[Problem] Machinist X99 U9 Mainboard doesn't work
Hey I just bought one of these x99 u9 boards I cant figure out how to message people on this forum doesnt make sense but okay…., I bought one of these boards and it literally does nothing it has to be the board psu works ram works video card works mother boards never displayed error codes nothing buttons or short pins to turn on has never resulted in anything at all its just hard t I believe a newer board is just doa maybe im missing something?
Edit by Fernando: Thread title specified
What exactly is the issue you’re facing? You cannot power on the board? You should check the clear CMOS jumper to see if it happens to be in the clear position instead of normal position.
I haven’t thought to look, not sure where that’s located but near the battery maybe? I’ll look on solder mask though just i have to look it’ll be one of the things with a jumper obviously , let me check
It’s labeled JCMOS, near the bottom right corner. The jumper should be set on pin 1-2 I believe.
Yeah bummer its uhh set to 1-2 I could move it to 2-3 I guess ?
Would a dead cpu make a board not get power ? it’s as if the board isn’t getting anyway
If it’s already in 1-2 then it’s correct (2-3 is clear cmos)
Yeah I mean all other parts work ive tested the board with 2 working power supplys I dont have another x99 socket to test the cpu , but I feel like it has to be the board its never done anything to indicate power happening a bad cpu the vrm fan would atleast spin or something id imagine right ? Its like the board literally isnt getting power.
Its pretty upsetting took like 3 weeks to get i mean the package was beat up a little bit but its hard to think its really just doa , the seller on ebay has good ratings an alot of sales blahhh…. I guess ill have to try again :frowning: the whole reason was to save money but now its like probably good luck on a return to china from the US :confused: an this whole ordeal didn’t save me anything ending up spending more on a dead platform instead of for something i could of upgraded is a real pain too
Yeah I think you’d better return the board.
Its like a less than 4% chance to happen a doa board smh…. IDK I was thinking maybe I didnt have the ram in the right slots an the cmos battery maybe is weak are the only things I can think ibwas gunna do a clear cmos thing than a cycle power without it plugged in thing an try that… But if I had ram in improper spot would it just not even try to post at all?? like no error codes ever happen just nothing ever :frowning:??
If I order another board , would you suggest any? I really liked the u9/v9s boards seemed promising. :disappointed_face:
They look nice, but other than the appearance the U9/V9S do not offer anything justifying of their high price. Where do you live to be exact?
I live in Newyork. So , uhhhm my idea was build something for editing mostly on the cheapest I could atm right … Anyway I got a E5-2690v4 , 64gb 32x2 Samsung 3200mhz UDIMMs , and a RTX 4070 . 750watt Corsair PSU uhh a ASUS 14 pin 9665 whatever TPM module an the U9 board never got the board to do anything though with just Ram and CPU nothing else , Ive been busy with life also so I havent even got around to trying the clear CMOS thing an I dont know maybe I had Ram in the wrong slots ? Maybe I bad battery but would that totally prevent vrm spin up an error display from doing anything idk Im about to try the clear CMOS thing now actually
