Hello everyone,
How it happened:
So after trying to downgrade my motherboard from beta version to a stable version utilizing the uefi flash tool . My motherboard now shows a white ez debug light and no display.
What I have tried:
- Tried reseting the bios setting by shorting the pins and removing the CMOS battery
The question:
I’m sure this can be solved by utilizing a bios programmer and I have few questions regarding it:
Which programmer can I use for my motherboard? I found “CH341A Programmer” to be the most common one but not sure how to check if it support for motherboard.
Looking into my bios chip i noticed it was a 1.65V-1.95V supply range will I also require a 1.8V adapter along with a programmer?
If a programmer is chosen, what things do I need to keep in mind so that I dont end up fusing my bios chip?
Components Information:
Motherboard: MSI A320M PRO-VD/S
CPU: Ryzen 3 2200G
BIOS Chip: winbond 25Q128FW5Q 1829
Thank you, let me know if any other or more information is required.
