image Type: SuperH Linux Kernel Image (gzip compressed)
Data Size: 2537914 Bytes = 2.4 MB
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
WDT2: Disable in do_bootm_linux()
sh_eth_init
Monolithic/DRB
init started: BusyBox v1.18.4 (2012-06-02 19:22:04 UTC)
starting pid 413, tty '': '/etc/init.d/rcS'
waitfor: pid 413 ...
setting net.ipv6.conf.default.accept_dad based on kernel bootup option
enable normal accept DAD for ipv6
Sat Jan 1 00:00:01 UTC 2000 To execute command __source /etc/sysapps_script/I_1000_mountfs.sh__
Sat Jan 1 00:00:03 UTC 2000 To execute command __source /etc/sysapps_script/I_1001_trigwdt.sh__
<========= Start H/W watchdog first... =========>
Sat Jan 1 00:00:03 UTC 2000 To execute command __source /etc/sysapps_script/I_1100_nfs.sh__
Sat Jan 1 00:00:03 UTC 2000 To execute command __source /etc/sysapps_script/I_1105_ps.sh__
XXXXXX /dev/mmcblk0p11
/dev/mmcblk0p11: recovering journal
fsck.ext3: unable to set superblock flags on /dev/mmcblk0p11
e2fsck 1.41.14 (22-Dec-2010)
Sat Jan 1 00:00:04 UTC 2000 To execute command __source /etc/sysapps_script/I_1106_clear_ps.sh__
Sat Jan 1 00:00:04 UTC 2000 To execute command __source /etc/sysapps_script/I_1150_SYS_Drv.sh__
Sat Jan 1 00:00:06 UTC 2000 To execute command __source /etc/sysapps_script/I_1170_mknode.sh__
Sat Jan 1 00:00:07 UTC 2000 To execute command __/etc/sysapps_script/config_lib_init.sh__
mounting Platform Data 1 partition
Sat Jan 1 00:00:10 UTC 2000 To execute command __source /etc/sysapps_script/I_1160_OSINET.sh__
Sat Jan 1 00:00:10 UTC 2000 To execute command __source /etc/sysapps_script/I_1200_etc_defaults.sh__
Sat Jan 1 00:00:10 UTC 2000 To execute command __source /etc/sysapps_script/I_1210_sysklog_syslogd.sh__
starting syslogd
/etc/sysapps_script/syslog.sh: /sbin/aim not running
waitfor: pid 413, wpid 705
syslogd: /mmc1/idraclogs: Read-only file system
Jan 1 00:00:11 (none) syslogd 1.4.2: restart.
Jan 1 00:00:11 (none) kernel: klogd 1.4.2, log source = /proc/kmsg started.
Jan 1 00:00:11 (none) kernel: Cannot find map file.
Jan 1 00:00:11 (none) kernel: No module symbols loaded - kernel modules not enabled.
Jan 1 00:00:11 (none) kernel: cannot find any symbols, turning off symbol lookups
Jan 1 00:00:11 (none) kernel: Linux version 2.6.30 ([email protected]) (gcc version 4.3.4 (GCC) ) #1 Sat Jun 2 18:35:38 UTC 2012
Jan 1 00:00:11 (none) kernel: Boot params:
Jan 1 00:00:11 (none) kernel: ... MOUNT_ROOT_RDONLY - 00000000
Jan 1 00:00:11 (none) kernel: ... RAMDISK_FLAGS - 00000000
Jan 1 00:00:11 (none) kernel: ... ORIG_ROOT_DEV - 00000000
Jan 1 00:00:11 (none) kernel: ... LOADER_TYPE - 00000000
Jan 1 00:00:11 (none) kernel: ... INITRD_START - 00000000
Jan 1 00:00:11 (none) kernel: ... INITRD_SIZE - 00000000
Jan 1 00:00:11 (none) kernel: NMI Buffer at 0x83000000
Jan 1 00:00:11 (none) kernel: Booting machvec: SH7757LCR
Jan 1 00:00:11 (none) kernel: Renesas R0P7757LC0012RL support.
Jan 1 00:00:11 (none) kernel: Node 0: start_pfn = 0x40000, low = 0x4ea00
Jan 1 00:00:11 (none) kernel: Zone PFN ranges:
Jan 1 00:00:11 (none) kernel: Normal 0x00040000 -> 0x0004ea00
Jan 1 00:00:11 (none) kernel: Movable zone start PFN for each node
Jan 1 00:00:11 (none) kernel: early_node_map[1] active PFN ranges
Jan 1 00:00:11 (none) kernel: 0: 0x00040000 -> 0x0004ea00
Jan 1 00:00:11 (none) kernel: On node 0 totalpages: 59904
Jan 1 00:00:11 (none) kernel: free_area_init_node: node 0, pgdat 804913ac, node_mem_map 804f5000
Jan 1 00:00:11 (none) kernel: Normal zone: 468 pages used for memmap
Jan 1 00:00:11 (none) kernel: Normal zone: 0 pages reserved
Jan 1 00:00:11 (none) kernel: Normal zone: 59436 pages, LIFO batch:15
Jan 1 00:00:11 (none) kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 59436
Jan 1 00:00:11 (none) kernel: Kernel command line: root=/dev/mmcblk0p2 rootwait rw rootfstype=squashfs mem=239616k console=ttyS2,115200 <NULL> mac1=90:B1:1C:01:BE:A5 mac2=90:B1:1C:01:BE:A6 mode=normal reset_cause=NMI_id_button nmi_buf=0xt
Jan 1 00:00:11 (none) kernel: TRAB buffer at 8eb00000 allocated
Jan 1 00:00:11 (none) kernel: NR_IRQS:384
Jan 1 00:00:11 (none) kernel: PID hash table entries: 1024 (order: 10, 4096 bytes)
Jan 1 00:00:11 (none) kernel: Using tmu for system timer
Jan 1 00:00:11 (none) kernel: Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Jan 1 00:00:11 (none) kernel: Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Jan 1 00:00:11 (none) kernel: PVR=10300b00 CVR=73440410 PRR=00003113
Jan 1 00:00:11 (none) kernel: I-cache : n_ways=4 n_sets=256 way_incr=8192
Jan 1 00:00:11 (none) kernel: I-cache : entry_mask=0x00001fe0 alias_mask=0x00001000 n_aliases=2
Jan 1 00:00:11 (none) kernel: D-cache : n_ways=4 n_sets=256 way_incr=8192
Jan 1 00:00:11 (none) kernel: D-cache : entry_mask=0x00001fe0 alias_mask=0x00001000 n_aliases=2
Jan 1 00:00:11 (none) kernel: Memory: 232192k/239616k available (3473k kernel code, 1205k data, 156k init)
Jan 1 00:00:11 (none) kernel: Calibrating delay loop... 230.19 BogoMIPS (lpj=1150976)
Jan 1 00:00:11 (none) kernel: Security Framework initialized
Jan 1 00:00:11 (none) kernel: Mount-cache hash table entries: 512
Jan 1 00:00:11 (none) kernel: CPU: SH7757
Jan 1 00:00:11 (none) kernel: net_namespace: 980 bytes
Jan 1 00:00:11 (none) kernel: PCI: Using configuration type 1
Jan 1 00:00:11 (none) kernel: NET: Registered protocol family 16
Sat Jan 1 00:00:11 UTC 2000 To execute command __source /etc/sysapps_script/I_trab_asdf.sh__
Jan 1 00:00:11 (none) kernel: sh pinmux: sh7757_pfc handling gpio 0 -> 504
Jan 1 00:00:11 (none) kernel: bio: create slab <bio-0> at 0
Jan 1 00:00:11 (none) kernel: usbcore: registered new interface driver usbfs
Jan 1 00:00:11 (none) kernel: usbcore: registered new interface driver hub
Jan 1 00:00:11 (none) kernel: usbcore: registered new device driver usb
Jan 1 00:00:11 (none) kernel: DMA: Registering DMA API.
Jan 1 00:00:11 (none) kernel: DMA: Registering sh_dmac handler (24 channels).
