There’s an ME update on Asus pages: MEUpdateTool Version 14.1.70.2228v4
I’d recommend to update your ME since the one hidden in the bios update is rather old.
(Latest is 14.1.72.2287 though, but I don’t know a readily stitched update file that contains the latest PHY P, too, which is part of the Asus ME update)
@lfb6 Buddy, its funny that you mention this… because it reminds me that i would like to hear your opinion on it.
The thing is that the first couple of past ME FW images updates I’ve done to my board, based on 14.1.6x.xxxx versions, they did contain the PHY sub-component and always sticked in bios, but last 2 ones starting the 14.1.7x.xxxx (14.1.70.xxxx and last 14.1.72.2287) i lost the PHY sub-component in bios.
Still the official ME FW image update 14.1.72.2287 from MSI, (currently on my board) does contain the PHY stitched 12.14.215.2015, but i never researched what could be done to re-engage this sub-component again.
What do you mean by ‘you lost it’? What board are we talking about and did you check on a dump with MEA? What’s the output?
14.0 didn’t have PHY (and SAMF) module, those came with 14.1, so a ME 14 will be able to work without. But if they’re in the firmware they should stay there even if they aren’t part of the update?
Z490, i don’t have PHY on firmware anymore, it was always 14.1.xx.xxx from start, not 14.0
I know they work without it, still it was present before and of course the board has USB-C
Current state, only main CSE ME, PMC and PCHC, no issues at all, just curiosity on the issue
Anyway, just wanted to share the complete FW update
EDIT: Anytime, this mb of mine doesn’t have BFB feature or dual bios, has main system not going to try to fix it anyway, FPT/FWUpdL doesn’t write it anyway.
Oh, and it’s not April’s fool… by the way.
