[Problem] Shuttle SX79R5 hangs while booting in UEFI mode
its there but (forgot to foto :see_no_evil_monkey: ) and in that administrator mode the bios is somewhat glitchy (double entry´s or entrys with no name etc)
But do the options here work? Do you have normal boot time when set the options to UEFI-only (or disable CSM completely)? The text glitches shouldn’t be that big of a problem in my opinion.
@th3l0lb0y here last attempt
@Tris when i disable CSM completly he wont boot at all
but if i set it to UEFI only it boot´s normal if i set all right (PXE OpROM policy (Do not Launch) and Video OpRom Policy UEFI Only)
@karfel ill test it right now (wich one should i flash first ? V1 or V2 ?
V1, that image is based on koekieezz mod, there’s should be new entry on Boot > CSM parameters > Launch CSM ← set it off.
ok i tested both (V1 and V2) niether V1 or V2 showed the CSM menu
I think you can be happy with this config =))
@karfel Could you tell/elaborate us how you’ve done this feat?
Thank you! Seems this would set it, the bios i did (Nvme, Latest mCode, Rebar, Latest Intel ME FW 8.1.70.1590) + @karfel 's unlocking bios should be the complete bios @th3l0lb0y :slight_smile:
But didn’t th3l0lb0y say neither of karfel’s mods showed CSM menu?
@tris thats right it didnt work
