Hi @Lost_N_BIOS I’m very new to this Bios Modding community and I’m facing the same issues with this VarOffset 0xFFFF and VarStore 0x0. Is there any solution to this? Actually I’m happy enough to get my laptop able to run ThrottleStop with the FIVR function for undervolting enabled through some bios mod. My main concern for my laptop now is Fan Control. After dumping my bios and searching through everything about Fan Control I came to all this VarOffset 0xFFFF and Varstore 0x0 which is impossible to mod it. I’ve tried using Phoenix Tools but I can’t even open the dump file. Same if I use Amibcp I can’t open the dump file either. I really hope there is a solution to this. Cheers!
Edit by Fernando: Double posts merged and thread title customized/shortened
Removed post:
deleted by Fernando
Hello.
Could you elaborate what this means? I’m not up to speed on this.
@Userghost87 Welcome to the Win-RAID Forum!
Since it is not a good idea to post the same request twice on different places, I have merged them.
Our BIOS Guru Lost_N_BIOS hasn’t been online since Janiuary last year. So it it is very unlikely, that you will get a reply from him.
By the way - we neither offer nor support the “Phoenix Tools”. You may better ask the tool developer andyp at My Digital Life.
Good luck!
Dieter (alias Fernando)
0x762C9 Ref: OverClocking Performance Menu, VarStoreInfo (VarOffset/VarName): 0xFFFF, VarStore: 0x0, QuestionId: 0xA, FormId: 0x1013 {0F 0F 78 05 79 05 0A 00 00 00 FF FF 00 13 10}
0x762D8 End If {29 02}
0x762DA Ref: Memory Configuration, VarStoreInfo (VarOffset/VarName): 0xFFFF, VarStore: 0x0, QuestionId: 0xB, FormId: 0x1028 {0F 0F EF 10 F0 10 0B 00 00 00 FF FF 00 28 10}
0x762E9 Ref: System Agent (SA) Configuration, VarStoreInfo (VarOffset/VarName): 0xFFFF, VarStore: 0x0, QuestionId: 0xC, FormId: 0x1029 {0F 0F ED 10 EE 10 0C 00 00 00 FF FF 00 29 10}
0x762F8 Ref: PCIE Configuration, VarStoreInfo (VarOffset/VarName): 0xFFFF, VarStore: 0x0, QuestionId: 0xD, FormId: 0x1539 {0F 0F 93 0E 94 0E 0D 00 00 00 FF FF 00 39 15}
0x76307 Ref: PCH-IO Configuration, VarStoreInfo (VarOffset/VarName): 0xFFFF, VarStore: 0x0, QuestionId: 0xE, FormId: 0x102F {0F 0F 91 06 92 06 0E 00 00 00 FF FF 00 2F 10}
0x76316 Ref: PCH-FW Configuration, VarStoreInfo (VarOffset/VarName): 0xFFFF, VarStore: 0x0, QuestionId: 0xF, FormId: 0x103E {0F 0F FC 04 FD 04 0F 00 00 00 FF FF 00 3E 10}
0x76325 Ref: Thermal Configuration, VarStoreInfo (VarOffset/VarName): 0xFFFF, VarStore: 0x0, QuestionId: 0x10, FormId: 0x1046 {0F 0F F3 0E F4 0E 10 00 00 00 FF FF 00 46 10}
0x76334 Ref: Platform Settings, VarStoreInfo (VarOffset/VarName): 0xFFFF, VarStore: 0x0, QuestionId: 0x11, FormId: 0x1125 {0F 0F DA 0F DB 0F 11 00 00 00 FF FF 00 25 11}
0x76343 Ref: ACPI D3Cold settings, VarStoreInfo (VarOffset/VarName): 0xFFFF, VarStore: 0x0, QuestionId: 0x12, FormId: 0x10F3 {0F 0F 78 10 79 10 12 00 00 00 FF FF 00 F3 10}
0x76352 Ref: TPM Configuration, VarStoreInfo (VarOffset/VarName): 0xFFFF, VarStore: 0x0, QuestionId: 0x13, FormId: 0x104C {0F 0F A4 1B A5 1B 13 00 00 00 FF FF 00 4C 10}
0x76361 Ref: BCLK Configuration, VarStoreInfo (VarOffset/VarName): 0xFFFF, VarStore: 0x0, QuestionId: 0x14, FormId: 0x1389 {0F 0F D5 04 DE 04 14 00 00 00 FF FF 00 89 13}
0x76370 Ref: Rework Configuration, VarStoreInfo (VarOffset/VarName): 0xFFFF, VarStore: 0x0, QuestionId: 0x15, FormId: 0x10E0 {0F 0F A1 04 A2 04 15 00 00 00 FF FF 00 E0 10}
0x7637F End Form {29 02}
This is what I get from my dump. Each of those settings should have their own VarOffset and VarStore but those seems to be disabled by the manufacturer to 0xFFFF and 0x0 which means that I can’t change any of those settings. My question is how to get those settings enabled so that I can change those settings. I’ve came across a YouTube video seeing that person can easily enable a settings in Amibcp so I went on to download that software and the moment I try to open my dump file it says “Setup information not found”. This drives me crazy trying to figure how to open that file and enable those settings.
They should not. Follow "FormId" to find menus these entries refer to.
They should not. Follow “FormId” to find menus these entries refer to.
How do I follow the FormId and find the menus? I’m very confused
