Hello everyone,
I have two identical laptops Acer Aspire 3 A325-53 with the same specifications:
CPU: Intel Core i3-1305U (Alder Lake-P)
Board: TU141AL R2.1A
BIOS Flash: Winbond/FM25W128 (16 MB)
Boot storage: NVMe M.2 2280, PCIe Gen3 x4 (ADATA OEM – Model KN.512S0.00D)
Problem description
One of the laptops had a corrupted BIOS.
I successfully restored boot by flashing a full dump (16 MB) taken from the working identical machine using an external EEPROM programmer.
The system turns on and has video, but now:
NVMe is not detected at all unless a USB drive is connected
ME Firmware Version shows 0.0.0.0 in BIOS
ME is “Temporarily Disabled” and cannot be enabled
PCIe root port for NVMe seems inactive without any external device connected
The second machine (the source) works perfectly with NVMe + ME enabled, so it’s not a hardware issue.
What has been tested
NVMe SSD tested in the working laptop → works normally
Full flash with verified write/verify → system boots fine
FPT cannot reflash ME due to locked descriptor (Error 37)
Enabling ME in the BIOS setup has no effect
NVMe only shows up when another storage device is connected through USB
This strongly suggests a corrupted / mismatched ME + NVMe PCIe policy / straps in the flashed image.
Files available for repair
I can provide for analysis:
full_atual.bin → dump of the currently working but broken laptop (16 MB, ME disabled, NVMe not detected)
ME Clean file (16.1.27.2225) which matches the working system
Photos of BIOS screens from both machines (ME version and NVMe detection)
(Just tell me what else to dump or provide)
Request
I need help rebuilding the BIOS:
Re-enable ME region properly (matching Alder Lake-P SKU)
Correct/restore PCIe/NVMe PCH strap configuration
Disable BootGuard key mismatch (if needed)
Preserve DMI data (SN, SNID, UUID, OEM key)
Keep EC compatibility (battery/keyboard issues are known on Acer if mismatched)
Any guidance, clean ME region rebuild, FIT settings, or rebuilt image would be greatly appreciated.
Tagging users who might help
@plutomaniac @Lost_N_BIOS @Pacman @chinobino
Thank you in advance for your help!
Edit by Fernando: Thread title shortened and customized