Jan 1 00:00:11 (none) kernel: Autoconfig PCI channel 0x8048a900
Jan 1 00:00:11 (none) kernel: Scanning bus 00, I/O 0xfed00000:0xff100000, Mem 0x04000000:0x08000000
Jan 1 00:00:11 (none) kernel: NET: Registered protocol family 2
Jan 1 00:00:11 (none) kernel: IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
Jan 1 00:00:11 (none) kernel: TCP established hash table entries: 8192 (order: 4, 65536 bytes)
Jan 1 00:00:11 (none) kernel: TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
Jan 1 00:00:11 (none) kernel: TCP: Hash tables configured (established 8192 bind 8192)
Jan 1 00:00:11 (none) kernel: TCP reno registered
Jan 1 00:00:11 (none) kernel: Switched to high resolution mode on CPU 0
Jan 1 00:00:11 (none) kernel: enable PCIe shared memory area
Jan 1 00:00:11 (none) kernel: audit: initializing netlink socket (disabled)
Jan 1 00:00:11 (none) kernel: type=2000 audit(946684800.310:1): initialized
Jan 1 00:00:11 (none) kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Jan 1 00:00:11 (none) kernel: JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
Jan 1 00:00:11 (none) kernel: fuse init (API version 7.11)
Jan 1 00:00:11 (none) kernel: msgmni has been set to 453
Jan 1 00:00:11 (none) kernel: alg: No test for cipher_null (cipher_null-generic)
Jan 1 00:00:11 (none) kernel: alg: No test for ecb(cipher_null) (ecb-cipher_null)
Jan 1 00:00:12 (none) kernel: alg: No test for digest_null (digest_null-generic)
Jan 1 00:00:12 (none) kernel: alg: No test for compress_null (compress_null-generic)
Jan 1 00:00:12 (none) kernel: alg: No test for stdrng (krng)
Jan 1 00:00:12 (none) kernel: io scheduler noop registered
Jan 1 00:00:12 (none) kernel: io scheduler anticipatory registered
Jan 1 00:00:12 (none) kernel: io schedIRQ 50/r8a66597_udc: IRQF_DISABLED is not guaranteed on shared IRQs
uler deadline reIRQ 57/r8a66597_udc: IRQF_DISABLED is not guaranteed on shared IRQs
gistered (default)
Jan 1 00:00:12 (none) kernel: io scheduler cfq registered
Jan 1 00:00:12 (none) kernel: Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
Jan 1 00:00:12 (none) kernel: SuperH SCI(F) driver initialized
Jan 1 00:00:12 (none) kernel: sh-sci: ttyS0 at MMIO 0xfe4b0000 (irq = 40) is a scif
Jan 1 00:00:12 (none) kernel: sh-sci: ttyS1 at MMIO 0xfe4c0000 (irq = 76) is a scif
Jan 1 00:00:12 (none) kernel: sh-sci: ttyS2 at MMIO 0xfe4d0000 (irq = 104) is a scif
Jan 1 00:00:12 (none) kernel: console [ttyS2] enabled
Jan 1 00:00:12 (none) kernel: sh-sci: ttyS3 at MMIO 0xfe4c0000 (irq = 76) is a scif
Jan 1 00:00:12 (none) kernel: sh-sci: ttyS4 at MMIO 0xfe4c0000 (irq = 76) is a scif
Jan 1 00:00:12 (none) kernel: sh-sci: ttyS5 at MMIO 0xfe4c0000 (irq = 76) is a scif
Jan 1 00:00:12 (none) kernel: sh-sci: ttyS6 at MMIO 0xfe4c0000 (irq = 76) is a scif
Jan 1 00:00:12 (none) kernel: brd: module loaded
Jan 1 00:00:12 (none) kernel: loop: module loaded
Jan 1 00:00:12 (none) kernel: nbd: registered device at major 43
Jan 1 00:00:12 (none) kernel: sh_eth_init
Sat Jan 1 00:00:11 UTC 2000 To execute command __source /etc/sysapps_script/I_usb_drv.sh__
Jan 1 00:00:12 (none) kernel: Monolithic/DRB
Jan 1 00:00:12 (none) kernel: sh_mii: probed
Jan 1 00:00:12 (none) kernel: Base address at 0xfee00000, 00:00:00:00:00:00, IRQ 315.
hid_init: Desc: Keyboard/Mouse Function
hid_init: Name: g_kbdmouse
hid_init: Version: 20110426
hid_bind: Using Major Number 233
hid_bind: using r8a66597_udc, Keyboard ep1 Mouse ep2
hid_bind: Mouse REL ep3
Jan 1 00:00:12 (none) kernel: Base address at 0xfef00800, 00:00:00:00:00:00, IRQ 84.
Jan 1 00:00:12 (none) kernel: sh_spi sh_spi.0: registered master spi0
Jan 1 00:00:12 (none) kernel: m25p80 spi0.1: mx25l3205d (4096 Kbytes)
Jan 1 00:00:12 (none) kernel: Creating 9 MTD partitions on "m25p80":
Jan 1 00:00:12 (none) kernel: 0x000000000000-0x000000080000 : "u-boot1"
Jan 1 00:00:12 (none) kernel: 0x000000080000-0x000000100000 : "u-boot2"
Jan 1 00:00:12 (none) kernel: 0x000000100000-0x000000110000 : "env1"
Jan 1 00:00:12 (none) kernel: 0x000000110000-0x000000120000 : "env2"
Jan 1 00:00:12 (none) kernel: 0x000000120000-0x000000130000 : "fru"
Jan 1 00:00:12 (none) kernel: 0x000000130000-0x000000140000 : "res1"
Jan 1 00:00:12 (none) kernel: 0x000000140000-0x0000001c0000 : "tracebuf"
Jan 1 00:00:12 (none) kernel: 0x0000001c0000-0x000000340000 : "lcl"
Jan 1 00:00:12 (none) kernel: 0x000000340000-0x000000400000 : "res2"
Jan 1 00:00:12 (none) kernel: sh_spi sh_spi.0: registered child spi0.1
Jan 1 00:00:12 (none) kernel: spi_sh: version 2009-06-10
Jan 1 00:00:12 (none) kernel: mknod /dev/aess_wdtdrv c 10 130
Jan 1 00:00:12 (none) kernel: aess_wdtdrv: initialized. (nowayout=0)
Jan 1 00:00:12 (none) kernel: device-mapper: ioctl: 4.14.0-ioctl (2008-04-23) initialised: [email protected]
Jan 1 00:00:12 (none) kernel: sh_mmcif: driver version 2010-03-17
Jan 1 00:00:12 (none) kernel: sh-sdhi: power control pin initiated
Jan 1 00:00:12 (none) kernel: mmc1: power off - f
Jan 1 00:00:12 (none) kernel: heartbeat: version 0.1.1 loaded
Jan 1 00:00:12 (none) kernel: sermux sermux: version 2010-05-26
Jan 1 00:00:12 (none) kernel: nf_conntrack version 0.5.0 (3744 buckets, 14976 max)
Jan 1 00:00:12 (none) kernel: IPv4 over IPv4 tunneling driver
Jan 1 00:00:12 (none) kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 00:00:12 (none) kernel: TCP cubic registered
Jan 1 00:00:12 (none) kernel: NET: Registered protocol family 10
Jan 1 00:00:12 (none) kernel: lo: Disabled Privacy Extensions
Jan 1 00:00:12 (none) kernel: tunl0: Disabled Privacy Extensions
Jan 1 00:00:12 (none) kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 00:00:12 (none) kernel: IPv6 over IPv4 tunneling driver
Jan 1 00:00:12 (none) kernel: sit0: Disabled Privacy Extensions
Jan 1 00:00:12 (none) kernel: NET: Registered protocol family 17
Jan 1 00:00:12 (none) kernel: RPC: Registered udp transport module.
Jan 1 00:00:12 (none) kernel: RPC: Registered tcp transport module.
Jan 1 00:00:12 (none) kernel: 802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
Jan 1 00:00:12 (none) kernel: All bugs added by David S. Miller <[email protected]>
Jan 1 00:00:12 (none) kernel: registered taskstats version 1
Jan 1 00:00:12 (none) kernel: Waiting for root device /dev/mmcblk0p2...
Jan 1 00:00:12 (none) kernel: mmc0: new high speed MMC card at address 0001
Jan 1 00:00:12 (none) kernel: mmcblk0: mmc0:0001 HYNIX 3.60 GiB
Jan 1 00:00:12 (none) kernel: mmcblk0: p1 p2 p3 p4 < p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 >
Jan 1 00:00:12 (none) kernel: mmc1: power on - e
Jan 1 00:00:12 (none) kernel: VFS: Mounted root (squashfs filesystem) readonly on device 179:2.
Jan 1 00:00:12 (none) kernel: Freeing unused kernel memory: 156k freed
Jan 1 00:00:12 (none) kernel: mmc1: new high speed SDHC card at address 0007
Jan 1 00:00:12 (none) kernel: mmcblk1: mmc1:0007 DELL1 7.62 GiB
Jan 1 00:00:12 (none) kernel: mmcblk1: p1
Jan 1 00:00:12 (none) kernel: kjournald starting. Commit interval 5 seconds
Jan 1 00:00:12 (none) kernel: EXT3 FS on mmcblk0p11, internal journal
Jan 1 00:00:12 (none) kernel: EXT3-fs: recovery complete.
