[Problem] QQLS debug LED Cpu solid White
Hi everyone. I need help getting a QQLS to work on an MSI H310M PRO-VD PLUS.
The system previously POSTed intermittently with QQLS on a very old BIOS ( one provided by Ali seller). I updated to the latest MSI BIOS, then modified it with CoffeeTime. Since flashing the modded BIOS I’m now get a solid white CPU debug LED (as if no CPU is detected).
My CH341A clip is broken, so I’ve been hot-air removing the BIOS chip, programming it externally, and soldering it back. I reflashed multiple times with no change. I was getting constant boot loops the furthest i got was VGA boot loop with dgpu present. from the constant removing and resoldering the original chip pins were damaged during all this, so I replaced it with W25Q128JVSIQ chips (program/verify OK), but since its been using the new bios chips it shows the solid CPU LED.
At this point I’m also unsure if the QQLS itself may be dead. Screenshots of the original BIOS and my edited settings are attached. Any advice would be appreciated.
flashed back to MF bios still white led, i think the cpu is toast
