This is my first post here, apologies if anything is incorrect.
I am attempting to increase the voltage limit on my RAM in the BIOS of my Asrock TRX50 WS motherboard. The current limit is 1.43V, I would like to increase this to 1.7.
I have been using a few AI tools to try and get me to what I need, but so far all I have been able to do is successfully identify where in the ROM file the limit is held, and what hex code to change the value to in order to increase it.
Is it possible to modify these values within an efi shell tool? That is the most attractive method that Claude has given me, but I have been unable to boot into an EFI shell using the methods it has given me and the ones I have found online. Unfortunately my motherboard manual doesn’t seem to give any clear instructions on this either. Is there a clear guide or instructions I can use to boot into the efi shell?
Would modifying the ROM file with AMIBCP and changing the limit there work? Is there a reliably safe source for that software?
