[Problem] Power Limit of HP Victus 15
MY MAIN QUESTION: THE CHARGER THAT COMES PRE EQUIPPED IS A 120W CHARGER IM PLAINING TO UPGRADE MY CHARGER TO 200W AND UPDATE THE VBIOS TO 75W(60+15 WITH DB)IS THAT GONNA WORK ? LIKE CPU WATTAGE RN GOES AROUND 25W WHEN I PLAY FORTNITE IT NEVER REACHES ITS POTENTIAL COULD THIS UNLOCK THAT AS WELL?PLS CORRECT ME IF IM WRONG
RTX 3050 Laptop GPU Setting Wattage Current Power Limit 50 W Default Power Limit 40 W Maximum Power Limit 50 W
i have watched yt vids and do have the basic knowledge i just couldnt find a perfect match
HERE IS THE VBIOS
gpu z info
HP VICTUS 15
GPU RTX 3050 6GB Laptop GPU (GA107)
VRAM 6 GB Samsung GDDR6
Device ID 10DE-25AC
Subsystem ID 103C-8DD0
Subvendor HP VBIOS 94.07.87.40.2F
this one : VGA Bios Collection: HP RTX 3050 Mobile 6 GB | TechPowerUp
Default clock 892 MHz Boost clock 1177 MHz Memory 1372 MHz
Edit by Fernando: Thread title customized and specified
WOW THATS A LOT OF CAPS WHY ARE WE SHOUTING?! :grin: :rofl:
In all seriousness before doing any of that try downloading Universal x86 Tuning Utility. You’re likely throttling due to heat, find the skin temperature in UXTU, gradually raise and apply the change to see how that impacts your clocks. Taking a glance at your Victus 15 it looks like its cooling is probably pretty horrible so I’d definitely download something like HWInfo64 as well to monitor CPU\GPU temps with the system under load as you nudge up that skin temp. Its likely not a good idea to have the CPU\GPU exceed about 75c, particularly considering its a laptop.
cpu - around 85
gpu - 65 celcius
hp played safe with the newer models capping at 50w instead of 75w
and also you havent given me an answer for the main question i dont really care about my temps my cpu is relatively better than my gpu so its a bottleneck