Jan 1 00:00:12 (none) kernel: EXT3-fs: mounted filesystem with ordered data mode.
Jan 1 00:00:12 (none) kernel: JFFS2 notice: (442) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
Jan 1 00:00:12 (none) kernel: KN:init_aess_mem_module
Jan 1 00:00:12 (none) kernel: mknod /dev/aess_eventhandlerdrv c 253 0
Jan 1 00:00:12 (none) kernel: mknod /dev/aess_kcsdrv c 252 0
Jan 1 00:00:12 (none) kernel: mknod /dev/aess_biospostdrv c 251 0
Jan 1 00:00:12 (none) kernel: mknod /dev/aess_gpiodrv c 250 0
Jan 1 00:00:12 (none) kernel: mknod /dev/aess_sgpiodrv c 249 0
Jan 1 00:00:12 (none) kernel: mknod /dev/aess_dynairqdrv c 248 0
Jan 1 00:00:12 (none) kernel: IRQ 236/aess_dynairqdrv: IRQF_DISABLED is not guaranteed on shared IRQs
Jan 1 00:00:12 (none) kernel: mknod /dev/aess_i2c_hwctrldrv c 247 0
Jan 1 00:00:12 (none) kernel: mknod /dev/aess_i2cdrv c 246 0
Jan 1 00:00:12 (none) kernel: mknod /dev/aess_spi1drv c 245 0
Jan 1 00:00:12 (none) kernel: Init_aess_pecisensor_module Sucess!
Jan 1 00:00:12 (none) kernel: mknod /dev/aess_pecisensordrv c 244 0
Jan 1 00:00:12 (none) kernel: mknod /dev/crypto c 10 59
Jan 1 00:00:12 (none) kernel: cryptodev: driver 0.8 loaded.
Jan 1 00:00:12 (none) kernel: TSIP HW Crypto accelerator: <6>Using mtd0 as boot flash
Jan 1 00:00:12 (none) kernel: Mask ROM with HRK support
Jan 1 00:00:12 (none) kernel: tsip_sboot called
Jan 1 00:00:12 (none) kernel: hwrng registration sucessed
Jan 1 00:00:13 (none) kernel: cbc(aes) ecb(aes) ecb(des3_ede) cbc(des3_ede) sha1 sha256 hmac(sha1) hmac(sha256) <6>
Jan 1 00:00:13 (none) kernel: mknod /dev/aess_fansensordrv c 243 0
Jan 1 00:00:13 (none) kernel: mknod /dev/aess_pwmdrv c 242 0
Jan 1 00:00:13 (none) kernel: mknod /dev/dell_cplddrv c 240 0
Jan 1 00:00:13 (none) kernel: mknod /dev/aess_rspidrv c 239 0
Jan 1 00:00:13 (none) kernel: aess_rspi_init: isblade=0 val=0x2
Jan 1 00:00:13 (none) kernel: mknod /dev/dell_fpdrv c 238 0
Jan 1 00:00:13 (none) kernel: dell_fp_init: isblade=0 isdrb=0 val=0x2
Jan 1 00:00:13 (none) kernel: dell_fp_init: iterations=126 val=5 isled=0
Jan 1 00:00:13 (none) kernel: mknod /dev/aess_adcsensordrv c 237 0
Jan 1 00:00:13 (none) kernel: mknod /dev/vkcs c 236 0
Jan 1 00:00:13 (none) kernel: mknod /dev/aess_memdrv c 235 0
Jan 1 00:00:13 (none) kernel: mknod /dev/sh_pbi c 234 0
Jan 1 00:00:13 (none) kernel: sh_pbi: 4kb Shared memory @ ffcaa000, PBI registers @ ffca0000, IRQ 320
Jan 1 00:00:13 (none) kernel: TRAB module loading: 0x80000 bytes
Jan 1 00:00:13 (none) kernel: TRAB exec: 0x8eb00000/0x40000 lookup: 0x8eb40000/0x400 nmi_buf: 0x83000000
Jan 1 00:00:13 (none) kernel: IRQ 50/r8a66597_udc: IRQF_DISABLED is not guaranteed on shared IRQs
Jan 1 00:00:13 (none) kernel: r8a66597_udc r8a66597_udc.0: version 20111109
Jan 1 00:00:13 (none) kernel: IRQ 57/r8a66597_udc: IRQF_DISABLED is not guaranteed on shared IRQs
Jan 1 00:00:13 (none) kernel: r8a66597_udc r8a66597_udc.1: version 20111109
Jan 1 00:00:13 (none) kernel: Now registering USB0/func0
Jan 1 00:00:13 (none) kernel: Gadget USB HUB, version: 20111105
Jan 1 00:00:13 (none) kernel: hid_init: Desc: Keyboard/Mouse Function
Jan 1 00:00:13 (none) kernel: hid_init: Name: g_kbdmouse
Jan 1 00:00:13 (none) kernel: hid_init: Version: 20110426
Jan 1 00:00:13 (none) kernel: Now registering USB0/func1
Jan 1 00:00:13 (none) kernel: hid_bind: Using Major Number 233
Jan 1 00:00:13 (none) kernel: hid_bind: using r8a66597_udc, Keyboard ep1 Mouse ep2
Jan 1 00:00:13 (none) kernel: hid_bind: Mouse REL ep3
Jan 1 00:00:13 (none) kernel: g_mass_storage: msd_init() Desc: Mass Storage Function
Jan 1 00:00:13 (none) kernel: g_mass_storage: msd_init() Name: g_mass_storage
Jan 1 00:00:13 (none) kernel: g_mass_storage: msd_init() Version: 20111109
Jan 1 00:00:13 (none) kernel: Now registering USB0/func2
Jan 1 00:00:13 (none) kernel: g_mass_storage: msd_bind() Using Major Number 232
Jan 1 00:00:13 (none) kernel: g_mass_storage3: msd_init() Desc: Mass Storage Function
Jan 1 00:00:13 (none) kernel: g_mass_storage3: msd_init() Name: g_mass_storage3
Jan 1 00:00:13 (none) kernel: g_mass_storage3: msd_init() Version: 20111109-3
Jan 1 00:00:13 (none) kernel: Now registering USB0/func3
Jan 1 00:00:13 (none) kernel: g_mass_storage3: msd_bind() Using Major Number 231
Jan 1 00:00:13 (none) kernel: g_mass_storage1: msd_init() Desc: Mass Storage Function
Jan 1 00:00:13 (none) kernel: g_mass_storage1: msd_init() Name: g_mass_storage1
Jan 1 00:00:13 (none) kernel: g_mass_storage1: msd_init() Version: 20111109-1
Jan 1 00:00:13 (none) kernel: Now registering USB0/func4
Jan 1 00:00:13 (none) kernel: g_mass_storage1: msd_bind() Using Major Number 230
Jan 1 00:00:13 (none) kernel: g_mass_storage2: msd_init() Desc: Mass Storage Function
Jan 1 00:00:13 (none) kernel: g_mass_storage2: msd_init() Name: g_mass_storage2
Jan 1 00:00:13 (none) kernel: g_mass_storage2: msd_init() Version: 20111109-2
Jan 1 00:00:13 (none) kernel: Now registering USB0/func5
Jan 1 00:00:13 (none) kernel: g_mass_storage2: msd_bind() Using Major Number 229
Jan 1 00:00:13 (none) kernel: g_mass_storage4: msd_init() Desc: Mass Storage Function
Jan 1 00:00:13 (none) kernel: g_mass_storage4: msd_init() Name: g_mass_storage4
Jan 1 00:00:13 (none) kernel: g_mass_storage4: msd_init() Version: 20111109-4
Jan 1 00:00:13 (none) kernel: Now registering USB0/func6
Jan 1 00:00:13 (none) kernel: g_mass_storage4: msd_bind() Using Major Number 228
SCSI subsystem initialized
Jan 1 00:00:13 (none) kernel: SCSI subsystem initialized
Driver 'sd' needs updating - please use bus_type methods
Jan 1 00:00:14 (none) kernel: Driver 'sd' needs updating - please use bus_type methods
Jan 1 00:00:14 (none) kernel: Initializing USB Mass Storage driver...
