[Problem] Mod BIOS to work with registered ECC modules?
Hello community,
is it possible to modify a RAM stick to remove the registered and ECC function to use it as a usual RAM in non-server desktop boards? I have a bunch of SAMSUNG M393A2K40BB1-CRC and it fits into my Fujitsu (now Kontron) D3600-A1 but it doesn’t boot.
Or maybe easier to mod the bios of the board to ignore/override the reg. and ECC?
I’m familiar with SMD soldering and flashing (bios or SPD data), so a hardware mod might be possible.
Never hear anyone getting something like that to work in 20 years or so. No consumer grade Socket has ever supported RDIMM in any form, so there may not be support on the CPU Integrated Memory Controller that you can enable at all.
The last platform that had both UDIMM and RDIMM support was LGA 2011-3 where consumer X99 boards could use either out-of-the-box (In non-ECC mode with a Core i7, ECC required a Xeon E5) but that was because that platform was shared with the Xeon E5 line that officially supported RDIMM, so Intel may not have bothered to disable it there, whereas on consumer Sockets no CPU supported it, ever.
https://www.overclockers.com/forums/threads/rdimm-on-x99-mainboards-with-i7.755952/
The only caveat is that X99 motherboards may not officially list support for Xeon E5 v3 CPUs or registered ECC memory. For example, the Asus X99 Deluxe board we use lists only a handful of Xeon E5 CPUs as being supported, and never mentions anything about registered ECC RAM. We know they work on that board since we have thoroughly tested it, but it is entirely possible another brand or model may use a BIOS that does not allow for Xeon or Registered ECC memory to be used.
