greetings to all,
i would like to have NVME booting on a Lenovo M73 Tower
i ‘roughly’ followed guides from:
[HowTo] Get full NVMe Support for all Systems with an AMI UEFI BIOS - Special Topics / NVMe Support for old Systems - Win-Raid Forum
and from: Modify the BIOS of a Lenovo M92 to enable native NVMe support
my unit has an i5-4590 of w/c i had trouble w/ blank reboot, fixed w/ ME update (9.0, Build 1487, Hot Fix 31)
what i did as follows:
-: dump BIOS: fptw -bios -d biosORIG.bin
-: insert: “NvmExpressDxe_Small.ffs” after UsbVfs & saved BIOS to: ‘biosMOD.bin’
-: flashing the BIOS w/out putting the PC to sleep gives error below: fptw -bios -f biosMOD.bin
Error 28: Protected Range Registers are currently set by BIOS, preventing flash access. Please contact the target system BIOS vendor for an option to disable Protected Range Registers.
if i put the PC to sleep, then perform: fptw -bios -f biosMOD.bin
i get error below irregardless if “ME_DIS” jumper is set or not
Intel (R) Flash Programming Tool. Version: 9.1.10.1000
Copyright (c) 2007 - 2014, Intel Corporation. All rights reserved.
Platform: Intel(R) H81 Express Chipset
Reading HSFSTS register... Flash Descriptor: Valid
--- Flash Devices Found ---
W25Q64BV ID:0xEF4017 Size: 8192KB (65536Kb)
PDR Region does not exist.
GBE Region does not exist.
- Reading Flash [0x800000] 4096KB of 4096KB - 100% complete.
Error 7: Hardware sequencing failed. Make sure that you have access to target flash area!
Trying to erase the same block (iteration: 2)
Trying to erase the same block (iteration: 3)
Failed to erase this block 3 times!!
dumplock info
c:\bios>fptw.exe -dumplock
Lock Settings.
Host CPU master: 00 00 0B 0A
ME region master: 00 00 0D 0C
GBE region master: 18 01 08 08
FPT Operation Passed
uploaded bios.zip (5.1 MB) containing orig & modified bios
i am stuck & i would like to seek guidance/insights/pointers for this & thank you for reading my post
Edit by Fernando: Thread title shortened and customized
