Question using Dell PFS
I usually use Dell PFS to extract the Bios Region and ME Region from the executable file downloaded from Dell’s website through Service Tag and then replace them in the donor file (dump file), do a Clean ME using FIT and generate my outimage file. Is it possible to generate an image using only the files extracted from the Dell executable that I can flash directly to the SPI Flash without using a donor file?
No
Ok thanks @lfb6. I suspected that