Jan 1 00:00:14 (none) kernel: usbcore: registered new interface driver usb-storage
Jan 1 00:00:14 (none) kernel: USB Mass Storage support registered.
start usb drivers version: 1.1.0.3
Sat Jan 1 00:00:14 UTC 2000 To execute command __source /etc/sysapps_script/I_video_drv.sh__
aess_video_init Avocent Video Driver installed
allocate_video_buffer ulEcc_enabled 0x00000000 ulEcd_clock_stop 0x00000000 ulMcr_ecc_enabled 0x00000001
allocate_video_buffer_dynamically- video_buffer_phys: 47000000 video_buffer_size: 0x00EAE000
Jan 1 00:00:14 (none) kernel: aess_video_init Avocent Video Driver installed
Jan 1 00:00:14 (none) kernel: allocate_video_buffer ulEcc_enabled 0x00000000 ulEcd_clock_stop 0x00000000 ulMcr_ecc_enabled 0x00000001
Jan 1 00:00:14 (none) kernel: allocate_video_buffer_dynamically- video_buffer_phys: 47000000 video_buffer_size: 0x00EAE000
Sat Jan 1 00:00:14 UTC 2000 To execute command __/etc/init.d/oem_preinit.sh__
Sat Jan 1 00:00:14 UTC 2000 To execute command __touch /flash/data0/oem_ps/maserinit__
Sat Jan 1 00:00:14 UTC 2000 To execute command __/etc/sysapps_script/credential_vault.sh start__
mke2fs 1.41.14 (22-Dec-2010)
mkdir -p /flash/data0/cv/BNR
Sat Jan 1 00:00:15 UTC 2000 To execute command __/etc/sysapps_script/syslog.sh restart__
Jan 1 00:00:15 (none) exiting on signal 15
waitfor: pid 413, wpid 712
waitfor: pid 413, wpid 714
waitfor: pid 413, wpid 855
Jan 1 00:00:16 (none) syslogd 1.4.2: restart.
Jan 1 00:00:16 (none) kernel: klogd 1.4.2, log source = /proc/kmsg started.
Jan 1 00:00:16 (none) kernel: Cannot find map file.
Jan 1 00:00:16 (none) kernel: No module symbols loaded - kernel modules not enabled.
Jan 1 00:00:16 (none) kernel: cannot find any symbols, turning off symbol lookups
Setting Debug masks to default ...
Debug Level set to: 1 (Critical)
Debug Source set to: 1024 (All Sources)
Debug Output set to: 2 (RAM File (/tmp/idraclogs))
Debug Extra Options set to: 0 (No Extra Options)
IPMI Trace Buffer Stopped
Generic Trace Buffer Stopped
KCSSIRQCR Write OK! -- SIRQCR_SELIRQ10 = 1
KCSSIRQCR Write OK! -- SIRQCR_IRQ10E2 = 1
Sat Jan 1 00:00:17 UTC 2000 To execute command __/etc/sysapps_script/S_3160_create_corepart.sh start__
Core Dump Partition exists
Disk /dev/mmcblk0: 3875 MB, 3875536896 bytes
4 heads, 16 sectors/track, 118272 cylinders
Units = cylinders of 64 * 512 = 32768 bytes
Device Boot Start End Blocks Id System
/dev/mmcblk0p1 * 1 513 16384 83 Linux
Partition 1 does not end on cylinder boundary
/dev/mmcblk0p2 513 4081 114176 0 Empty
Partition 2 does not end on cylinder boundary
/dev/mmcblk0p3 4081 4097 512 0 Empty
Partition 3 does not end on cylinder boundary
/dev/mmcblk0p4 4097 65536 1966079+ 5 Extended
Partition 4 does not end on cylinder boundary
/dev/mmcblk0p5 4097 4609 16384 83 Linux
/dev/mmcblk0p6 4609 8177 114176 0 Empty
/dev/mmcblk0p7 8177 8193 512 0 Empty
/dev/mmcblk0p8 8193 18433 327680 0 Empty
/dev/mmcblk0p9 18433 18561 4096 0 Empty
/dev/mmcblk0p10 18561 18689 4096 0 Empty
/dev/mmcblk0p11 18689 18817 4096 83 Linux
/dev/mmcblk0p12 18817 63937 1443840 83 Linux
/dev/mmcblk0p13 63937 65463 48828 83 Linux
/dev/mmcblk0p14 65463 65527 2048 83 Linux
Core Dump Partition Size = 48828, type =
Checking FS Mounting EXT3-fs warning: mounting fs with errors, running e2fsck is recommended
Jan 1 00:00:18 (none) kernel: kjournald starting. Commit interval 5 seconds
Jan 1 00:00:18 (none) kernel: EXT3-fs warning: mounting fs with errors, running e2fsck is recommended
Jan 1 00:00:18 (none) kernel: EXT3 FS on mmcblk0p13, internal journal
Jan 1 00:00:18 (none) kernel: EXT3-fs: recovery complete.
Jan 1 00:00:18 (none) kernel: EXT3-fs: mounted filesystem with writeback data mode.
done.
FreshAir Partition type = "ext2"
Checking FS Mounting EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended
Jan 1 00:00:18 (none) kernel: EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended
done.
done.
Sat Jan 1 00:00:18 UTC 2000 To execute command __/etc/sysapps_script/S_1000_AIM.sh start__
waitforaim: AIM started sec:946684818 usec:870166 ended: sec:946684819 usec::203475 elapsed:0.333309
Sat Jan 1 00:00:19 UTC 2000 To execute command __/etc/sysapps_script/S_3000_sd_detect.sh start__
Sat Jan 1 00:00:19 UTC 2000 To execute command __/etc/sysapps_script/S_3000_amea_detect.sh start__
AMEA card is present or not
Read CPLD Offset 0x21 Bit 3
Sat Jan 1 00:00:19 UTC 2000 To execute command __/etc/sysapps_script/S_3010_OSInterface.sh start__
Sat Jan 1 00:00:19 UTC 2000 To execute command __/etc/sysapps_script/S_3140_modular_setup.sh start__
mmcblk0: error -84 sending read/write command, response 0x900, card status 0x4000d00
Jan 1 00:00:20end_request: I/O error, dev mmcblk0, sector 1198474
Buffer I/O error on device mmcblk0p11, logical block 1217
lost page write due to I/O error on mmcblk0p11
end_request: I/O error, dev mmcblk0, sector 1198476
Buffer I/O error on device mmcblk0p11, logical block 1218
end_request: I/O error, dev mmcblk0, sector 1198478
Buffer I/O error on device mmcblk0p11, logical block 1219
end_request: I/O error, dev mmcblk0, sector 1198480
Buffer I/O error on device mmcblk0p11, logical block 1220
end_request: I/O error, dev mmcblk0, sector 1198482
Buffer I/O error on device mmcblk0p11, logical block 1221
end_request: I/O error, dev mmcblk0, sector 1198484
Buffer I/O error on device mmcblk0p11, logical block 1222
end_request: I/O error, dev mmcblk0, sector 1198486
Buffer I/O error on device mmcblk0p11, logical block 1223
end_request: I/O error, dev mmcblk0, sector 1198488
Buffer I/O error on device mmcblk0p11, logical block 1224
end_request: I/O error, dev mmcblk0, sector 1198490
Buffer I/O error on device mmcblk0p11, logical block 1225
end_request: I/O error, dev mmcblk0, sector 1198492
Buffer I/O error on device mmcblk0p11, logical block 1226
end_request: I/O error, dev mmcblk0, sector 1198494
end_request: I/O error, dev mmcblk0, sector 1198496
end_request: I/O error, dev mmcblk0, sector 1198498
end_request: I/O error, dev mmcblk0, sector 1198500
end_request: I/O error, dev mmcblk0, sector 1198502
end_request: I/O error, dev mmcblk0, sector 1198504
end_request: I/O error, dev mmcblk0, sector 1198506
end_request: I/O error, dev mmcblk0, sector 1198508
end_request: I/O error, dev mmcblk0, sector 1198510
end_request: I/O error, dev mmcblk0, sector 1198512
end_request: I/O error, dev mmcblk0, sector 1198514
end_request: I/O error, dev mmcblk0, sector 1198516
end_request: I/O error, dev mmcblk0, sector 1198518
end_request: I/O error, dev mmcblk0, sector 1198520
end_request: I/O error, dev mmcblk0, sector 1198522
end_request: I/O error, dev mmcblk0, sector 1198524
end_request: I/O error, dev mmcblk0, sector 1198526
end_request: I/O error, dev mmcblk0, sector 1198528
end_request: I/O error, dev mmcblk0, sector 1198530
end_request: I/O error, dev mmcblk0, sector 1198532
end_request: I/O error, dev mmcblk0, sector 1198534
end_request: I/O error, dev mmcblk0, sector 1198536
end_request: I/O error, dev mmcblk0, sector 1198538
end_request: I/O error, dev mmcblk0, sector 1198540
end_request: I/O error, dev mmcblk0, sector 1198542
end_request: I/O error, dev mmcblk0, sector 1198544
end_request: I/O error, dev mmcblk0, sector 1198546
end_request: I/O error, dev mmcblk0, sector 1198548
end_request: I/O error, dev mmcblk0, sector 1198550
end_request: I/O error, dev mmcblk0, sector 1198552
end_request: I/O error, dev mmcblk0, sector 1198554
end_request: I/O error, dev mmcblk0, sector 1198556
end_request: I/O error, dev mmcblk0, sector 1198558
end_request: I/O error, dev mmcblk0, sector 1198560
(none) kernel: mmcblk0: error -84 sending read/write command, response 0x900, card status 0x4000d00
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198474
Jan 1 00:00:20 (none) kernel: Buffer I/O error on device mmcblk0p11, logical block 1217
Jan 1 00:00:20 (none) kernel: lost page write due to I/O error on mmcblk0p11
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198476
