[Problem] Overheating HP Spectre, no undervolt support :(
I have an
HP spectre x360 convertible 13t-aw000 with an i7-1065G7 CPU, Despite changing the thermal paste and cranking the fans to max, even setting the CPU to battery mode or limiting freq to 1.6ghz, it still hits 80C Under load, setting it to turbo/performance of course kills it from overheating without much load (All changes done via throttlestop). After doing some more research I discovered intel discontinued undervolt support for these CPUs due to a CVE from 2019.
I have a ch347 and ch341 and consider myself to have decent knowledge so far, but not perfect, so i’d love to learn any news/more advice in general. I’m happy to test any new images. I extracted the image and looked thru IFRExtractor and found that it has undervolt option/cpu overclocking lock etc
What i’m stuck at so far, is how to re-assemble the bios after tweaking some options from IFRExtractor, and how to confirm if they work at all, or if this whole thing is possible. Everyone on the internet is giving mixed answers
Big thanks!
Bios files & Links:
https://support.hp.com/lv-en/drivers/hp-spectre-13-aw0000-x360-convertible-pc-series/model/29100378
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title ustomized
Are you sure the thermal dissipation is well seated/equitable settled surface…
Being equipped with two fans and no dedicated GPU…
EDIT:
Then sell it…
yes well seated, checked myself and by a technician
I don’t want to sell it, plus who’s gonna buy it with this problem, this model will bring pennies if sold as well.
HP modern machines since 2014 have very low success percentage in modding…Sure Smart and other security details, even some recoveries with original HP files/dumps by SPI programmer can lead to several issues…not to discourage you, there’'s plenty to read on the forum, all the best.
ok, thanks anyway
