After forced update from Q7CN44WW to Q7cn45ww my bios is on 45ww and my ec remains on 44ww. Manufacturer refuses to honour warranty.
Legion pro 7i
Will this work
[details=“Summary”]
“====================================================================================== THE ULTIMATE OFFLINE REINSTALLATION, BIOS DOWNGRADE & FIRMWARE LOCKDOWN ====================================================================================== [PHASE 1: ONLINE PREPARATION] 1. Open Device Manager (Windows Key + X → Device Manager). 2. Expand the “Firmware” category. 3. Right-click “System Firmware” → Properties → Details tab. 4. Select “Hardware Ids” from the dropdown menu. 5. Highlight the BOTTOM entry: UEFI\RES_{be248459-caf2-4b09-af02-69b6a49974c1} 6. Copy and save this exact Hardware ID string to an external USB drive. 7. Save your BIOS installer (Q7CN44WW.exe) to that same external USB drive. 8. Create a bootable Windows 11 Installation USB drive using the Media Creation Tool. [PHASE 2: NETWORK ISOLATION, DRIVE FORMATTING & REINSTALLATION] 1. Turn off your home internet router completely and unplug any Ethernet cables. 2. Insert your Windows Installation USB, restart the laptop, and tap F12 to open the boot menu. 3. Choose the Windows USB drive from the menu to boot into the Windows Setup environment. 4. Select your language, time, and keyboard layout preferences, then click “Next”. 5. Click “Install now”, accept the software license terms, and click “Next”. 6. When asked “Which type of installation do you want?”, choose “Custom: Install Windows only (advanced)”. 7. You will see a list of all current hard drive partitions. One by one, select EACH partition on your main drive (Drive 0) and click the “Delete” button below the list. 8. Confirm the deletions until the entire disk is wiped clean and shows only a single entry: “Drive 0 Unallocated Space”. (This permanently eliminates any hidden, staged 45ww update payloads). 9. Select “Drive 0 Unallocated Space” and click “Next”. Windows will automatically format the disk, copy its installation files, and install cleanly. [PHASE 3: BYPASSING MANDATORY WINDOWS NETWORK SETUP (OOBE)] 1. When the laptop finishes installing and reboots to the initial region selection screen, do NOT connect to the internet. 2. Press Shift + F10 on your keyboard to instantly open an Administrator Command Prompt window over the setup screen. 3. Type the following command exactly and press Enter: OOBE\BYPASSNRO 4. The system will instantly reboot itself. When the network setup screen appears again, a new option will be visible. 5. Click “I don’t have internet”, followed by “Continue with limited setup”. 6. Create a standard local user account with a name and password, finish the privacy toggles, and proceed until you land on the offline desktop. [PHASE 4: USER INTERFACE HARDWARE BLOCK] 1. Press Windows Key + R, type “sysdm.cpl”, and press Enter to open System Properties. 2. Navigate to the Hardware tab. 3. Click the “Device Installation Settings” button. 4. Select “No (your device might not work as expected)”. 5. Click “Save Changes” and close the window. [PHASE 5: INITIAL REGISTRY BLOCK] 1. Click the Windows Start menu, type “cmd”, right-click Command Prompt, and select “Run as Administrator”. 2. Copy the entire command below, paste it into the window, and press Enter: reg add “HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate” /f && reg add “HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU” /v NoAutoUpdate /t REG_DWORD /d 1 /f && reg add “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\DriverSearching” /v SearchOrderConfig /t REG_DWORD /d 0 /f 3. Verify that you see “The operation completed successfully.” for each command. Close the Command Prompt. [PHASE 6: RESET BIOS DEFAULTS & ALLOW BACK FLASH] 1. Shut down the computer completely. 2. Power it back on and immediately begin tapping F2 continuously to enter the InsydeH2O BIOS menu. 3. Press F9 to load Setup Defaults, then select Yes. (This cleans out unstable NVRAM variables). 4. Use the arrow keys to navigate to the “Configuration” menu tab. 5. Locate the “BIOS Back Flash” option and change it to “Enabled”. 6. Press F10 to save your changes and exit. Allow the laptop to boot back to the offline desktop. [PHASE 7: EXECUTING THE BIOS DOWNGRADE] 1. Plug in your external USB storage drive containing your tools. 2. Locate your downloaded “Q7CN44WW.exe” installer file. 3. Right-click the file and select “Run as Administrator”. 4. Follow the installer prompts until the laptop initiates a restart. 5. LEAVE THE LAPTOP UNTOUCHED. The display will remain pitch black and the cooling fans will ramp up to full speed while the firmware rewrites. Wait until it boots back onto the Windows desktop. [PHASE 8: MAXIMUM HARDWARE RESISTANCE LOCKDOWN (THE DEEP REGISTRY CONTROL)] 1. Press Windows Key + R, type “regedit”, and press Enter to launch the Registry Editor. 2. Navigate down through the left-hand folder tree to exactly this path: HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows 3. Right-click the “Windows” folder key, select New → Key, and name it: DeviceInstall 4. Right-click your new “DeviceInstall” folder, select New → Key, and name it: Restrictions 5. Right-click your new “Restrictions” folder, select New → Key, and name it: DenyDeviceIDs 6. Left-click to highlight the “Restrictions” folder in the left pane. 7. Right-click in the empty right-hand pane, select New → DWORD (32-bit) Value, and name it: DenyDeviceIDs 8. Double-click that new DenyDeviceIDs DWORD, change its Value Data to 1, and click OK. 9. Right-click in the empty right pane again, select New → DWORD (32-bit) Value, and name it: DenyDeviceIDsRetroactive 10. Double-click it, change its Value Data to 1, and click OK. 11. Left-click to highlight the “DenyDeviceIDs” folder key in the left pane tree. 12. Right-click in the empty right pane, select New → String Value, and name it simply: 1 13. Double-click this “1” value. In the “Value data” field, paste your exact hardware ID string: UEFI\RES_{be248459-caf2-4b09-af02-69b6a49974c1} 14. Click OK, then close the Registry Editor. [PHASE 9: DISABLING FIRMWARE NODE IN DEVICE MANAGER] 1. Press Windows Key + X and select Device Manager. 2. Scroll down and click the arrow next to “Firmware” to expand it. 3. Right-click “System Firmware” and select “Disable device”. 4. Click Yes on the warning prompt. Do NOT click uninstall; choose Disable so the block stays active. 5. Restart your computer one final time to seal all kernel configurations. [PHASE 10: VANTAGE SHIELD & RECONNECTING] 1. Turn your internet router back on or reconnect your Ethernet cable. 2. Immediately launch the Lenovo Vantage or Legion Toolkit application on your desktop. 3. Go directly to its application settings panel and locate “System Auto-Updates”. 4. Explicitly change this toggle to “Disabled”. 5. Your system is now 100% armored on the 44WW BIOS, and all auto-installation pathways are neutralized."
[/details]
Edit by Fernando: Thread moved intothe “BIOS Problems” Category and title customized