Jan 1 00:00:20 (none) kernel: Buffer I/O error on device mmcblk0p11, logical block 1218
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198478
Jan 1 00:00:20 (none) kernel: Buffer I/O error on device mmcblk0p11, logical block 1219
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 119848sh_mmcif: Cmd(d'25) err
0
Jan 1 00:00mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
:20 (none) kerneend_request: I/O error, dev mmcblk0, sector 1199126
l: Buffer I/O ersh_mmcif: Cmd(d'25) err
ror on device mmmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
cblk0p11, logicaend_request: I/O error, dev mmcblk0, sector 1200282
end_request: I/O error, dev mmcblk0, sector 1200284
end_request: I/O error, dev mmcblk0, sector 1200286
end_request: I/O error, dev mmcblk0, sector 1200288
end_request: I/O error, dev mmcblk0, sector 1200290
end_request: I/O error, dev mmcblk0, sector 1200292
end_request: I/O error, dev mmcblk0, sector 1200294
end_request: I/O error, dev mmcblk0, sector 1200296
end_request: I/O error, dev mmcblk0, sector 1200298
end_request: I/O error, dev mmcblk0, sector 1200300
end_request: I/O error, dev mmcblk0, sector 1200302
end_request: I/O error, dev mmcblk0, sector 1200304
end_request: I/O error, dev mmcblk0, sector 1200306
end_request: I/O error, dev mmcblk0, sector 1200308
end_request: I/O error, dev mmcblk0, sector 1200310
end_request: I/O error, dev mmcblk0, sector 1200312
end_request: I/O error, dev mmcblk0, sector 1200314
end_request: I/O error, dev mmcblk0, sector 1200316
end_request: I/O error, dev mmcblk0, sector 1200318
end_request: I/O error, dev mmcblk0, sector 1200320
end_request: I/O error, dev mmcblk0, sector 1200322
end_request: I/O error, dev mmcblk0, sector 1200324
end_request: I/O error, dev mmcblk0, sector 1200326
end_request: I/O error, dev mmcblk0, sector 1200328
end_request: I/O error, dev mmcblk0, sector 1200330
end_request: I/O error, dev mmcblk0, sector 1200332
end_request: I/O error, dev mmcblk0, sector 1200334
end_request: I/O error, dev mmcblk0, sector 1200336
end_request: I/O error, dev mmcblk0, sector 1200338
end_request: I/O error, dev mmcblk0, sector 1200340
end_request: I/O error, dev mmcblk0, sector 1200342
end_request: I/O error, dev mmcblk0, sector 1200344
end_request: I/O error, dev mmcblk0, sector 1200346
end_request: I/O error, dev mmcblk0, sector 1200348
end_request: I/O error, dev mmcblk0, sector 1200350
end_request: I/O error, dev mmcblk0, sector 1200352
end_request: I/O error, dev mmcblk0, sector 1200354
end_request: I/O error, dev mmcblk0, sector 1200356
end_request: I/O error, dev mmcblk0, sector 1200358
end_request: I/O error, dev mmcblk0, sector 1200360
end_request: I/O error, dev mmcblk0, sector 1200362
end_request: I/O error, dev mmcblk0, sector 1200364
end_request: I/O error, dev mmcblk0, sector 1200366
end_request: I/O error, dev mmcblk0, sector 1200368
end_request: I/O error, dev mmcblk0, sector 1200370
end_request: I/O error, dev mmcblk0, sector 1200372
end_request: I/O error, dev mmcblk0, sector 1200374
end_request: I/O error, dev mmcblk0, sector 1200376
end_request: I/O error, dev mmcblk0, sector 1200378
end_request: I/O error, dev mmcblk0, sector 1200380
end_request: I/O error, dev mmcblk0, sector 1200382
end_request: I/O error, dev mmcblk0, sector 1200384
end_request: I/O error, dev mmcblk0, sector 1200386
end_request: I/O error, dev mmcblk0, sector 1200388
end_request: I/O error, dev mmcblk0, sector 1200390
end_request: I/O error, dev mmcblk0, sector 1200392
end_request: I/O error, dev mmcblk0, sector 1200394
end_request: I/O error, dev mmcblk0, sector 1200396
end_request: I/O error, dev mmcblk0, sector 1200398
end_request: I/O error, dev mmcblk0, sector 1200400
end_request: I/O error, dev mmcblk0, sector 1200402
end_request: I/O error, dev mmcblk0, sector 1200404
end_request: I/O error, dev mmcblk0, sector 1200406
end_request: I/O error, dev mmcblk0, sector 1200408
end_request: I/O error, dev mmcblk0, sector 1200410
end_request: I/O error, dev mmcblk0, sector 1200412
end_request: I/O error, dev mmcblk0, sector 1200414
end_request: I/O error, dev mmcblk0, sector 1200416
end_request: I/O error, dev mmcblk0, sector 1200418
end_request: I/O error, dev mmcblk0, sector 1200420
end_request: I/O error, dev mmcblk0, sector 1200422
end_request: I/O error, dev mmcblk0, sector 1200424
end_request: I/O error, dev mmcblk0, sector 1200426
end_request: I/O error, dev mmcblk0, sector 1200428
end_request: I/O error, dev mmcblk0, sector 1200430
end_request: I/O error, dev mmcblk0, sector 1200432
end_request: I/O error, dev mmcblk0, sector 1200434
end_request: I/O error, dev mmcblk0, sector 1200436
end_request: I/O error, dev mmcblk0, sector 1200438
end_request: I/O error, dev mmcblk0, sector 1200440
end_request: I/O error, dev mmcblk0, sector 1200442
end_request: I/O error, dev mmcblk0, sector 1200444
end_request: I/O error, dev mmcblk0, sector 1200446
end_request: I/O error, dev mmcblk0, sector 1200448
end_request: I/O error, dev mmcblk0, sector 1200450
end_request: I/O error, dev mmcblk0, sector 1200452
end_request: I/O error, dev mmcblk0, sector 1200454
end_request: I/O error, dev mmcblk0, sector 1200456
end_request: I/O error, dev mmcblk0, sector 1200458
end_request: I/O error, dev mmcblk0, sector 1200460
end_request: I/O error, dev mmcblk0, sector 1200462
end_request: I/O error, dev mmcblk0, sector 1200464
end_request: I/O error, dev mmcblk0, sector 1200466
end_request: I/O error, dev mmcblk0, sector 1200468
end_request: I/O error, dev mmcblk0, sector 1200470
end_request: I/O error, dev mmcblk0, sector 1200472
end_request: I/O error, dev mmcblk0, sector 1200474
end_request: I/O error, dev mmcblk0, sector 1200476
end_request: I/O error, dev mmcblk0, sector 1200478
end_request: I/O error, dev mmcblk0, sector 1200480
end_request: I/O error, dev mmcblk0, sector 1200482
end_request: I/O error, dev mmcblk0, sector 1200484
end_request: I/O error, dev mmcblk0, sector 1200486
end_request: I/O error, dev mmcblk0, sector 1200488
l block 1220
JJBD: Detected IO errors while flushing file data on mmcblk0p11
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198482
Jan 1 00:00:20 (none) kernel: Buffer I/O error on device mmcblk0p11, logical block 1221
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198484
Jan 1 00:00:20 (none) kernel: Buffer I/O error on device mmcblk0p11, logical block 1222
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198486
Jan 1 00:00:20 (none) kernel: Buffer I/O error on device mmcblk0p11, logical block 1223
Jan 1 00:00:20 (none) kesh_mmcif: Cmd(d'18) err
rnel: lost page mmcblk0: retrying using single block read
write due to I/Osh_mmcif: Cmd(d'17) err
error on mmcblkmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
0p11
Jan 1 00end_request: I/O error, dev mmcblk0, sector 1202190
:00:20 (none) kesh_mmcif: Cmd(d'17) err
rnel: end_requesmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
t: I/O error, deend_request: I/O error, dev mmcblk0, sector 1202191
Jan 1 00:00sh_mmcif: Cmd(d'25) err
:20 (none) kernemmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
l: Buffer I/O erend_request: I/O error, dev mmcblk0, sector 1196408
end_request: I/O error, dev mmcblk0, sector 1196410
end_request: I/O error, dev mmcblk0, sector 1196412
end_request: I/O error, dev mmcblk0, sector 1196414
end_request: I/O error, dev mmcblk0, sector 1196416
end_request: I/O error, dev mmcblk0, sector 1196418
end_request: I/O error, dev mmcblk0, sector 1196420
end_request: I/O error, dev mmcblk0, sector 1196422
end_request: I/O error, dev mmcblk0, sector 1196424
end_request: I/O error, dev mmcblk0, sector 1196426
end_request: I/O error, dev mmcblk0, sector 1196428
end_request: I/O error, dev mmcblk0, sector 1196430
end_request: I/O error, dev mmcblk0, sector 1196432
end_request: I/O error, dev mmcblk0, sector 1196434
ror on device mmAborting journal on device mmcblk0p11.
