I have a dell R720 that I bought but the bios seems to be corrupted. I have tried almost all the options in order to attempt to fix and troubleshoot it hut have had no luck. I have working IDRAC but no vga or virtual console. Idrac shows the post code 0x7f after a couple of minutes although I suspect this is an error as it does not have any os installed.
I have bought a bios flasher clamp but I do not know how to locate the bios chip or how to use the clamp to repair the bios. Can anyone help me?
