Hello fellow forumers, I really need help as I have been trying to tweak and figuring things out on my BIOS. The reason I modded the BIOS is due to the motherboard not supporting Intel Xeon despite the microcode being there already. I am using FPT because EFIFlash, BIOS Flash, AFUDOS, AFUWIN doesn’t work as it will say invalid image.
Motherboard: GA-B250M-DS3H
CPU: Intel Xeon E3-1240-v5 (That I’m trying to get to work)
CPU: Intel i3-7100 (CPU thats being used to flash using FPT)
What I did:
- Updated the microcode using UBU
- Disabled and Removed ME Recovery using CoffeeTime
- Added patches such as PCIe, Init 8+ CPUs, ACPI tables, support for 128Gb ram
PCIe (The patch removes device_id checking by host bridge to enable CPU PCIe lines)
Init 8+ CPUs (The Patch allow system to init more than 8 CPU thread)
ACPI tables (The patch implement correct features control for 8+ threads like C-state, thermal, performance, throttling, etc)
Now that ME is disabled, its able to boot the Intel Xeon CPU. However, certain RAM were not able to be used despite only a bit different (2444Mhz and 2449Mhz on the label). The 2449Mhz were able to boot with single stick, but the 2444Mhz fail to boot with a single stick. But if I use the i3-7100, its able to boot both stick regardless in any slot.
Another issue I am facing is where when restarting PC from Windows OS or from the BIOS (Exiting with saving) will cause it not to boot. It will shutdown, but when it turned on again, it will only stays on for 1-3 second before shutting down. Not only that, it’ll not boot even if I tried to power on. The only way to fix this would be turning of PSU and holding power button for 5-10s before turning on the PSU again and pressing the power button again. This issue also doesn’t happen with i3-7100 CPU.
I’m at my end wits, so I’d hope this forum would help me with troubleshooting or possibly giving a method to fix this. Original and the modded BIOS are attached in the link below.
Note: Not having those patches other than ME disabled and ME Recovery removed doesn’t change anything, since those are only for Coffeelake mod (Which I will attempt in the future)
Edit by Fernando: Thread title specified and customized
