[Problem] Intel DX79SR Bios Update
Hello everyone,
I got an intel dx79SR and a E5 2680 v1 processor that they say is working with the board after an bios update. So i got the bios version 560 but the file is 9.9mb and the bios chip only hold 8mb. Is there any method to shrink the file or anyone can help me somehow ? I got spi programmer and desoldered the chip from the board and also made a backup copy of the old bios but now i got stuck at this.
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title customized
Latest is: BIOS Version 0650 - SIX7910J.86A.0650.2014.0307.0138 (April 11, 2014)
CPU support on bios 0430…
I have 650 too but same problem since it have 9.9mb. I need a version that is 8mb and must be .bin format
Ok but what bios has the board currently? Is it functional? Why won’t use regular Intel update files?
Why are you using an SPI programmer?
Since that Xeon is supported already from 0430…
looks like is 537 but tryed two cpu’s and no post. I tryed with regular intel updates like f7 and even intel bios update .exe on win10 and win7 32bit
Seems the board is OK…try to search for older bios update files and do incremental updates 0553, 0559, 0590, 0594, till 0650.
SPI programmer as option, should be very, very last resource…
Intel files are based on AMI Aptio Core but really not a regular AMI bios, to a programmer the best option is a working dump.
EDIT: A similar user had no success booting a 2687w even after getting help, updates… maybe board revision, seems AA…-003 was launched in 2013
First of all i dont have any other bios than 590 and 650. I read somewhere that those intel bios chips are write protected and cannot update bios thru classic methods thats why SPI programmer was the last option