cblk0p11, logicash_mmcif: Cmd(d'25) err
l block 1224
Jmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
an 1 00:00:20 (end_request: I/O error, dev mmcblk0, sector 1196364
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198490
Jan 1 00:00:20 (none) kernel: Buffer I/O error on device mmcblk0p11, logical block 1225
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198492
Jan 1 00:00:20 (none) kernel: Buffer I/O error on device mmcblk0p11, logical block 1226
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198494
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198496
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198498
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198500
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198502
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198504
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198506
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198508
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198510
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198512
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198514
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198516
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198518
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198520
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198522
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198524
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblkext3_abort called.
0, sector 119852EXT3-fs error (device mmcblk0p11): ext3_journal_start_sb: 6
Jan 1 00:00Detected aborted journal:20 (none) kerne
l: end_request: Remounting filesystem read-only
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198530
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198532
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198534
Jan 1 00:00:20 sh_mmcif: Cmd(d'18) err
(none) kernel: emmcblk0: retrying using single block read
nd_request: I/O sh_mmcif: Cmd(d'17) err
error, dev mmcblmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
k0, sector 11985end_request: I/O error, dev mmcblk0, sector 1202206
36
Jan 1 00:0sh_mmcif: Cmd(d'17) err
0:20 (none) kernmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
el: end_request:end_request: I/O error, dev mmcblk0, sector 1202207
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198540
Jan 1 00sh_mmcif: Cmd(d'18) err
:00:20 (none) kemmcblk0: retrying using single block read
rnel: end_requessh_mmcif: Cmd(d'17) err
t: I/O error, dev mmcblkmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
0, sector 119854end_request: I/O error, dev mmcblk0, sector 1202198
2
Jan 1 00:00sh_mmcif: Cmd(d'17) err
:20 (none) kernel: end_request: I/O errommcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
r, dev mmcblk0, end_request: I/O error, dev mmcblk0, sector 1202199
sector 1198544
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198546
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198548
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198550
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198552
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198554
SLED NOT PRESENT
Jan 1 00:00:20 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198556
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198558
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1198560
Jan 1 00:00:21 (none) kernel: sh_mmcif: Cmd(d'25) err
Jan 1 00:00:21 (none) kernel: mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1199126
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200282
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200284
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200286
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200288
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sectorsh_mmcif: Cmd(d'18) err
1200290
Jan mmcblk0: retrying using single block read
1 00:00:21 (nonesh_mmcif: Cmd(d'17) err
) kernel: end_remmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
quest: I/O errorend_request: I/O error, dev mmcblk0, sector 1202190
, dev mmcblk0, ssh_mmcif: Cmd(d'17) err
ector 1200292
Jan 1 00:00:21 end_request: I/O error, dev mmcblk0, sector 1202191
(none) kernel: end_request: I/O error, dev mmcblk0, sector 1200294
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200296
Jan 1 00:00:21 (none) kernel: end_request: I/O error,sh_mmcif: Cmd(d'18) err
dev mmcblk0, semmcblk0: retrying using single block read
ctor 1200298
Jsh_mmcif: Cmd(d'17) err
an 1 00:00:21 (mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
none) kernel: enend_request: I/O error, dev mmcblk0, sector 1202190
d_request: I/O esh_mmcif: Cmd(d'17) err
0, sector 120030end_request: I/O error, dev mmcblk0, sector 1202191
0
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200302
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200304
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200306
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200308
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200310
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200312
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200314
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200316
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200318
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200320
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200322
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200324
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200326
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200328
Sat Jan 1 00:00:21 UTC 2000 To execute command __/etc/sysapps_script/S_3160_create_scratch.sh start__
Checking Scratchpad Partition... sh_mmcif: Cmd(d'18) err
end_request: I/O error, dev mmcblk0, sector 524293
end_request: I/O error, dev mmcblk0, sector 524294
end_request: I/O error, dev mmcblk0, sector 524295
end_request: I/O error, dev mmcblk0, sector 524296
Jan 1 00:00:21 (none) kernel: end_request: I/Osh_mmcif: Cmd(d'17) err
error, dev mmcbmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
lk0, sector 1200end_request: I/O error, dev mmcblk0, sector 524297
330
Jan 1 00:00:21 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200332
Jan 1 00:00:21 (none) kernel: end_request: Ish_mmcif: Cmd(d'17) err
/O error, dev mmmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
cblk0, sector 12end_request: I/O error, dev mmcblk0, sector 524298
00334
Jan 1 0sh_mmcif: Cmd(d'17) err
0:00:21 (none) kmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
ernel: end_requeend_request: I/O error, dev mmcblk0, sector 524299
st: I/O error, dsh_mmcif: Cmd(d'17) err
ev mmcblk0, sectmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
or 1200336
Janend_request: I/O error, dev mmcblk0, sector 524300
1 00:00:21 (nosh_mmcif: Cmd(d'17) err
ne) kernel: end_mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
request: I/O errend_request: I/O error, dev mmcblk0, sector 524301
or, dev mmcblk0,sh_mmcif: Cmd(d'17) err
Jan 1 00:00:2end_request: I/O error, dev mmcblk0, sector 524302
1 (none) kernel: end_request: I/O error, dev mmcblk0, sector 120sh_mmcif: Cmd(d'17) err
0340
Jan 1 00:00:22 (none) kernel: end_request: I/O emmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
rror, dev mmcblkend_request: I/O error, dev mmcblk0, sector 524303
0, sector 120034sh_mmcif: Cmd(d'17) err
2
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
end_request: I/O error, dev mmcblk0, sector 524304
Jan 1 00:00:22sh_mmcif: Cmd(d'17) err
end_request: I/Oend_request: I/O error, dev mmcblk0, sector 524305
error, dev mmcbsh_mmcif: Cmd(d'17) err
lk0, sector 1200mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
346
Jan 1 00:end_request: I/O error, dev mmcblk0, sector 524306
00:22 (none) kersh_mmcif: Cmd(d'17) err
nel: end_requestmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
: I/O error, devend_request: I/O error, dev mmcblk0, sector 524307
mmcblk0, sector 1200348sh_mmcif: Cmd(d'17) err
Jan 1 00:00:mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
22 (none) kernelend_request: I/O error, dev mmcblk0, sector 524308
: end_request: I/O error, dev mmcblk0, sector 1200350
Jan 1 00:00:22 (none) kernel: end_request: I/O sh_mmcif: Cmd(d'17) err
