I am working with an Intel Apollo Lake Atom E3950 embedded system. My goal is to downgrade the Trusted Execution Engine (TXE) from the current version 3.1.76.2356 (VCN/SVN 69) to 3.0.1.1107 (VCN/SVN 1).
My ultimate objective is to utilize the INTEL-SA-00086 vulnerability to bypass/disable BootGuard, Secure Boot, and Measured Boot, which are currently active on this hardware.
My Problem:
I am flashing directly via an external SPI programmer. Here is the behavior I’m seeing:
If I patch in TXE version with the same SVN (69 - eg. 3.1.75.2351**)**, the system boots perfectly.
If I patch in TXE v3.0.1.1107 (SVN 1), the system is brick-like and fails to POST.
My Workflow:
Followed the guide: [Guide] Clean Dumped Intel ME/TXE Regions with Data Initialization.
Used Intel Flash Image Tool to decompose the original flash.
Replaced the TXE binary with the target version (3.0.1.1107).
Manually copied the SMIP region in HxD from the original dump to the new build to preserve signatures hand hardware config
Flashed the resulting image back to the SPI chip.
I was under the impression that Apollo Lake does not have the same hardware-enforced Anti-Rollback mechanisms (like Field Programmable Fuses) that prevent TXE downgrades in the same way modern Core-i platforms do?
Is there any other lock on Apollo Lake that enforces SVN checks even when flashing via SPI that I am missing?
I have uploaded the original working dump and both patched versions (the working SVN 69 and the non-working SVN 1) for analysis here:
Any insight into why the boot process hangs on the lower SVN would be greatly appreciated.
