hi
when i try to flash bios
using h2offt or flashit
i get this error
facp not found
@kirolos
Since your chosen thread title has been very unspecific, I have customized it and moved the thread into the “BIOS Modding” Forum Category.
Good luck!
thanks
fdpacker is just an archiver. Like winrar or 7zip. It packs flasher + bios file in a single executable. Is this what you need?
i need agurment when i use without agurment i get this result
flash.exe
option:
c:/
If you specify the bios filename only it will try to flash in auto mode. If in windows, flash according to platform.ini.
What files you have in the folder?
i tryting to flash in freedos not windows
i have 2 folders bin have flash tool
msg.ini
platform.ini
and folder with fdpacker
i used h2offt without [InsydeFdPacker]
Then the flasher is not compatible. Packing with fdpacker won’t give a different result.
can you give me a compatible flasher (support dos) , this is toshiba laptop
I don’t have a compatible one nor know the exact version needed.
i searched on internet until i get compatible version but i have another problem
everytime i try to flash i get this error
error:facp not found
h2offt or flashit
i get this error
facp not found
i tried other versions of bios
and programs but no luck
Any luck?
I have a similar problem with a Toshiba laptop.
error: IHISI 15h failed. internal error 20.
FTBS: permission is denied by user