error, dev mmcblk0, sectmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
or 1200352
Janend_request: I/O error, dev mmcblk0, sector 524309
1 00:00:22 (nosh_mmcif: Cmd(d'17) err
ne) kernel: end_request: I/O error, dev mmcblk0, sector 1200354
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200356
Jan 1 00:00:22 (mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
none) kernel: enend_request: I/O error, dev mmcblk0, sector 524310
Jan 1 00:00:22 (none) kernel: end_rmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
equest: I/O erroend_request: I/O error, dev mmcblk0, sector 524311
r, dev mmcblk0, sh_mmcif: Cmd(d'17) err
Jan 1 00:00:22end_request: I/O error, dev mmcblk0, sector 524312
(none) kernel: sh_mmcif: Cmd(d'17) err
end_request: I/Ommcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
error, dev mmcbend_request: I/O error, dev mmcblk0, sector 524313
lk0, sector 1200sh_mmcif: Cmd(d'17) err
362
Jan 1 00:mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
00:22 (none) kerend_request: I/O error, dev mmcblk0, sector 524314
nel: end_requestsh_mmcif: Cmd(d'17) err
: I/O error, devmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
mmcblk0, sectorend_request: I/O error, dev mmcblk0, sector 524315
1200364
Jan sh_mmcif: Cmd(d'17) err
1 00:00:22 (nonemmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
) kernel: end_reend_request: I/O error, dev mmcblk0, sector 524316
quest: I/O errorsh_mmcif: Cmd(d'17) err
, dev mmcblk0, smmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
ector 1200366
end_request: I/O error, dev mmcblk0, sector 524317
Jan 1 00:00:22 sh_mmcif: Cmd(d'17) err
(none) kernel: emmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
nd_request: I/O end_request: I/O error, dev mmcblk0, sector 524318
error, dev mmcblsh_mmcif: Cmd(d'17) err
k0, sector 12003mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
68
Jan 1 00:0end_request: I/O error, dev mmcblk0, sector 524319
0:22 (none) kernsh_mmcif: Cmd(d'17) err
el: end_request:mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
I/O error, dev end_request: I/O error, dev mmcblk0, sector 524320
mmcblk0, sector sh_mmcif: Cmd(d'17) err
1200370
Jan 1mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
00:00:22 (none)end_request: I/O error, dev mmcblk0, sector 524321
kernel: end_reqsh_mmcif: Cmd(d'17) err
uest: I/O error,mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
dev mmcblk0, seend_request: I/O error, dev mmcblk0, sector 524322
ctor 1200372
none) kernel: enend_request: I/O error, dev mmcblk0, sector 524323
0, sector 120037end_request: I/O error, dev mmcblk0, sector 524324
4
Jan 1 00:00sh_mmcif: Cmd(d'18) err
:22 (none) kernemmcblk0: retrying using single block read
l: end_request: sh_mmcif: Cmd(d'17) err
I/O error, dev mmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
mcblk0, sector 1end_request: I/O error, dev mmcblk0, sector 524293
200376
Jan 1 sh_mmcif: Cmd(d'17) err
00:00:22 (none) mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
kernel: end_requend_request: I/O error, dev mmcblk0, sector 524294
est: I/O error, sh_mmcif: Cmd(d'17) err
dev mmcblk0, secmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
tor 1200378
Jaend_request: I/O error, dev mmcblk0, sector 524295
n 1 00:00:22 (nsh_mmcif: Cmd(d'17) err
one) kernel: endmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
_request: I/O erend_request: I/O error, dev mmcblk0, sector 524296
ror, dev mmcblk0sh_mmcif: Cmd(d'17) err
, sector 1200380mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
Jan 1 00:00:end_request: I/O error, dev mmcblk0, sector 524297
22 (none) kernelsh_mmcif: Cmd(d'17) err
: end_request: Immcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
/O error, dev mmend_request: I/O error, dev mmcblk0, sector 524298
cblk0, sector 12sh_mmcif: Cmd(d'17) err
00382
Jan 1 0mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
0:00:22 (none) kend_request: I/O error, dev mmcblk0, sector 524299
ernel: end_requesh_mmcif: Cmd(d'17) err
st: I/O error, dmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
ev mmcblk0, sectend_request: I/O error, dev mmcblk0, sector 524300
or 1200384
Jansh_mmcif: Cmd(d'18) err
1 00:00:22 (nommcblk0: retrying using single block read
ne) kernel: end_sh_mmcif: Cmd(d'17) err
request: I/O errmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
or, dev mmcblk0,end_request: I/O error, dev mmcblk0, sector 1196128
Jan 1 00:00:2mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
2 (none) kernel:end_request: I/O error, dev mmcblk0, sector 1196129
end_request: I/EXT3-fs error (device mmcblk0p11): ext3_get_inode_loc: O error, dev mmcunable to read inode block - inode=195, block=44blk0, sector 120
0388
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200390
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200392
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200394
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200396
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200398
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200400
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200402
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200404
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200406
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200408
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200410
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200412
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200414
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200416
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200418
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200420
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200422
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200424
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200426
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200428
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200430
Jan 1 00:00:22 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1200432
I let it do its thing, and eventually I got a shell that quickly got away with more errors, but I can still access it even though there are a lot more of the I/O errors:
Jan 1 00:13:55 (none) kernel: mmcblk0: retrying using single block read
Jan 1 00:13:55 (none) kernel: sh_mmcif: Cmd(d'17) err
Jan 1 00:13:55 (none) kernel: mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
Jan 1 00:13:55 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1196158
Jan 1 00:13:55 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1196159
Jan 1 00:13:55 (none) kernel: EXT3-fs error (device mmcblk0p11): ext3_get_inode_loc: unable to read inode block - inode=315, block=59
Jan 1 00:13:56 (none) kernel: sh_mmcif: Cmd(d'18) err
Jan 1 00:13:56 (none) kernel: mmcblk0: retrying using single block read
Jan 1 00:13:56 (none) kernel: sh_mmcif: Cmd(d'17) err
Jan 1 00:13:56 (none) kernel: mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
Jan 1 00:13:56 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1196158
Jan 1 00:13:56 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1196159
Jan 1 00:13:56 (none) kernel: EXT3-fs error (device mmcblk0p11): ext3_get_inode_loc: unable to read inode block - inode=319, block=59
starting pid 6871, tty '': '-/bin/sh'
[SH7757 ~]$ help
-/bin/sh: help: not found
[SH7757 ~]$ ls
avct flash linuxrc mmc1 share usr
bin home man mnt ssl var
dev lib maser-zip proc sys
etc libexec messages sbin tmp
[SH7757 ~]$ Restarting /bin/fullfw
ln: ./NVRAM_SEL00.dat: File exists
ln: ./ThermalConfig.txt: File exists
ln: ./ThermalData.txt: File exists
ln: ./bmcsetting: File exists
ln: ./NVRAM_SDR00.dat: File exists
ln: ./drvsetting.dat: File exists
Jan 1 00:14:25mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
(none) kernel: end_request: I/O error, dev mmcblk0, sector 1196134
This is what I was able to do in a moment of silence from the errors:
id
uid=0(root) gid=0(root)
[SH7757 ~]$ w
-/bin/sh: w: not found
[SH7757 ~]$ whoami
root
[SH7757 ~]$ ls
[SH7757 ~]$
AppMonitor ldapsearch
AppThermalSHM length
CompressTest less
DM_PowerTest.sh libfst
IPMICmd lmtest32
MemAccess lmtest32.5.9.3.3999
MemAccess2 ln
MemTest logger
NL_send login
NL_test logname
RAIDTest logsave
SharedMemApp logtest
SysStatus loguboot
[ losetup
