Hey Guys , i am Lara from Germany i say hello to all here
I have a Problem with my Uefi . I have are HP 8560p Elitebook with Intel i7 Prozessor . I can not upgrade my Uefi , because the previous owner from the HP 8560p , has write protection set. I have the newest Uefi file from HP . In the Logfile is are error message : Uefi can not installed ,write protection set ā¦
Now i have found the program CHIPSEC . I working on this for 1 Week . I have all instructions i from here befoling:
Create the USB with Boot Efi File https ://chipsec.github.io/USB%20with%20UEFI%20Shell.html This not working , the instructions was correctly executed.
Now i think this is another problem in the UEFI Settings . I have Windows 7 and Windows 10 for working this problem installed in Uefi Modus.
Can someone help me solve this problem .
The program CHIPSEC runnig in Windows 10 , I just donāt know how to get it to work I have the program Python 3⦠and Chipsec from Githup āMaster fileā downloaded , see here : https:// github.com/chipsec/chipsec
Can anyone help me CHIPSEC Runnig in Windwos 10 with python with professional instructions please Or have anyone are idea , why not chipsec stardet with the USB instructions .
Greetz Lara
Edit by Fernando: Unneeded blank lines removed (for better readability and to save space) and thread title customized
@Lara : Welcome to the Win-RAID Forum! I have moved your thread into the better matching Sub-Forum "BIOS Modding Guides and Problems" and hope, that this is ok for you.
Does this mean, that you cannot flash any original BIOS, which is offered by HP for your notebook? Have you already looked into the "Security" section of the BIOS? How are the settings there? Regards Dieter (alias Fernando)
Yes i can not Flash the bios thats realy . I know Write protection is set . I dont know what the previous owner of mine HP 8560p set in the epprom memory . maybe it explains why chipsec not from usb via efi bootet .
My security settings looks normal, secure boot there is not any . Which informations do you want from my UEFI , direct ?
I have I tried to flash the uefi from usb and from windows directly . Its working , however the log file says error and write protection is set .
@Lara : Yes, I am a German like you, but the Forum language is English. I cannot help you anyway, because I am not an expert regarding your problem. You should wait until you get a reply from someone, who can really help you. Good luck!
I used Chipsec once, but thatās a while ago. but I assume the stick doesnāt exist any longer. Easiest way this time was using an UEFI boot USB stick, but there was some fiddling to get it to work, thatās right. Iād normally prefer UEFI boot for such tools since it gives you more direct hardware access.
Thatās not what I wrote, I wrote āUEFI boot USB stickā and thatās a bootable USB stick with an EFI shell, as described in both links you provided.
Many year ago i do. Backup your bios with programmer. Find unlocked full firmware from internet. Program it in your pc with programmer (no remove programmer from pc). Start pc and go bios ( you must still be physical access to flash chip) Program your original bios. Go bios protection menu and disable protection. Then Shut down pc and remove programmer. This was so i remember⦠Not easy and possibe must do access throught cover.
e: so you must have second programming pc and example ch341 programmer and do power on hp pc chip programming.
