[PROBLEM] Flashing a modded ASRock Z370 MB BIOS
which one patch use working ?
possible upload ?
i need Z370 asrock taichi
thanks
This possible use latest version asrock bios Z370 asrock taichi
or same not working z370m ?
actually not possible test yet not any cpu
No more patch needed, the UBU tool removes the capsule security check.
[Guide] How to flash a modded AMI UEFI BIOS
EDIT: Ok forgot that new note on Intel 300+
U can try, making an SPI dump of the current on system with Intel FPT tool, test bios access regions with write operation, if fails access u need to unlock it first, edit and then flash it back with the same tool.
or dump only the bios region, edit and paste over with UEFI tool in the stock bios file.
No success granted, ur risk ONLY.
Other than that, stick with the old guides, the user lordkag last login was back in 2018, Lost_N_Bios last January, so better try a more recent user that succeed in the operation on ur model.
plz read linked post :
"b) that the UBU tool found it and was able to removed it (not possible with BIOSes of the newest ASRock mainboards)."
application:
2 - Remove Instant Flash Protection (Not work for AMD 400+/ Intel 300+ chipsers)
other way ?
@lordkag patch working latest bios z370 asrock or not ?