[[ ls
addgroup lsattr
adduser lsmod
adjtimex lzcat
aim lzma
ap-req mapitest
ar md5sum
arp mdev
arping mem_usage.sh
ash memusage
avct_control mesg
avct_server mib2c
avct_util mib2c-update
avct_wsman mkdir
awk mkdosfs
badblocks mke2fs
basename mkfifo
bash mkfs.ext2
biospostap mkfs.ext3
blkid mkfs.ext4
brorch mkfs.ext4dev
brview mkfs.minix
brvrfyapp mkfs.msdos
buildcache mkfs.vfat
bunzip2 mklost+found
busybox mknod
bzcat mkpasswd
bzip2 mkswap
cal mmc_stats
cat modinfo
catv modprobe
chattr more
check_ldap_user mount
check_user mount.cifs
chgrp mrbindump32
chmod mrbindump32.5.9.3.3999
chown mrcached32
chpasswd mrcached32.5.9.3.3999
chpst mrtst32
chroot mrtst32.5.9.3.3999
chrt mv
chvt nameif
cksum nc
clear ncsiapptest
clpd ndcmactest
clphelp.txt net-snmp-config
cmcServer netstat
cmp nice
comm nicinvapp
connect nmeter
copy_cred_cache nohup
cp nslookup
cpio nsupdate
cpu_usage.sh od
crond openssl
cryptpw openwsmand
cut osdinst
date osdtest
dcecfg32 passwd
dcecfg32.5.9.3.3999 patch
dcetst32 pgrep
dcetst32.5.9.3.3999 pidof
dcicfg32 ping
dcicfg32.5.9.3.3999 ping6
dcitst32 pivot_root
dcitst32.5.9.3.3999 pkill
dcsexecute pluginviewer
dd portmap
debugcontrol poweroff
debugfs printenv
delgroup printf
dellutil proc_mem_usage.sh
deluser ps
depmod pscan
df pwd
dhcp6c pwrsim
dhcprelay racadm
diff raclogclear
dirname raclogd
dlogrotate re_x_dload
dmesg read_id_devid
dmsetup readcfg
dnsd readvmaccfg
dnsdomainname realpath
dos2unix reboot
dosfsck redownloader
dpkg refpop32
dpkg-deb refpop32.5.9.3.3999
dsm_dataeng.sh renice
dsm_dataeng_prestart.sh reset
dsm_dataeng_stage2.sh resize
dsm_report_resource_usage.sh resize2fs
dsm_sa_datamgr32d rm
dsm_sa_datamgr32d.5.9.3.3999 rmdir
dsm_sa_eventmgr32d rmmod
dsm_sa_eventmgr32d.5.9.3.3999 route
dsm_sa_snmp32d rpm
dsm_sa_snmp32d.5.9.3.3999 rpm2cpio
dsm_start runlevel
du runsv
dumpe2fs runsvdir
dumpleases saslauthd
e2freefrag schema.conf
e2fsck scp
e2image sed
e2label sem_usage.sh
e2undo sendlcd
echo seq
ed setuidgid
egrep sfcbd
encode_keychange sfcbdump
env sfcbinst2mof
envdir sfcbmof
envuidgid sfcbmofpp
ether-wake sfcbrepos
ethtool sfcbstage
ex_free sfcbunstage
expand sfcbuuid
expr sftp
fakeidentd sh
false sha1sum
fd_usage.sh shmread
fdisk shmwrite
fgrep slattach
filefrag sleep
find slogin
findfs snmpbulkget
fixproc snmpbulkwalk
flash_erase snmpcheck
flash_eraseall snmpconf
flock snmpd
fold snmpdelta
free snmpdf
freeramdisk snmpget
fsck snmpgetnext
fsck.ext2 snmpinform
fsck.ext3 snmpnetstat
fsck.ext4 snmpset
fsck.ext4dev snmpstatus
fsck.minix snmptable
fsck.msdos snmptest
fsck.vfat snmptranslate
ftpget snmptrap
ftpput snmptrapd
fullfw snmpusm
fuser snmpvacm
fw_printenv snmpwalk
fw_setenv softlimit
fwtool sort
generate-requests split
getDMstatus ssh
getfwver.sh ssh-add
getty ssh-agent
gpg ssh-keygen
grep ssh-keyscan
gunzip sshd
gzip stat
halt stty
hd su
head sulogin
hexdump sum
hiipoptest sv
hostid svlogd
hostname switch_root
httpd sync
hwinvapp sysctl
id syslogd
idrac_discovery tail
idrac_performance.sh tar
ifconfig tcpdump
ifenslave tcpsvd
ifplugd tee
ifplugstatus telnet
inetd telnetd
init test
insmod test_krb_aaa
ip test_mon
ip2dns testsasl
ip6tables testsaslauthd
ip6tables-multi tftp
ip6tables-restore throttle.sh
ip6tables-save tkmib
ipaddr top
ipcalc touch
ipcrm tr
ipcs trabdump
ipf-mod.pl traceroute
iplink traceroute6
ipmiSystemCallAgent traptoemail
ipmi_cmds_list true
ipmi_gateway tty
ipmi_response.sh ttymonitor
ipmiextd tune2fs
iproute udevadm
iprule udevd
ipstd udhcpc
iptables udhcpd
iptables-multi udpsvd
iptables-restore umount
iptables-save umount.cifs
iptables-xml uname
iptunnel uncompress
jcancel unexpand
jcancelSSM uniq
jcstore unix2dos
jdaemon unlzma
jdctrl unzip
jdefault uptime
jexec usleep
jmonitor uudecode
jpop uuencode
jreboot uuidd
jstart_backup uuidgen
jstart_restore vconfig
jstatus vfctrl
jupdate vfk
jvalidate vi
kdecode_ticket vkvm_pm
kdestroy vlock
kdigest watch
kgetcred watchdog
kill wbemcat
killall wc
killall5 wget
kimpersonate which
kinit who
klist whoami
klogd writecfg
kswitch xargs
kverify xmltest
lcllibtest yes
ldapbind zcat
ldapbind5 zcip
[SH7757 ~]$
Partitions
[SH7757 ~]$ cat /proc/partitions
major minor #blocks name
7 6 1024 loop6
31 0 512 mtdblock0
31 1 512 mtdblock1
31 2 64 mtdblock2
31 3 64 mtdblock3
31 4 64 mtdblock4
31 5 64 mtdblock5
31 6 512 mtdblock6
31 7 1536 mtdblock7
31 8 768 mtdblock8
179 0 3784704 mmcblk0
179 1 16384 mmcblk0p1
179 2 114176 mmcblk0p2
179 3 512 mmcblk0p3
179 4 1 mmcblk0p4
179 5 16384 mmcblk0p5
179 6 114176 mmcblk0p6
179 7 512 mmcblk0p7
179 8 327680 mmcblk0p8
179 9 4096 mmcblk0p9
179 10 4096 mmcblk0p10
179 11 4096 mmcblk0p11
179 12 1443840 mmcblk0p12
179 13 48828 mmcblk0p13
179 14 2048 mmcblk0p14
179 16 7999488 mmcblk1
179 17 7998464 mmcblk1p1
254 0 1000 dm-0
I tried running fsck on one of the partitions, but it failed:
[SH7757 ~]$ fsck.ext3 -f /dev/mmcblk0p11
/dev/mmcblk0p11 is mounted.
WARNING!!! The filesystem is mounted. If you continue you ***WILL***
cause ***SEVERE*** filesystem damage.
Do you really want to continue (y/n)? yes
end_request: I/O error, dev mmcblk0, sector 1196040
Jan 1 01:49:57 (none) sh_mmcif: Cmd(d'17) err
kernel: sh_mmcifmmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
end_request: I/O error, dev mmcblk0, sector 1196041
Buffer I/O error on device mmcblk0p11, logical block 0
Jan 1 01:49:57 (none) kernel:sh_mmcif: Cmd(d'18) err
mmcblk0: retryimmcblk0: retrying using single block read
ng using single block resh_mmcif: Cmd(d'17) err
ad
Jan 1 01:49:57 (nommcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
ne) kernel: sh_mend_request: I/O error, dev mmcblk0, sector 1196046
mcif: Cmd(d'17) err
Jan 1 01:sh_mmcif: Cmd(d'17) err
49:57 (none) kernel: mmcblk0: error -84 sending read/write command, response 0x0, card smmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
tatus 0xd00
Jaend_request: I/O error, dev mmcblk0, sector 1196047
Buffer I/O error on device mmcblk0p11, logical block 3
n 1 01:49:57 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1196040
Jan 1 01:49:57 (none) kernel: sh_mmcif: Cmd(d'17) err
Jan 1 01:49:57 (none) kernel: mmcblk0: error -84 sending read/write command, response 0x0, card status 0xd00
Jan 1 01:49:57 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1196041
Jan 1 01:49:57 (none) kernel: Buffer I/O error on device mmcblk0p11, logical block 0
Jan 1 01:49:57 (none) kernel: sh_mmcif: Cmd(d'18) err
Jan 1 01:49:57 (none) kernel: mmcblk0: retrying using single block read
Jan 1 01:49:57 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1196046
Jan 1 01:49:57 (none) kernel: end_request: I/O error, dev mmcblk0, sector 1196047
Jan 1 01:49:57 (none) kernel: Buffer I/O error on device mmcblk0p11, logical block 3
fsck.ext3: Attempt to read block from filesystem resulted in short read while trying to open /dev/mmcblk0p11
Could this be a zero-length partition?
[SH7757 ~]$
Any idea if this situation can be salvaged? I really do not want to buy a new motherboard if everything else is working just fine and I can still boot into an OS and everything. But I really want to have iDRAC working.
Thank you!
Thanks for this thread, my R730 have the same problem.
After power on, the IDRAC LED have no action, also the lan LED, full speed fan after bootup.
Update BIOS to the latest version still the same.
Then I follow the thread, solder a 4pin 2.54mm connector on the motherboard, connecte an UART to USB adapter on.
It’s lucky that the IDRAC stop at u-boot env, because the bad emmc, no need to try something to stop at U-boot stage.
Then I set the command to update firmimg.d7 from SD card, but still stop at emmc reading, maybe the emmc is broken. I have to replace the emmc with a new one(before this I checked that my IDRAC have no enterprise license, so just replace no more action need).
After firming.D7 updated to the fresh emmc, reboot, it works, but there are some information lost: have no Tag info, I wonder that my update is not sucess.
Later, I boot the system to BIOS, the Tag info back to iDrac automaticly, wow, then the system just quiet as before, many thanks to everyone to this thread.
I have a T430 that has a basic IDRAC with no external card. Is it still possible to fix this via UART cable? There’s absolutely no light blinking, not even amber. The server gets stuck at initializing IDRAC.
