Question: is H310 bios mod for Xeon the same as H110?
I made E3-1230 V5 work on my ASROCK B150COMBO, simply toggle ME off in coffeetime 0.99 is enough. I guess since I already added all microcodes, supporting 2124G etc should work as long as the pin mod is correctly carried out.
I’m wondering, for H310, the pin mod is not needed. Has anyone ever tried one with ME toggled off?
I think the H310 with H310C chipset (22nm, like the older skylake chipsets), you can just disable the ME Hap bit.
Thanks, I will first update here with pin mod on B150 then H310
It all depends on the technical process.
