[Problem] Extraction of ASRock H110m-HDV BIOS from .exe file
Hi, probably a pretty basic question for this forum, but… I have a computer with an Asrock H110m-HDV motherboard running P1.90 bios. Due (i think) to repeated power interruptions the computer no longer boots at all (fans run and it sounds like it is initiating as normal but no screen action). Have swapped out the ram and cleared cmos with no effect. I do have a ch341 programmer which is reading the current bios chip and I have saved this file, but I don’t know what program to use in order to extract the .bin file from the Asrock .exe file in order to reflash the bios? Any help/suggestions appreciated, Many thanks in advance.
Edit by Fernando: Thread title customized
The one as ROM…if you look at the link at selection of server download: H110M-HDV(7.60)ROM.zip
In this case the “Instant Flash” one
File extension is not an issue, just rename it.
Thank you, this has worked and I was able to write the file to bios chip.
