[Problem] NVMe Support of Zebronics ZEB-H61NVMe
Greetings for all.. I have a Zebronics motherboard H61NVME and I have one issue. I plug one NVME PCIE 3.0 SSD and the bios no detect this one. I have one backup of my pc bios to see if you can check it. Thanks.
ZEB-H61M2 OK.BIN.zip (2.7 MB)
Edit by Fernando Thread moved into the “BIOS Problems” Category and title customized
One what sir… wizards here now???
To check what sir… ask the damm Chinese guy who took your money.
The Chinese guy will tell you “the One” “models” of NVMe disks supported…
A POS that doesnt worth not even 10Euros and still they get “fated” by some costumers… and i’m not a “wealthy” guy…
@gordonhenriquez
Welcome to the Win-Raid Forum!
Please attach a screenshot of the related BIOS screen.
This is the bios screen..
And this is the NMVE SSD
@gordonhenriquez
Thanks for the pictures.
I suspect, that it is a BIOS issue, but that booting off the NVMe SSD will be possible nevertheless.
Please enter the initial post of >this< thread and try to get a modern Windows OS (Win10/11) installed onto the NVMe SSD by following the chapter “STEP 4” of my Guide.
This way you will get knowledge about your mainboard’s NVMe support - good luck!
Don’t forget to give here a feedback about the result of your test.
