try the 2600 with the asrock x570 and let us know ! @Windows7_Fan
@Fernando Very interesting!
So theorectically if that is the case, a microcode from the BIOS of a Windows 7 compatible motherboard like MSI X570-Creation can be extracted and then reinjected to another BIOS of another motherboard manufacturer.
Could this be a possibility perhaps?
@avsd1 Ohhh I’m already using it!
From a few posts earlier (or on anothe thread) I’ve stated the Ryzen 2600 works on the Asrock X570 Pro4, both Windows 7 32-bit and 64-bit boots up and allows installation to progress with no issues (except for drivers of couse)!
It’s really the Ryzen 5000 (and somewhere it’s been said the 3000) series that have issues.
@Windows7_Fan
Yes, it should be possible to insert a certain CPU microcode, which had been extracted from the BIOS of another mainboard.
The only question will be whether it will work as desired.
By the way - your question had nothing to do with the topic of this thread.
@Fernando I think this is the scary part now…who will go ahead and do the First step; The long winded process of extracting the code from compatible BIOS.
Second step; To inject the microcode to desired BIOS and rebuild it.
Third step; Flash motherboard with modified BIOS.
Aaahhh…
@Windows7_Fan
This discussion becomes completely off-topic!
Update: Since your recent contributions didn’t match the topic of the target thread, I have moved them into this already existing and much better matching one.
@Fernando @canonkong @avsd1 @MeatWar Hey everyone, sorry for being a bit quiet here lately, as I’ve been pretty busy with some work on the current working build of Windows 7 64-bit on the Ryzen 2600 (and using all 128GB of Ram)!
Whilst this is nice, I still absolutely desire after being somewhat spoiled when testing out the 5950x on Windows 10, thus I REALLY need to utilise that processor anyway and besides…that was kind of the whole point of all this
So, letting you all know, I’m going ahead once again and going to bite the bullet, I am going to do some microcode transferring.
Starting from my post(s) on this topic here: [Problem] Win7 install with x570 Chipset+Ryzen 5000 Ser. CPU - #70 by Windows7_Fan
The MSI X570 Creation seems to be the best motherboard for compatibility, and as stated by user @K4sum1 the 5950x runs with his current BIOS albeit being version 7C36v1I.
I am thinking of using that version as a basis, extract the microcode for the 5950x and inject into to the latest Asrock X570 Pro4 BIOS being v5.60.
Before proceeding (although I’m procrastinating a lot these days), is there any word of advice or anything like to be said before I go down this rabbit hole?
Dumb idea? Run a Hypervisor on the 5950X and use 7 with GPU passthrough.
Or have it as a hypervisor with whatever OS that you might want 16c32t for, and main a weaker system. I want to do this myself sometime as I get tired of having all my RAM eaten up and CPU pegged doing intensive tasks. Although not sure when I would have the money to get another powerful system I would want to main. I would want to go 11th gen Intel and 11700/11900K(F) for the lower latency.
I do not believe this is due to mcode, the base patch released by AMD should be intact used by OEMs, ill point this to “OS features abandonware” and consequently modern ACPI/DSDT and all users should expect this to continue in modern hardware platform releases, there’s no “gains” in supporting old OS for consumer market when the OS manufacturer already dropped support for it and keeps pressing forward.
You’ll have a chance with this only from a user with spare time and a very good knowledge of AMD DSDT AML/ ACPI FADT tables…
Read some topics on ACPI specs revisions and their implementations vs OS support…you’ll get the picture.
Here’s just a taste of it with easy understand of it.
My advice is to get an old platform hardware mb as spare system to your needs, regarding W7 OS, good luck.
@K4sum1 @MeatWar Thanks guys for getting back to me!
I would like to point out that I AM currently running Windows 7 64-bit on my comuter rig at the moment, but this is on a Ryzen 2600 (Pinnacle Ridge).
To reiterate, as soon as I swap or change the CPU to a 5950x (Vermeer), it will fail to boot, nor will it execute a Windows 7 x64 installation disc or USB (unless it was a Gen2 release, which seems to use a Windows 8 setup style installation GUI).
It is for these reasons, including @Fernando’s assessment AND an Asrock tech support representative who also speculates that it’s to do with AGESA code, that I believe this could be a microcode problem
To avoid any misunderstanding: This does not mean, that each mainboard manufacturer compiles its own microcodes. The only difference between the mainboard manufacturers is the intensity, frequency and duration of the tests done with various BIOS modules.
@Fernando Rightttt okay then.
But these different values of the test they conduct, does that even affect the execution of Windows 7 64-bit files from installation?
Hi everyone, hope you’ve all had a good Easter!
I’m kind of new here and I’ve seen a lot of the work some users here have done and they’re all very impressive!
I don’t know if this is the right place to post this, but I originally began a topic on another thread here where I’ve been having problems booting my Windows 7 64-bit on my upgraded Asrock x570 Pro4 and Ryzen 5950x.
I’ve came to a conclusion that the BIOS is what’s refusing the OS.
Long story: [Problem] Win7 x64 Install onto ASRock X570 Pro4 with AMD Ryzen 5950X - #19 by Windows7_Fan
Short story: Updated BIOS to include Ryzen 5000 series compatibility fails to initialise Windows 7 64-bit (old and fresh install).
Swapped to Ryzen 2600 and operates as expected.
Windows 7 32-bit has no issues on either scenario.
Because of this I was really wondering, might anyone know if this is a current practice manufacturers do?
And does any of you intelligent lot know if it’s possible to mod the BIOS to accept any OSs it’s thrown at it?
I would REALLY appreciate it if anyone can help me on this matter, I’m without a working system for over 2 weeks now and well overdue with work, but I’ll be ever so grateful to know if this is a possibility
@Windows7_Fan
Since you had started 2 threads about the same topic in different Forum Categories, I have merged them. Unfortunately the Forum Software didn’t follow the chronological order of the posts with the result, that the only post of the 2nd thread started by you on 3rd of April 2024 is now the latest one within this merged thread. Shall I delete the last post?
