[Problem] Extraction of an HP BIOS .EXE File
Using the AMIUCP extract the ID @R00 from the 083C6F24.exe, resulted of the sp139780.exe
EDIT: Well my friend, signatures files and other are present as you can see with the tool, that’s your task to look for them, not me and my time, im sure you clearly understand this…all the best and good luck.
Thank you. I sort of figured that part out (although I wasn’t sure and could use the confirmation). But how do I get the signature file? (I think that’s mandatory to be present along the binary for an update.) There are several small size sections in there.
Edit: Well, I didn’t expect you to figure that out for me from scratch but I expected somebody (you or others here) might do so already (or at least can give me some tips on how to).
As it turns out, the block right above it (S00) was the one. And the files were accepted as 08324.bin and 08324.s12 (I figured this out by looking at file names from earlier installers: the first 3 digits are probably the first digits of the board ID and the last 2 are the version number of the binary).
Heya,
I’m currently trying to fix a broken BIOS on a HP desktop PC (see thread [Problem] HowTo Fix HP Z2 Mini G9 Workstation BIOS Issue? ).
My question is if it’s possible to prepare a downloaded .BIN file from HPs website for directly flashing to the chip? When looking at the two .BIN files, one downloaded and one I dumped, the downloaded one is around 2MB smaller than the dumped one. The downloaded .BIN also seems to contain data way earlier when looking at it with a HEX editor, and is zero’d out in the beginning where as my dumped one is filled with FF till a few pages down.
I’d also have to edit the BIOS and add the serial number from my understanding, however correct me if I’m wrong.
On top of everything there are 2 chips on this mainboard, one for the BIOS and one for Intel ME. However HP only provides one update package with just one .BIN inside.
Thanks already for your help!
Edit by Fernando Thread title customized
If you want to modify an HP BIOS, you have to download the offered *.exe installer and to extract the included *.bin file as first step, but the real problem begins while trying to flash the modded BIOS.
Yeah, the .BIN extraction was easy, just the preparation for flashing is the hard part now :sweat_smile:
Hi, I need help with finding the correct .bin file in the .exe that I downloaded from hps website to use a ch341a programmer to write to the chip. In the .exe, there is .bin file labelled T77_01210000 but it is shown as 35,748KB which is higher than the 32MB capacity of the chip.
(HP Elite book X360 830 g8, Winbond 25Q256JVEN)
You can try to reconstruct it from your original dump and replacing volumes from HP file.
what do you mean by original dump? is that the bios file thats already on the chip? if so, the bios file on the chip is corrupted and may not be able to do that
What kind of question is that if you intend to use a SPI programmer…of course that it’s the reading from the IC.
Corruption has a certain degree… and the original HP system data is there.
It will be lost forever if overwritten…your call.
Did you even bother to explain what happened to the system…
A lot of info on similar HP recovery’s on the forum… enjoy the reading, good luck.
Could somebody please help me extract the binary and signature files from this installer? sp155621 idk how to do the limk
Run the package and select “Copy bios image…”
For full unpacked content, the Windows Temp folder is also a source.
Dont know what you’re trying to achieve…on modern HP bioses…but you need to know your platform ID.
I did that but got a lot of bins and none of them have work
I just need the bin to sp155621.exe im trying to flash a new bio to my bios chip but have tried everything to get the bin but I can’t
If you could get the .bin bios from that specific one it would be awesome
Sir…again…YOU NEED TO KNOW YOUR HARDWARE PLATFORM ID, we are not “Wizards” here to know what model of “Washing machine” you’re dealing with.
HP SP packages serves various models with same bios code, usually the device support page can show the ID…not always.
There’s no specific one or ONLY one in the package, as you already know so why the stupid persistent question.
7 posts were merged into an existing topic: [Problem] Extraction of the pure BIOS from an HP EXE file
@sauce @MeatWar
Yesterday I have merged 2 threads about the same topic, but unfortunately the Forum Software disregarded the chronological order of the posts. Your recent posts are present within this thread, but not at the end as it should be.
I am sorry about that and hope, that this issue will be solved very soon by an update of the Forum software.
@wendell
Just for your information
Edit by Fernando:
Meanwhile I was able to get all merged posts with the correct chronogical order.
